Question about Maytag 24 in. MDB4651A Built-in Dishwasher
SMALL LEAK IN MAYTAG DISH WWASHER # MDB7130AWW
At the bottom, left side of the dishwasher, just to the left of the main electrical connection is a micro switch. A white pin moves the rocker piece which activates this switch. Water is seeping down the white pin. How do I fix this?
jsrock516
  • 5911 Answers
SOURCE: Leaking dishwasher
Are you washing cereal bowls or mixing bowls on the bottom rack? If so, are you placing them in front? Sudden leaks that form huge puddles can often be attributed to improper loading of the dishwasher. Most dishwashers don't have a seal across the tub front. The door closes over it and does a pretty good job of deflecting water back inside the wash cavity. However, if you place bowls in the front on the bottom rack rack they can divert the water right over the tub lip and onto the floor. This is usually the culprit that causes most leaks in dishwashers. Now, if you don't think you have a loading problem, remove the kick panel on the bottom of the dishwasher and check the drain line and pump housing for leaks. Check the door gasket for tears or cracks. Lastly, feel inside the bottom of the door with your hand. You should be able to feel the door insulation. If it is wet, then the problem could be a leak around your soap or rinse-aid dispenser. Depending on the model, some dispensers are mounted to the door with a gasket behind it. Sometimes this gasket can form leaks. I hope this helps.
Posted on Jun 05, 2007
  • 1462 Answers
SOURCE: Maytag Quiet Series 200 Dishwasher Leaking Internally
two possible sources of water
either
inlet valve leaking. turn water off after use and if no water accumulates, then cause is leaking valve
or
if drain is plumbed in to a spigot on the sink trap, then every time you empty water from the sink, some of it goes down to the washer
cure by taking the drain hose up as far as possible under the sink in a swan neck
Posted on Oct 12, 2008
rickzilla
  • 706 Answers
SOURCE: water standing in Dishwasher
Hello buzzy220,
If you have water remaining in the bottom of your dishwasher then I would check the following:
  1. The drain filter screen is free from food byproducts that might limit drainage.
  2. The drain line exiting the dishwasher itself.. is it kinked or clogged?
  3. If your drain line is plumbed into a garbage disposal side entry, is that clogged or your house drain clogged?
  4. Is your dishwasher pump contaminated with sediment or anything that would limit its ability to pump?
  5. Are the water lines that come into or out of the pump blocked, damaged or restricting water flow?
Those are the main reasons areas of concern to investigate.. BTW, your drain line exitting the dishwasher should be routed up high and down into your sink drain system or thru the garbage disposal tap so that you have an air gap as 20YRSEXP was inquiring about..
You can run a simple test to verify all this..
Detach your drain hose from the house drain system ( from the garbage disposer or sink drain.. then route that into a rubber barrel ( be sure to keep part of the house up around the height of the countertop when you do this.. )... You should see a fairly robust flow of drain water into it when the system functions properly.. I would encourage you to run this test with no dishes inside it,.. This test will tell you if the restriction is in the dishwasher or house drain side..
Hope this helps you..
Regards,
Rick
Posted on Nov 29, 2008
localwonder
  • 6784 Answers
SOURCE: Maytag Dishwasher Leak
HI. this is a inlet assembly issue. The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow. There are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. If your valve has two solenoids, test the second one in the same way as the first.
If the solenoid is working properly, but water leaks through the valve even when the dishwasher is off, then the valve itself is the problem. Debris may be preventing the valve from closing. If the valve cannot be cleaned, it will have to be replaced. The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
***(((NOTE-- It i possible that the valve housing has cracked as well. make sure that the hoses are connected properly during your testing. If there are no hose issues, this will be a defective valve assembly)))
Posted on Sep 12, 2009
  • 220 Answers
SOURCE: Maytag MDB5100AWB Dishwasher not draining
More than likely the filter is clogged,remove the spray arm(there is a threaded cap in the center of the arm twist it to the left,then remove the # 15 or 20 torx(star shaped) screws out of the filter cover(around the edges)The filter is round and runs around the outer edge of the pump housing it lifts right out,clean it and reverse the process.It's the most common issue with not draining on this model.
Posted on Sep 26, 2009
Testimonial: "The solution from TomZS was precisely what I needed to fix my Maytag washer. Thanks a million!"
Over-level water error
The sensor is on the outside of the unit on the left side. slide the unit out of its location, taking care not to pull apart the fresh water hose, drain hose or electrical wiring, the sensor is on the left side, a small clearish plastic box with a rubber hose connected to the bottom, it's probably filled with crud which blocks the plastic float from moving up and down, the float covers and uncovers 2 small electric eyes, carefully remove the box and clean the crud out with an old toothbrush and it should work find, did for mine, good luck
ps, try not to soak the 2 small electrical pc boards on the sensor, if they do get wet, dry them well before reinstalling
Dec 18, 2013 | Samsung DMT300RFS Builtin Dishwasher
How to fix leak in miele dish washer g1202 svi has F70 fault and small leak into catch pan
The reason the pump keeps running when F70 fualt appears is that the water leak circuit has tripped which causes the dishwasher controller to empty the dishwasher to avoid flooding of the motor and pump area.
The sources of leaks could be many, to start with hoses and water inlet valve. If you feel you can handle such repairs then go ahead otherwise call a technician.
Make sure the mains power is turned off when you are working with the dishwasher internals.
Aug 10, 2012 | Miele Dishwashers
How do you remove the bottom spray arm?
Hello
Unplug the dishwasher. If you cannot access the plug, turn off the dishwasher's circuit breaker in the electrical circuit breaker box to stop electrical power to the dishwasher.
Open the dishwasher's door, and pull out the bottom dish rack. Set it aside.
Hold the lower spray arm still with one hand. Turn the retaining nut clockwise with the other hand until it comes free. Pull the spray arm up and off the shaft.
Sep 12, 2011 | Maytag Dishwasher
Connecting electrical cables to dishwasher
you should be able to take the cover off at the bottom front and you will see on the left side a small metal box and this will be the electrical connection
Jun 27, 2010 | Bosch 24 in. SHE43C05UC Stainless Steel...
Small amount of water covering bottom dishwasher-won't drain
YES IT IS WATER FROM DRAIN HOSE LEFT AFTER PUMPING OUT THE MAJORITY OF WATER AND IS LEFT IN HOSE.
Mar 10, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
Model MDB7130AWW: Repeats the wash cycle non-stop.
Control timer is more than likely to have gone bad not continuing cycles as you state then the control has gone bad and will need to be replaced.
Dave
Jan 08, 2010 | Maytag Dishwashers
Favorit 43070 vi leak
I assume that this leak is from the flat tank on the side of the machiene. Any water leak to the bottom of the machiene puts the washer in ANTI FLOOD mode with the pump out motor activated. You can remove the flat tank by disconnecting the hoses to it and pulling it upwards. If you find a small leak just run it over with a hot soldering iron to melt closed the small leak. Also note that this tank has a small outlet pipe that deliberatly discharges water to the anti flood device (polystireen float / micro switch at the base of washer) in case of a fault (blocked pipe / leak etc).
Jun 07, 2009 | AEG 23 in. Favorit 44070Vi Built-in...
Dish drawer leaks Fisher Paykel
When water accumulates in the bottom it triggers an error code and it keeps running. There is a water sensor in the bottom. I pull out the bottom drawer, mop up the water and use a hair dryer to dry the water (the more you mop up the less you need the hair dryer). Be careful to not get any of the plastic too hot. Kill the power before messing with the unit. The first time I did this it took 20 minutes to dry out. I have gotten more proficient and it take about 5 minutes now.
I had a water leak which was due to the rinse agent cap not being completely sealed. Water leaked out of a small hole in the front (I'm guessing an air vent but don't know for sure) and flooded the bottom.
I also had a leak due to having too tall a dish in the drawer and the top not sealing. I currently have a leak on the top drawer of unknown origin, but the bottom drawer still works.
Hope this helps.
May 15, 2008 | Dishwashers
Maytag 24 in. MDB4651A Built-in Dishwasher Logo
76 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
