Question about Velodyne CT-80 Subwoofer
Cant get sound out of the receiver on the sat input
I am able to get video but I I am not getting any audio. My receiver is a Pioneer
    Problem Solver:
  • 15 Answers
Have you selected the appropriate input type? (e.g. Optical, HDMI?)
Some receivers (like my Onkyo 606) support HDMI passthrough, but will not decode audio signals from HDMI. Making it a pretty useless port!
Do you get sound when you select FM Tuner on the Pioneer?
Posted on Dec 02, 2008
I've had a Pioneer receiver hooked up to have surround sound and I have used this to play music throughout my house in bedrooms, to play Blu Ray and TV which have all worked fine. I had a guest in my home...
go through the input modes its one of them leave it each mode on for 30 seconds what output do you have for audio on the blueray. It can also be setting for audio from blueray was turned off swich to fiberoptec
Mar 04, 2015 | Pioneer Audio Players & Recorders
How do I hook up a Pioneer VSX-918V receiver to Sat.Dish box?
For the audio portion, you must have either a digital coax, optical connection or analog L/R composite RCA jacks plugged into the "Sat.audio in" on the rear panel of the chassis. The other end of THAT connection must come from the "audio out/ variable out" from the T.V. or from the Sat.Dish box.
Sep 12, 2014 | Pioneer VSX-918V Receiver
Pioneer vsx 519v
Are you sure the correct input is selected on BOTH the TV AND the A/V receiver?
Does the subwoofer work on other inputs? If not, is the subwoofer connected correctly? If so, is the input connected correctly?
Jan 31, 2014 | Audio Players & Recorders
Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
CaRC not working on my vsx823
With some of these elaborate setups, the receiver overrides your settings and connections to configure a default arrangement for certain functions. The rationale for this is often buried obscurely in the equipment instructions. You may have to resort to trial and error, connect and disconnect to get a satisfactory result.
Dec 01, 2013 | Pioneer Vsx-821-k Receiver
Cant get coaxel wire to give me sound
You need the remote to turn the coax input on or off and assign it to SAT, DVD, CD, or MD/ TAPE 1.
Press the receiver button on the remote then use the < > buttons 'till coax appears in the display. The up-down or center cursour buttons should turn it on-off, and I think the < > buttons assign coax in to the source you want to use it with. You wound naturally want to assign it to the same source as the video signal if it coming from a dvd player or sat receiver.
Jan 09, 2010 | Pioneer VSX-D508
No TV sound, only DVD and CD players
Check your tv settings may need to change from speaker out to line out.
Check the tv input on the receiver, put the cd or dvd cables into the tv input. If you get audio the receiver is fine. No audio check the receiver settings.
Nov 16, 2009 | Pioneer VSX-54TX Receiver
No Sound on TV/SAT setting on Receiver.
Most TV has Audio Out RCA jack at rear and it gives same TV Sound as coming from its speakers.
Hook audio wire red white RCA pins at TV Out and plug these pins to TV/SAT input of receiver. Select TV/SAT input in receiver to get TV program sound coming out from TV.
Hope that info will help you.
Sep 15, 2009 | Pioneer VSX-D509S Receiver
No television sound from denon avr-3000
TV has Component input (Green,Red,Blue) connect as follows:
1. Connect Component Video and Audio cables from the Cable box, PS3, DVD or Sat box to thea Component Video and Audio input on the Denon (TV/DBS, DBS,VCR1 VRS2, VDP or DVD).
2. Connect a Component Video cable from the Denon to the TV Component Video input.
3. If you do not have a cable or sat box and have a cable from the wall to the TV you must take an RCA(Red&White) audio out of the TV to an input listed in #1
Nov 21, 2008 | Denon AVR-2106 Receiver
VSX D511 No input select
I am getting no sound via my optical cable input. The back of the AMP says that the optical is TV/SAT but i can't change the input to digital it will only go to analog. DVD player is set to Bitstream all dvd options set to DTS, but still no sound going through. Any help would be apprecaited
Jan 29, 2008 | Pioneer VSX-D511 Receiver
Velodyne CT-80 Subwoofer Logo
112 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
