Question about Ovens
Finding parts for La Germania- Explorer Oven
The new house we purchased has an oven marked La Germania- Explorer. The model number is A95C61x. The heating element that goes around the convection fan does not work. We need to get a new element for the oven. We also need the electrical schematic for this oven. We have extensively searched the web for this information and have been unable to successfully find much. Any help you can give us would be great.
  • Conrad Public Mar 01, 2013
    My La Germania range (model V95C 31 X) was made by Bertazzoni and sold in the US in 2002. I was able to get it serviced in 2013, but I had to email the Bertazzoni service department in Italy (Service@bertazzoni.com). The Bertazzoni distributor in the US (us.Bertazzoni.com) would not talk to me about my La Germania range, but the Bertazzoni service people in Italy were great. They helped me find a local service person, find find the correct part numbers for my La Germania range, and find a parts supplier through whom I could order the parts. They even sent me a PDF user's manual for my range, and helped their local parts supplier enter new parts into their system so that I could order them.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
The distributor for LaGermania in North America has gone out of business. However, parts can be ordered directly from the manufacturer in Italy. A contact that worked is: Daniel Pedrazzini
Customer Support
BERTAZZONI S.P.A.
phone +39 0522 226415
fax +39 0522 226440
e-mail: dpedrazzini@bertazzoni-italia.com.Note that shipping will be expensive, but it is still much less than buying a new stove.Also, I have found a model sold in Australia that is very similar in features to the models that were sold here, with the exception that they don't have a separate burner lighting button. Here's a link:http://sampfordixl.com.au/lagermania/upload/LUEP01-90-S._W1883_%28A.pdf
UPDATE: (January 5th, 2018)
Unfortunately, the Australian distributor no longer carries the La Germania line, and has removed all La Germania related information from their website. I uploaded the manual I had gotten from the above dead link and also the parts breakdown drawings and parts list that were sent to me from the parent company in Italy, Bertazzoni. This parts list can be used to order parts from Reliable Parts, which is a U.S. distributor of Bertazzoni parts, and they can order the La Germania parts using the parts numbers from this list by contacting their Bertazzoni reps and getting the Bertazzoni part numbers where they differ.
Here's a link to the directory that contains this information on a Google Drive. Using this link you should be able to browse, view and download the documents:
https://drive.google.com/drive/folders/1dYHsPsU-_WZ71kR4nLobiv7thY-lJV2t?usp=sharing
A few notes that may help people when repairing these 1990's La Germania branded stoves:
1. These La Germania branded stoves are well built and worth repairing. They are the same quality and similar build as the stoves currently being sold in the U.S. under the parent company's name, Bertazzoni. After replacing two burned out oven heating elements (see below) in mine in 2008, it has been operating flawlessly for over 10 years -- pretty good for a 1990's dual-fuel stove.
2. Some of the electrical elements can be replaced with domestic parts. For example, I took the burned out circular convection oven element to a local used appliance store (used appliance stores often have appliance repair departments) and was able to match it up exactly to a used convection element they salvaged from a domestic stove. Unfortunately, because this was a salvaged part, I was not able to determine the make and model of the "donor" domestic appliance, otherwise I would have posted it here. However, their technician assured me that it was a commonly available part. You just need to match up the dimension of the round element (both diameter, and depth) and make sure the wattage rating is about the same -- in my case the one I found was exactly the same, including the support brackets. Since in the U.S. oven elements are 220-240V rated, they will work in the La Germania (and Bertazonni) ranges. While I was at this used appliance store repair department I also looked for a replacement for the burned out lower oven element. Unfortunately I could not find an exact match for the lower oven heating element as I had for the convection element. However I did find a used domestic lower heating element that was approximately the same dimensions and wattage, and the end with the connectors very closely matched the original element, and so could be mounted and connected up exactly as the original element had been. I had to extend the two front support legs on it by about 1/2 inch, but that was easy to do with some scrap aluminum flat stock and a small bolt, a washer, a lock washer, and a nut to hold the extension in place.
I attached this extension to the bottom of the two V-shaped wire "feet" that were already welded to the front of the used element I had found. These two wire "feet" were welded at the top of the "V", so, being attached to the bottom of the "V" the extension wouldn't get the full heat from the element. This reduction in direct heat allowed me to use easier to cut and drill flat aluminum stock instead of using much harder to cut and drill flat stainless steel scrap stock. (I would not have trusted aluminum to withstand the heat of direct contact with the heating element.)
Because I was able to find workable domestic used parts, the total cost of repairing both elements was less than $20. It would have been far more costly just to have had factory replacement parts shipped from Italy.... I also was able to do the repair immediately instead of having to wait for the parts to arrive.
WARNING!!!! If using non-factory elements it is EXTREMELY important that you pay attention to closely matching the wattage of the existing elements. Putting in lower wattage elements will result in slower warm up times for the oven, and putting in higher wattage elements could be an EXTREMELY DANGEROUS FIRE HAZARD because the element would burn hotter than the stove was designed for and could potentially cause a fire due to this, OR it could cause a fire due to overloading and heating up or burning the supply wiring inside the stove because it wasn't rated to supply that high a wattage/current. WARNING!!!!
I realize that this kind of mix-and-match parts finding is not something that a person without some good DIY skills and experience would be able to do. However, competent professional repair people can and do use quality generic replacement parts all the time for out-of-warranty repairs -- they just make sure that the manufacturer is known for their quality and the wattage is an exact or very close match, and thus maintain the engineering and safety integrity of the stove.
3. Regarding getting factory replacement parts for these La Germania branded stoves:
While the parts can be ordered directly from Italy, I was quoted more than $100 just for shipping to get the parts I wanted shipped direct from Bertazzoni in Italy. Because La Germania and its parent company Bertazzoni produced very similar products, a great many of the parts were shared. Because of this, a Bertazzoni U.S. parts distributor like Reliable Parts will be able to supply many of the wearing parts (elements, burner caps, hinges, door seals, etc.) from their existing Bertazzoni stock. They would just need to contact their Bertazzoni representative and ask for the cross-matching part numbers between the two related companies when the part numbers differ. The U.S. parts distributors order a lot of parts at a time, possibly by the container load, which drastically reduces the cost of shipping for each individual part. So, if you aren't the experienced DIY type person that can work with matching and using domestic replacement parts, or just want to stay with the original factory parts -- attempting to get replacement parts through a U.S. Bertazzoni parts distributor could save you a lot of money (and time). I know this to be true because I researched getting the parts through Reliable Parts prior to discovering I could find and use domestic replacements.
4. The oven light bulbs for these stoves are hard to find, and expensive in the U.S. because of their shape and voltage. I was quoted between 8 to 10 dollars per bulb (not including shipping). However, if you do a search on a site like Ebay, you can find these bulbs for a lot less, even when considering the shipping cost. If you can wait for 2-3 weeks you can get a pair of these bulbs for about $2.50 from China or Hong Kong, including shipping. If you want to order from the UK to get quicker shipping, you can find them for about $8 for 2 including shipping. Just do a search for "25W 220V oven E14" or "25W 220V 300C E14" and you'll find them. Make sure they are high temperature rated (300 degrees Centigrade.) You can find them on Amazon as well, but I only saw Chinese suppliers listed (a 3-4 week shipping time usually indicates a Chinese seller).
Posted on Nov 09, 2009
  • phreich Jan 06, 2010
    Update: It turns out that Reliable Parts (look them up on the web) can also get these parts for you and it may save on shipping. They are an authorized distributor for Bertazzoni parts, and Bertazzoni is the parent company of La Germania. It will take some time for them to research the parts and get a price as they will have to contact Italy with your model and serial number and get back to you with the part number and price.
    Good Luck!
Looking for parts for La germania oven cooker
Posted on Apr 28, 2009
My La Germania V95C7LX is 3 years old. I have not used the range nor the oven yet so it is still "brand new". I want to bake but can't use the oven because I cannot find my manual. Can you...
I cannot locate an online manual, but there is a Contact Us page on the WEBSITE which you can find a location to call and see if they can send you another owners manual or at least give you instructions. The only thing is that they are all located in Italy as far as I can tell. This looks to be an "Italy Only" appliance.
Hope this helps
Joe
Sep 02, 2011 | Ovens
My oven is brand new, id tried it earlier, but its not functioning, how can i operate my la germania oven
CHECK the POWER CONNECTION PROPERLY. IF IT IS ANALOG TYPE OF OVEN TURN AROUND YOUR TIMER KNOB.
Aug 06, 2011 | Ovens
I have an SL100 - 10W La Germania table top oven (gas) I did not receive a operations manual with purchase of the oven and I do not understand its operation. Questions 1. How does it maintain the set...
I GOT THE SAME QUESTION .. IT IS A GAS OVEN . WHEN THERMOSTAT IS SET TO GAS MARK 4 WHICH IS EQUIVALENT TO 350 DEGREES , AFTER 10 MINUTES, IT REACHES ITS DESIRED TEMP. BUT IF I DON'T ADJUST THE FLAME, THE TEMP WILL RISE HIGHER AND HOTTER THAT I NEED TO OPEN THE OVEN DOOR TO DECREASE THE TEMPERATURE INSIDE. ANYONE KNOWS IF THAT IS NORMAL? THANKS12_1_2012_3_54_19_am.jpg
Oct 26, 2010 | Ovens
La Germania oven won't stay lit. Stove is 10 years old and problem just started. It will light, but goes off after a few seconds.
Use a good air gun to blow off dirt inthe regulator. dirt in the nozzle and the burners.
Use a good brush to assist, or a thin metal wire to push through the gas passage .The air mixing section must be fitting correctly wedged.
Sep 11, 2010 | Ovens
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Ovens Logo
2,313 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
