Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
Hard drive motor just cant get a full head of steam going
This is now the second hd that has the same problem in this past month. When I turn the drive on to boot up, i can hear the motor start, but then it stops and starts again, sputtering trying to get up to speed and it never does. One drive now doesnt even try anymore and the other one just started and I'm afraid that it will completely die on me soon.
What do you think?
Vern
  • LaCie Master
  • 19,396 Answers
When the motor and the heads start getting noisy, clicking and whirring, and the hard disk access time gets abnormally longer than usual, that means that the disk can fail at any time.
Better saving all your data and get a replacement drive.
If this happened on two Lacie and they did not receive any shock, then call Lacie to complain : Contact Support
Posted on Nov 23, 2008
Oreck Steam-It diagram?
You have probably already found the solution, but I've had this problem as well. The steam head has a hard plastic tube that directs the steam and disperses it across the head. This tube breaks and the result is what you are experiencing. The last time this happened to me I drilled out the tube and glued a new tube in the hole and reattached the flex tube. But this is only a short time repair. I couldn't find the part sold separately and we had to purchase a new steam head. Hope this helped
Oct 02, 2013 | Oreck Steam-It Steam Wand
1995 geo metro running issues
a GM suzuki swift.
G10 or G13 engine? both are EFI no carbs here, in USA. 95.
last carb usa 1994 Isuzu.
OLD gas goes bad clogging that Injector or if MPI ? injectors.
Old spark plugs cant burn old gas, like a double bad effect.
give a tuneup> last decade?
Nix, that sEA-Floam, use Chevron, Techron injector cleaner
its got the REAL clearer called Benzene, costs more but is MORE.
all that said , i never use additives. (snake oil ever)
after all cleaning and injection system correctly is hard work.
so I offer this comment based on, (fast and dirty fix)
sure, ISC dirty, they love to jam parked for a year.
EGR and PCV gasses, there form gunk,
Gunk cloggs, ISC, valve, (electric) idle speed valve
i cant drive car, see if right for overcomes a dead isc easy
if the lower RPM is from MISFIRE< i can hear it and feel it.
and Misfire has over 50 causes, spark plugs bad tops the list.
when it wont start to the operator guide , stated unflood method work. cranking wide open throttle, work?
I bet the PCV is clogged to. valve
steam, is a whole other matter, non of which is good
do a hard leak down test?
new head, was it milled (shaved) or put back not checking
for warp-age like the Service manual directs?
warped head bust be de-warped using baking oven.
Ask your machinist this is knows this very well on alumin, heads.
Id work steam issue, hard and not drive too far, like that,
Most heads replaced, DIY fail.
for 2 reasons,
not dewarped, and not surfaced correctly and other reasons.
Mar 04, 2017 | 1995 Geo Metro
Hi, I have 2 Hard Disc Drives on my laptop, one of them is full and I want to all my future downloads to go to the free hard disc drive, is this possible? If not am I abe to transfer some stuff from the...
move the download file to the empty drive.........
highlight the file click edit at tope left............go down to move to folder then find spare drive in new window.........
after check spare drive for your files ..
job done
cheers
Apr 04, 2011 | Computers & Internet
Alright this may sound big but I have a windows vista hp operating system installed on my #1 hard drive. I am getting the blue screen error, and no longer cant fix it, so as in it's done. I bought an...
Make an clean installation of Win 7 and repartition your Hard disk.Use Genuine Windows 7 to avoid blue screen error.AVG 2011 is a very good antivirus.Use Hard disk sanitizer given in Bios settings.Use Tune up utilities 2011or System mechanic latest version.I think your problem will be solved
Dec 23, 2010 | HP Pavilion DV7-1020US Laptop
Hi! I have a Rock Mobile External 250gb hard drive that I have reformatted for my MacBook Pro computer. I have used it for about 6 months now. One day I noticed when I turn on the power it took longer and...
Its in your logic board controller issue, usually the problem is like that but to see what is the another problem of your External Drive is to make or use any diagnostic freeware program to identify the device where it really connected in your PC. I have also encountered like your problem but I send my External to Electronic Tech to check the power connection and controller connection going to PC. Because you said that the hard Drive is still have a normal sound then it is working then but cannot see in your Computer. Try to Diagnose first before you bring to a Technician. Good luck!
Jul 29, 2009 | Computers & Internet
LaCie d2 Quadra 500 GB HD dropped, now makes strange chime/alarm
Modern hard drive motors can easily become seized after an impact. The only DIY solution I am aware of is the use of a heat gun over the back of the drive motor. The build up of heat within the motor is sometimes enough to free it.
If the drive was running the problem may be due to a phenomenon known as "sticktion" where the drive head is actually stuck to the disc surface. If this is true then you need a data recovery company.
Nov 19, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
I have a iomega mdhd500-ue for about past ten months.when switched on it useually whirls into action but now it is just making a repeated clicking sound and it is not connecting to my laptop
I have a MDHD500-N Iomega external HD that had the same issue - clicking at startup and flashing power LED. I noticed that the supplied power transformer for the unit is 12V 1A and the sticker on the HD enclosure says 12V 2A. I hooked up the HD enclosure directly to a power supply - at boot up, the HD draws 2.5A, more than double what the provided power transformer can output. HD enclosure runs beautifully on an external PS.
Sep 01, 2008 | Computers & Internet
Simple tech 500 gig external drive
the interface has gone out, these portable drive are horrible i have 2 go bad withing months of each other.
theres not much you can do beside taking out the drive and buying another enclosure and putting it in the drive in that enclosure.
so replacing the enclosure is the only option, since the device is out of warranty. just pry open the enclosure and remove the HD, and then buy another enclosure, add the HD to it. the problem is solved.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jul 20, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Bad Hard drive
if your HD don't had a head crash you will have a chance to copy your data to a new HD.
You need exactly the same disk with exactly the same controll PCA revision. Take a look at ebay or a second hand dealer.
In case you get one, built the new contoll PCA into your dead HD.
Be very carfull about foil cables and connectors between the HD case and the PCA.
I had a similar problem with a blown motor driver chip in a Maxtor drive and changed the PCA. All worked fine and I could save the data.
Good luck !
There are also companies who are specialized for data recovery but the are very expensive.
Jul 13, 2008 | Computers & Internet
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
94 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
