Question about 3M MP 7630AV Multimedia Projector
Problem in 3M MP 7630 Multimedia Projector
Hi I need Help!!! Please, when I turn "on" the projector(3M MP 7630) using the remote or the power button on the top of the projector, the power led starts blinking ORANGE and thats it. The projector does'nt start. my lamp is used for only 490 HRS.
2 Suggested Answers
  • 6966 Answers
SOURCE: 3M Multimedia Projector
Hi Sue, On your first concern, a possible reason for the 'Sync is out of range' is because your laptop's resolution is just too high for the projector to handle. You may have to manually lower down your screen resolution (right click on a clear area of your desktop, click on properties, settings tab, move bar of screen resolution towards the left). Try different settings that will give you best performance without the projector rejecting the input signal. Am not sure about your second concern though, offhand your description sounds like video noise. You may have to check that your connectors are firmly plugged in. A longshot is to remove any possible source of interference like wireless phones including your mobile, WiFi AP and the likes. Perhaps you give the first suggestion a try and see if the purple dots disappear when you have the projector running ok. Further you may have to reset your projector if it's got one. Normally it's a small button clearly marked RESET somewhere at the rear of the unit. Hope this works out for you. Pls comment/post back should you need further information. Good luck and kind regards.
Posted on Aug 11, 2007
  • 2236 Answers
SOURCE: my 3m s20 projector has a big yellow spot
the polarizer on the blue lcd panel is fried due to excessive dust and heat. you may have to replace the whole optical engine.
Posted on Jan 27, 2010
0 characters
1 Points
It projects green.
check your connection settings to your computer, or check your cable connection attached to your laptop..
Mar 31, 2011 | 3M MP 7630 Multimedia Projector
I have purchased an used MP7630 projector. How do you start running an MP7630 projector. Do I need software for it as well the leads.
You should just require the leads as when you plug your pc into it if the resolution is set correctly, will produce a picture.
Jan 06, 2011 | 3M MP 7630 Multimedia Projector
clean the dust out of it with canned air and make sure the fans all spin. the dust keeps in the heat that the projector is trying to expel.
Jun 27, 2009 | 3M MP 8640 Multimedia Projector
When turned on the projector has a pink spot in middle of the screen with old lamp and also with new lamp. 3M model number MP 8630
you have a fried polarizer on one of the lcd panels due to excessive dust and heat. may need to replace the whole optical engine.
Jun 04, 2009 | 3M MP 8765 Multimedia Projector
Manual for 3m mp 8730?
your projector is the exact same as the hitachi cp-x950w/e. as a matter of fact, hitachi made the 3m mp8730.
Apr 26, 2009 | 3M MP 8730 Multimedia Projector
hmmm...have you connected with 3M on this unit? If it's registered, they will issue you a new password.
Aug 20, 2008 | 3M MP 8640 Multimedia Projector
PASSWORD in how to undo the password?
Aug 20, 2008 | 3M MP 8610 Multimedia Projector
Lamp will not power up
Hi there
Are any of the indicator lights on the Projector flashing ?
Sounds like your Projector might be in need of a new lamp !
Apr 06, 2008 | 3M MP 8640 Multimedia Projector
Liesegang DV 610 / 3M MP 8610
Mar 07, 2008 | 3M MP 8610 Multimedia Projector
3M S151 Projector for the classroom
You will need to have a dvi to vga converter. If you have a Macbook, it is a mini dvi to vga. You can get this adapter direct from Apple for about $20. A wireless connection is not available with this model projector.
Dec 01, 2007 | 3M MP 8640 Multimedia Projector
3M MP 7630AV Multimedia Projector Logo
52 people viewed this question
Top 3M Multimedia Projectors Experts
Jorge Luis
Jorge Luis
Are you a 3M Multimedia Projector Expert? Answer questions, earn points and help others
