Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Spacemaker oven, Model JVM240
I noticed that surface light bulbs were not working, so I replaced each one (they were blown). After replacing bulbs I depressed keypad for surface lights controls, but lights will not light. I also noticed that vent fan will not operate when depressing keypad control for vent fan. All other features and microwave work and operate. I turned main fusebreaker for microwave off and then on, but did not cure problem. Any ideas? Thanks
  • OldBoy Nov 01, 2007
    Exactly the same thing just happened to me. I replaced the bulbs, which worked fine for a little while-- like, a day or so-- and then they began to flicker. Next thing you know, they went dead. No response from the keypad, even with brand new bulbs. No light at all. The vent fan has also ceased working.
    Timer works, it cooks, just no illumination or fan. What's next...?
  • Anonymous Mar 30, 2014
    SURFACE LIGHT WILL NOT WORK
  • GE Master
  • 9,149 Answers
That would almost certainly be a problem on the control circuit board. If the bulbs happen to short / blow out or if they are removed or installed while the microwave is still plugged in, there is often an arc which causes damage to the board. We repair regularly these boards for such problems for $32.50 nationwide.
Posted on Dec 25, 2006
  • William Miller
    William Miller Nov 05, 2007
    The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
    This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
    This often can affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on.
    If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
  • Ben Rajabi Dec 27, 2011
    I have exact same problem. They are not making a replacement control board. Would you be able to fix my old board?
GE replaced one circuit board with the identical part no. under warranty - when it failed again they refused to repair it again (after the warranty period). By the way I can still use mine by repeatedly pressing the "add 30 seconds" button.
Posted on Apr 26, 2010
Don't buy GE!
Posted on Feb 03, 2008
I have a similar problem, however, the microwave does not function either. could this only be a board problem?
Posted on Jan 06, 2008
4 Suggested Answers
  • 579 Answers
SOURCE: Ge Spacemaker microwave - Model # JNM1851
They sometimes have a plastic cover over the bulb cavity that you can take off from the oven interior
Posted on Jan 02, 2008
MicrowaveSvc
  • 9149 Answers
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
MicrowaveSvc
  • 9149 Answers
SOURCE: GE Microwave Keypad or Control Panel
If some pads on the keypad are not working, then you have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
On this model, the cover will have to come off to replace the light bulb. If it's mounted in the wall, it will have to come down.
The installation instructions are nice to have in this case. You can download GE owner's manuals and installation instructions here.
I have attached a drawing to show where the bulb is on this model. It is located on the right side of the oven next to the wall of the cooking cavity.
The bulbs are available in local grocery stores, hardware stores, and stores like Wal-Mart and Lowe's.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 27, 2008
Changed the light bulbs in my ge jvm315 and know the surface light will not turn off ?
This sounds like the control board also called a smart board in some models has to be replaced.
May 02, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Over the range Danby Model dom16a1wdb surface light replacement
a screw at the back side when removed get access to the bulb.Usually 40Watts bulb with1/2 " threaded
Mar 28, 2014 | GE JVM1790SK Convection/Microwave Oven
Ge lvm1750dm1ww microwave
<-- I see and repair this problem on a regular basis. Details are here.
This failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line, as the warning label near the light socket advises.
This causes a failure on the control circuit board.
The lights can can be inoperable, or stuck on, or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
You can get it your smart board repaired or order a replacement part number WB27X10935 here.
Whether you choose repair or replacement, the first step is to remove the controller assembly.
Here
is a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
If you choose repair, do not disconnect the keypad connector and do not remove the board screws. Leave the controller assembly intact.
Feb 16, 2014 | Microwave Ovens
My microwave heats, but the surface light and interior light don't light up and the turn table doesn't rotate. Everything else seems to be working fine. What is the best way to trouble shoot the problem?
follow this steps and fix it. God bless you
  • Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#6#ixzz2gUUt9D8f
    Sep 30, 2013 | Microwave Ovens
    Kenmore Microwave/Vent Model 721.80042 - External light will not turn off after bulb replacement
    If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
    If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
    God bless you
    Apr 02, 2013 | Microwave Ovens
    Relace bulbs ge spacemaker model JVM164OCj02 light that illuminates cooking surface of stove
    That model would be JVM1640CJ02.
    That is covered on page 33 of your owner's manual.
    If for some reason you don't still have yours, you can download it here.
    Always be sure you unplug power before you remove or install bulbs in a microwave.
    Otherwise you may need circuit board repair.
    You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
    Oct 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
    Replacing surface light
    That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
    Cooktop Light/
    Night Light
    Replace the burned-out
    bulb with a 40-watt
    incandescent bulb
    (WB36X10003), available
    from your GE supplier.
    1 To replace the bulb(s),
    first disconnect the power
    at the main fuse or circuit
    breaker panel or pull the
    plug.
    2 Remove the screw from
    light cover and lower
    the cover.
    3 Be sure the bulb(s) to be
    replaced are cool before
    removing. After breaking
    the adhesive seal, remove
    the bulb by gently turning.
    4 Replace the screw.
    Connect electrical power
    to the oven.
    Oven Light
    bulb with a 40-watt
    incandescent bulb
    1 To replace the oven light,
    plug.
    2 Remove the top grille by
    taking out the 2 screws
    that hold it in place.
    3 Next, remove the screw
    located above the door
    near the center of the
    oven that secures the
    light housing.
    to the oven.
    May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    Light bult in a Microwave oven is burned out.
    There should be a panel covering the bulb iside the cookspace with a screw holding it on. Remove screw, cover then bulb.
    Oct 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    GE Spacemaker JVM1640SJ Microwave Oven Logo
    1,771 people viewed this question
    Top GE Microwave Ovens Experts
    vince
    D. E. Hev
     Larry
    Larry
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
