Question about Motorola Mobility RAZR V3
Bad Reception Every time someone talks to me on my Razr, there is an extremely loud, electrical buzzing in the background, and I am very lucky when it is nonexistent. This problem began when I went off to college in Missouri (and I am from Minnesota), and I figured this was due to the on-campus wireless network interfering with reception. But the problem is still persisting even though I am now home for the holidays. Both of my parents have Razrs, as we are on a family plan, and neither of them experience this at all. Help me, please...
  • Anonymous Apr 16, 2008
    I also have a strong electrical buzzing noise. It comes and goes (mostly comes) and isn't related to environmental issues. It appears I need to take it to a service center.
    Sergeant:
    Champion:
  • 283 Answers
Man...do you have tester? if you have do this,.,. without the bat ,put the testers in each side of the bat terminal,, then check if the cursor moves... then switch the tester in each side, again check if it moves... if both terminals upon switching moves .. man your phone is grounded .. go to your nearest service center to fix that..... and if only one side move... you have to replace your speaker (earpiece>) ....only professionals do it....tnx..
Posted on Apr 16, 2008
Buzzing Refrigerant Lines
Have someone check your pressures & temperatures in your refrigeration system. Also check the compressor amps with an analog meter to see if the amps fluctuating. There might be something wrong with the compressor.
Jun 12, 2012 | Bryant Heating & Cooling
Hi, I Purchased an LG 50PK350 plasma tv and I am experiencing an extremely loud, annoying buzzing sound even with the amp switched off & the sound muted. The buzzing is not constant ... the brighter...
I have this tv aswell, and yes I will confirm that it does buzz quite alot, but all plasma tvs do, it is to do with how it renders images, the buzzing can be made worse by it being close to a wall and it reflecting back. I found that my tv stand some how amplified the buzzing when i got mine. I dont think its something you can escape.
Mine i notice also when scrolling around menus seems to have lines that follow your selection....not to pleased about that
Oct 18, 2010 | Televison & Video
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Lost picture extrem loud buzzing noise
You have a bad colorwheel. No to uncommon. It is in the light engine and you should probably call a tech. Input your zip on the homepage to find one in your area. Let me know if I can be of further assistance
Dec 28, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Poor reception
Go to a radio shark or to a phone store and tell them u want the Reception Booster that goes inside ur battery pack and this should improve ur Signal. :)
Feb 10, 2008 | Motorola Mobility RAZR V3
Battery not staying charged
what kind of reception do you have in your area? If you don't have good reception it can really kill your battery. Is your bluetooth on all the time thats also a battery killer. Those a re the two i see the most in the shop. How much time do you talk on your phone? If you can get more than 2 hrs talk time the phone is actually doing pretty well. Mine straight out of the box only got about 16hrs on a charge. 6 - 8 hrs if i talked a lot!
Anyway there may not be much wrong. Just check your reception and see if your bluetooth is on all the time. Good Luck!
Jan 08, 2008 | Motorola Mobility RAZR V3
Noise problems
This is a common problem, the solution is actually called the "Treo Buzz Fix".
Earlier models of the Treo 600 had an unshielded cable that connects the battery to the main board. This cable causes loud buzzing and interference on the Treo.
If your treo is under warranty (unlikely probably...) then send it back to Palm for replacement.
If not, try the fix. The fix involves disassembling your Treo and wrapping aluminum foil around the offending cable. Here is a guide:
http://mytreo.net/treofaq/BuzzFix
And here is a forum on MyTreo with high resolution pictures of the process, to help you:
http://mytreo.net/forum/index.php/topic,54886.msg429525.html#msg429525
This is a somewhat dangerous procedure. It is possible to damage your treo if you aren't careful. Follow all instructions EXTREMELY carefully.
Good luck! And don't break your Treo!
Nov 20, 2007 | Palm Treo 600 Handheld
Buzzing sound while talking
sounds like the earpiece is not grounded properly need to have a tech look at this
Nov 16, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Mobility RAZR V3 Logo
79 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
