Question about Gateway Computers & Internet
WHEN I TURN MY LAPTOP ON IT FLASHES 2-3 TIMES WHAT CAUSES THIS
  • 105 Answers
Perhaps some connected devices, turning on with little delay, and using (in a flash) power from the central unit.
it happens less frequently when windows is almost loaded, ( after the windows colored logo disapear or as it disapears)
Posted on Nov 22, 2008
I have a sony Bravia 32" LCD it has stopped working. When I turn it on it comes on and then shuts off. Red LED continually flashes in pulses of 2. Any advice? Mark
HI,
LED BLINKS 2 TIMES
Indicates there is some problem in power (POWER-DET)
Causes
missing 12V line on Power Board .
Check points and remedy
Replace Power Board 1.
www.electro-medical.blogspot.com
Sep 09, 2015 | Sony Televison & Video
I have a 1994 plymouth voyage se and it will not strat. It tell me to check gauge light comes on. what should i do or what does that mean?
Turn key to on ( not start) then off, then on, then off, then on and leave on, and have a pen and paper ready to record flashes of "check engine light". It will flash then pause between second number of 2 digit code. Then a short pause and flash again, pause, then flash. For example: if it flashes 2 times, then pause, then flashes 2 more times, that would be code 22. If it flashes 3 times, pause, then flashes 5 more times, that would be code 35. As I said, there will be a short pause between 2 digits, as well as after number. Write them down as they come up and get back to us with those codes for advice. When you get code 55 ( 5 flashes, pause 5 more ) that means end of message. Those codes should point everyone in right direction of trouble spot.
Jul 31, 2011 | 1991 Plymouth Grand Voyager
I have an intermittent power-on issue with my Dell E4200. Sometimes it is very hard to turn on - pressing the power button makes the button light up, the fan runs for a few seconds, then the caps lock icon...
Try performing a hard reset on the laptop. Remove the battery and all peripherals connected to the laptop (including the AC adapter). Once everything is removed/disconnected, press and hold the power button for around 15 seconds. This will drain all remaining charge in the motherboards capacitors which usually causes this kind of issue.
Hope this help. Goodluck!
Mar 28, 2011 | Dell Latitude E4200 Notebook
I replaced the main board in my sony Kdl-32S300. When turn on power, the back light flashes 3 times then goes into standby mode after which the standby light flashes 12 times in sequence. What could be...
B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Have you set the output voltage correctly?
Mar 24, 2011 | Sony KDL-32S3000 32 in. LCD Television
My Toshiba laptop battery light flashes 6 times but wont turn on? Dead battery?
Most laptop battery can be normal used in 400-500 charge and discharge cycles, in another word, a laptop battery should be normal in 2 year.
maybe your laptop battery is dead....
you should buy a new one.
here is the replacement toshiba laptop battery online shop for you to consider to buy one there:)
May 23, 2010 | Toshiba Satellite A205-S4617 Notebook
Compaq nx6110 PC Laptops: When i turn it on the lights flashes then goes off...
Which light flashes? If it is the battery light then perhaps your battery is empty?
When plugged into your PSU does the power light turn on? If not your PSU may have broken or the plugs fuse may have blown.
Other potential causes could be your RAM, CPU or even your system board. Check the RAM is correctly seated, if two modules are installed try removing one.
Hope this helps, www.PuterCare.com
May 17, 2010 | HP Compaq nx6110 PC Laptop
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
Turns on when cold and works fine for thirty seconds, then starts clicking in the back and picture goes out. Then tries to turn on and then just clicks off again. Continues to cycle like this, but never...
Pls check error code by counting the front LED flashes. Below is the list or error code and values;
0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty. 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted. 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode. 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped. 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small. 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture. 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board) 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board) 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
Dec 26, 2009 | Sony KP-43HT20 43" Rear Projection...
Wont turn one, power light flashes 3 times
I will need more information here but it seems that either the battery needs a charge or the power adapter has failed.
2. or the unit is in the sleep or hibernation mode.
Sep 29, 2009 | Compaq Presario CQ60-220US PC Laptop
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
Computers & Internet Logo
32 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
