Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire Model ltf2940es (Lowes) washes but does not spin
It's just past a year old, It goes through the wash cycle fine, but does not spin. The water will drain, but drum does not spin at all. Any suggestions? No wierd sounds or indications were given to detect a problem. Any suggestions would be most appreciated. Thanks
Stan
  • Anonymous Nov 26, 2008
    My spin cycle just went out too. Same machine, bought just under 2 years ago. Will run through all the cycles fine, and drain, but no final spin. UGH!!
  • 3 Answers
I HAVE THIS SAME PROBLEM . I HAVE LONG BACK GROUNG IN ELECTRONICS AND MECHANICAL WORKS.SO I DEICIEDED TO CHECK INTO MY PROBLEM I REMOVED THE REAR COVER AND I NOTICED THAT THE DRUM AND MOTOR ASSEMBLY HAD COME INTO CONTACKED WITH THE WIRING HARNESS EXPOSING THE WIRIES THIS COULD HAVE SHORTED OUT THE PROSSESSOR. I HAVE READ OTHER PROBLEM LIKE THIS ONE AND WHEN THERE REPAIR MAN CAME TO FIX ANOTHER PROBLEM THEN THEY TOLD THEM THEY NEEDED A NEW COMPUTER I THINK THEY KNOW OF THIS PROBLEM AND THEY ARE COVERING IT UP BECAUSE MOST PEOPLE DO NOT KNOW ANY THING ABOUT THIS.I HAVE MORE TEST TO RUN BUT I BELIEVE THIS IT THE ROOT OF ALL THESE PROBLEMS AND I THINK THEY NEED TO STEP UP AND ADMIT. THESE MACHINES COST A LOT OF MONEY AND WE SHOULD GET WHAT WE PAID FOR.
Posted on Nov 23, 2008
  • TWINTURBOCAV Nov 23, 2008
    ANOTHER THING THIS PROBLEM DOES NOT GIVE YOU A CODE
Frigidaire washing machine (FTW3011KW0) runs through all cycles, agitates, pumps out water, but doesn't spin, nor does the motor attempt to spin during the spin cycle
Your main switch needs replaced. The motor that drives the switch operates because it goes through the other cycles, so the switch must be bad.
murf427
Jul 31, 2012 | Frigidaire Washing Machines
My frigidaire stopped working
The bearings are bad. My sears kenmore did the same thing. Do you have hard water, that would be one cause. Or maybe it's still under warrenty because it is not a cheap fix.
Dec 31, 2009 | Frigidaire FTF530FS Front Load Washer
My Frigidaire Model fails to spin after wash
my washer had same problems, turned out to be door lock switch. around $75.00. Washer 2 years old. Questioning quality also.
Dec 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Spin cycle stopped on 10 yr old Amana washer
its the brushes on your motor or your pump is blocked or defective
Jun 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
Feb 07, 2009 | Frigidaire Washing Machines
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Sounds like the belt may be off. Was it moved with the shipping braces out? It may have caused some internar damage. You might check to see if the hum is coming from the door lock area. If the lock is out it won't let drain or spin.
May 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
258 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
