Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
Not all of the soap dissolving, some left in dispenser and bottom
KitchenAid KUDS01DL dishwasher, 5 years old
problem started suddenly, rewashed with more det, soap still not dissolved.
Dishes aren't dirty, as far as I can see. checked water temp - over 120 degrees
Is there a filter I need to clean out? If so, it doesn't say so in my use and care booklet.
Thanks
  • 24 Answers
Kitchenaid lists 130 dishwashers with this model. Need the rest of the number
KUDSO1DLxxxx
Back in the day, when I worked on K Dishwashers, the drain valve was the problem typically.
It would get a piece of glass, from broken glass or other item, or a toothpick, whatever stuck in the drain valve. It would not completely close. During the wash cycle, water would be trickling down the drain and by the time the soap dispenser opens, the water would be gone or nearly gone.
Check this. When you hear the dispenser snap open, stop the dishwasher and open the door.
If you have little or no water, you are losing the water during the wash cycle.
Let me know.
Gary
Posted on Nov 22, 2008
The soap dispenser opens & the soap tablet (power ball) drops to the bottom but doesn't dissolve
1. Water temp is wrong should be 140-145
2. spray arms clogged with food
3. water valve is not letter the correct amount of water in
after it fill's check to see water amount in bottom , dose it sound like it is starving for water ? it would sound like it was surging
Dec 01, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Soap stayes in dispenser
The water in the tub isn't hot enough. Make sure you have 125 degrees going into the unit otherwise the soap will not dissolve.
Dec 11, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher starting to leave soap film on dishes. It is a 2 year old Kitchenaid. Cleaned filter, no changes in our soap or water.
First check the salt dispenser located at the bottom of the machine under the bottom rack,make sure it is full,then also check the rinse aid dispenser is full and adjusted correctly,in the rinse aid dispenser it will have numbers turn the dial to about number 2 this is average
Dec 30, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher detergent "pacs" dont disolve anymore
Try reversing the bottom dish rack, it's likely blocking the dispenser door because it's put in the dishwasher incorrectly. Also check if there is anything in the back of the rack preventing it from going all the way in.
Apr 05, 2009 | KitchenAid KUDU03FT Built-in Dishwasher
Suds residue left on clothes just washed
ck drain hose end of drain hose should be at least 36 ins from floor also be sure drain hose fits loosely in drain water may be siphoning out resulting low water level to wash/rinse ..also recommend using liquid detergent dry doesn't dissolve good in cold water and even though it may be recommended for front load the lower water levels used may not be enough to dissolve it properly
Nov 27, 2008 | Washing Machines
Soap is in the dispenser after dishwasher has been run
You need to clean your particle screen under the heating element. It is found at the bottom center of the washer under the heating coil. It is usually a plastic mesh screen and sometimes are removable. This needs to be cleaned really good about every 2 months. This will stop the problem with the suds. Good Luck This Should Help!
By the way I see that you soap won't dissolve this is not because of water temperature it is that the jets in the washer arm are clogged. You need to clean these one by one with a small cleaning device and brush. When these clog the jets of water don't come out with any force they just trickle. Clean the jets(on the arm that spins at the top and bottom of the washer and your screen and it will be like having a brand new washer.
Nov 23, 2008 | Maytag 24 in. DWU9202 Built-in Dishwasher
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Nov 06, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
No water coming in - soap is dry
Check for power at fill valve when it is supposed to fill. If power, check filter in valve. If not clogged replace valve. This is about the only repair I would make on a machine this old. They are really not designed to last more than 10 years. The new ones are much quieter, efficient and clean better. The fill valve should cost around $25 and you can easily replace it yourself.
Jul 05, 2008 | Dishwashers
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
527 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
