Question about Sony TA-E9000ES Amplifier
Sony output problem
Hi, I'm having a problem with my sony deck. Ok my amp turns on when im playing it on tuner and then when i click source to change it to CD the amp power light will turn off i have no power then. So too sum it up i cannot listen to my sub on CD and i can with the Radio. Thanks for any help Jared.
All i did was mess with the REM wire, and found out i had to hook the REM wire to the blue/white wire on the deck. Instead of the blue/white wire, i had it hooked up to the solid blue wire on the deck which was preventing my amp from playing on CD.
Posted on Nov 23, 2008
Sony XM-GTR4A
contact sony .... or check your head unit is recieving
Mar 29, 2014 | Sony Car Audio & Video
Sony Mini Hi-Fi Systwm shuts down at high volumes
You need to have the fan in the check,possibly its not working anylonger
Jan 22, 2014 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Ive got the sony set up to a denonm38 it plays but no sound.cds and tuner work through speakers but not tape deck.i havnt played a cassette for quite a while maybe ive overlooked something
Are you sure you have pressed the tape monitor switch or button on the amp or receiver? The Tape Monitor switch is the most common failure in amplifiers and receivers provided the tape deck is hooked into the correct place on the back of the unit. The tape decks outs go to the play in on the amp and the Record outs go to the tape decks inputs.
Nov 04, 2012 | Audio Players & Recorders
I have a Sony Amplifier [model TA-AX380] and other components of CD player [model DCP-C40], AM/FM Tuner [model ST-JX380], FM Stereo/FM-AM Receiver [model STR-AV570X], and Stereo Cassette Deck [model...
http://www.servicemanuals.net/ServiceManual/SONY/TAAX380/148547/detail.aspx
http://www.hifiengine.com/manuals/sony/str-av570x.shtml
Hi above are links for manuals, these may help..
When one wires up anything it is all usually color to color output to input... usually RED & WHITE stereo audio.
Now we would start with our Tuner this the CD player, & Cassette deck, will wire into the Amp's INPUTs , red - red & white - white, these go into the Stereo INPUTs on the AMP... 1, 2 & 3 and be selected via the input selector on the AMP.
Now after all these in's and out's are wired we need to wire our speakers, this too is simple, locate the outputs on the Amp, and wire accordingly, Plus to Plus and Negative to Negative... each speaker has two wires a Plus, + & a Negative -
All will/should be clearly marked and it will be easy to do. You will need patch leads, one set each for each unit, these will be a pair of cables, usually Red & White with RCA jacks on each end, as related these go color to color from the RCA OUTPUTs Sockets, of the signal suppliers, ie: Tuner, FM stereo & Cassette deck... these ALL will wire into the Main Amplifiers INPUTS, usually at rear of unit, and clearly marked, after this is all done, then as related again now connect the Speakers, again the OUTPUT on the Amp will be clearly marked, as output and + & -, + & - (two sets), one for each channel.
Now each INPUT is selected ON the AMP, and it's output will then be directed to the speakers attached to the Amp..... Just wire and test one at a time, and i am sure you will prevail.
Hope this helps.
Jun 20, 2011 | Sony Audio Players & Recorders
Sub doesnt kick on when put cd in only comes on when turn on radi
I had the same problem, but in my case it was a factory amp.
The blue wire on the deck harness is for a power antenna, and only powers up when the tuner is in use, not in the cd or aux mode. Therefore if you are using the blue wire (on the adapter or car side) to power the remote power on your amp, you would need to connect that blue wire (on the adapter or car side) to a keyed power source. This way the keyed source supplies power when the key is on, and will not cut out when the mode is changed from "Tuner" to "CD" or "AUX".
I just connected to the keyed source on my radio harness, but then, I am not running any kind of system, just the basics.
Jun 03, 2009 | Sony CDX-GT210 CD Player
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
Sony cdx ca650x has no audio output from tuner, CD is OK
Tuner might be defective , check to see if tuning voltage varies
Nov 03, 2008 | Sony CDX-CA850X CD Player
Connect 5 piece Sony seperates stereo system
OK, this is pretty easy to do. First connect your leads from the component outputs(i.e., tape, cd, phono, etc) to the recievers corresponding input for the device. Then connect the recievers outputs to your equalizer, if it is a seperate eq. Then the outputs of that to your amplifier, then your speakers to that. Be sure all of your wires are connected with the proper polarity. These instructions may be a little different for your exact setup but basically follow the same order minus any device you dont have.
Feb 03, 2008 | Audio Players & Recorders
My amp works on tuner but switches off when i change it to cd
The remote turn-on wire from your amplifier is connected to a blue wire behind the head unit. That's a power antenna activation wire, so the amp only turns on when the tuner is on. Switch it to a blue/white wire from the head unit instead; that should be the amp remote turn-on output.
Jun 16, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony TA-E9000ES Amplifier Logo
125 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
