Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Status light stays on
I have a 57inch Mitsubishi dlp. I turn the tv on and it is making a squeaking noise as if the lamp wants to come on. I wait a minute and the tv shuts down and the red status light stays on. This happened the other night and I reset the tv and it worked. Now, the tv will not work at all.
  • 2 more comments
  • woernle Dec 30, 2008
    I have the same problem but still comes on after turning it off and on a few times. Very irratating and waiting for the worst.
  • cajuncoonie Jan 05, 2009
    my tv turns on (i can hear the fan kick on) the green light blinks then stop blinking then the status light comes on (red) and stays on.i tried the reset button but nothing happens .this is a wd-62530 model
  • Anonymous Apr 02, 2009
    same issue tv tried to kick on squeks then red status light comes on. Ugg freaking expensive tv that has not lasted even 5 yrs wo problems
  • icdniner May 23, 2009
    NO PICTURE. Solid RED status light comes on after TV shuts itself off. No picture, but I can still hear audio. Occasionally, I can get a picture if I press the reset button and turn on, then it fails again. A SOLUTION WOULD BE MUCH APPRECIATED! My DLP is Mitsubishi 62725.
I have a 52inch mitsubishi dlp model ws-52725,I turn on the tv and the green light is plinking I have this befor and had to replace the module at a coat of 600.00 that was 2 years ago .I have done all the necessary steps,light still plinking.what do I have to do now ?My last mitsubishi I had for 15 years with no problem.Its mitsubishi going down hill. Thank you PS there any help any where ?
l#wd52725
Posted on Nov 22, 2008
TV turned off by itself one day. I pressed reset, timer light blinked green for a minute, then I pressed power and it sounded like it wanted to boot up, but nothing happened and the status light turn
Two thoughts:
First is this is a DLP set and the lamp may have failed
Second is it should have the self check which reads error codes---most of these sets that is the same:
" After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
(then release both)
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
This is for a earlier Mitsubishi DLP but should be the same as your set as Mitsubishi rarely changes things like this.
If you get the lamp abnormal it is likely your problem.
Dec 06, 2012 | Mitsubishi WD-Y65 65" HDTV
Lamp light is yellow. Replaced bulb still not working1
CHECK AND MAKE SURE THAT THE LAMP DOOR IS SECURE ON THE BACK OF THE TV.
Dec 16, 2010 | Mitsubishi WD-57733 57" HDTV
Where can i get a color wheel replacement for my DLP Mitsubishi WD-52525 210719 TV? I have changed the lamp and still the TV goes to black and the status light goes on.
This DLP tv model don't have a colors wheel.U hear alot of clickings sound,when power turn on?The Ballast board it dead.This board,job to help projection lamp to ignite.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP TV model WD-65100. Power not ON
What about Lamp Fan if it is defective lamp will not turn on and if Ballast Board is not working then Lamp itself will not power on. Encompass has parts for this TV 1-800-638-3328
Feb 09, 2010 | Televison & Video
Mitsubishi 65" DLP HDTV, Status light is red, no picture
Check your lamp; it may have blown. Sound, no picture and a red light are classis signs a lamp has failed.
Feb 02, 2009 | Mitsubishi WD-62528 62 in. LCD Television
Mitsubishi there first dlp wd65100 65in
That load sound could be the color wheel . But first check your lamp that could be bad. and if that noise you here sounds like something taping it could be color wheel which would be bad mit only sell complete light engines cost os 650.00.
But hopefully you will get lucky and only be your lamp.
Thanks doctor video
May 12, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
395 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
