Question about Gateway M275 Tablet PC
Gateway Pen Drive .... not recognized on Windows XP
Have a Gateway 2.0 USB pen drive and trying to use it for the first time on Dell Desktop running Windows XP. The computer doesn't recognize it. Does it need formatted on the gateway laptop first? Does it need formatted on the Dell? Have used the USB port before for camera. Any advice is appreciated!!
  • 1 more comment
  • Anand Srinivasan
    Anand Srinivasan May 11, 2010
    @rickyostrom: Dude usb 1.1 has nothing to do with this prob... it is just a pendrive and with a usb 1.1 port the device will be configured to have a maximum speed of 12Mbps...
    is the pendrive recognised in other systems??? is ur dell desktop usb port recognising other devices....
  • Ricky Ostrom
    Ricky Ostrom May 11, 2010
    The Dell port your plugging it into might be a USB 1.1 and not a USB 2.0 port.
    Did the USB Pen come with drivers?
  • Vincent Wright
    Vincent Wright May 11, 2010
    Does the gateway recognize the pen drive?
  • 152 Answers
@rickyostrom: If the drivers is not present then there would be a pop up to say that the hardware connected is malfunctioning... the user is saying his device is not being recognised... i dont think the usb protocol is the reason of the problem...
Posted on Nov 23, 2008
    Sergeant:
    Champion:
  • 274 Answers
@Enquiry: It's a USB 2.0 pen drive, which might not backwards support USB 1.1 without drivers. Many computers have USB 1.1 out one end of the case (back) and USB 2.0 out another (front).
Posted on Nov 22, 2008
  • Ricky Ostrom
    Ricky Ostrom Nov 22, 2008
    Can your give me the model number of the Dell?
How do i get the pen an tablet to calibrate
Assuming you are running Windows XP Tablet Edition:
Go to Control Panel Select Tablet and Pen Settings Tap the Calibrate Button
Follow the instructions.
There should be a similar Tablet control in the Control Panel for other versions of Windows.
Apr 19, 2011 | Gateway M275 Tablet PC
I want to write pen with toshiba portege tablet on XP
If you have Windows XP tablet PC Edition 2005 installed on it, you can use the Wacom Pen to enter text instesd of type it.
On Windows XP tablet PC Edition 2005, there is an Input panel Icon on the tray bar, usually to the left, close to the Start button.
Use the pen to click the Input Panel. When it opens showing you a black line on yellowish backround you can start using the pen as if it were on paper. Depending on the pen input setting it will insert automatically or waits for you to press the insert button.
However for the converted text to be inserted you need to have a text editing software open (Word Pad for example.)
If when you open the input panel you see a keyboard you can change that to handwriting (continuous line) or typing separate letters.
The computer can be taught to recognize your handwriting: You will need to practice. You might have to download and install the relevant ink recognition package for your language. Look for it on the Microsoft tablet PC page.
Mar 26, 2011 | Toshiba Portege M700-S7002 Tablet PC
I got my system, windows xp c drive formated and due to which i lost a tool(though i saved the folder in f drive and installed again but now not telling the system "genuine") windows xp validator.Actually...
Either you didn't 'activate" your copy of Windows XP in the time alotted; which is usually 30 days, or the copy of Windows XP that you used to re-install on your computer is not a legitimate copy. If your copy of Windows XP isn't legitimate, then that is likely the reason for it telling you that it's not "Genuine".
Aug 17, 2010 | Xplore Technologies iX104C2...
Any time i insert a flash drive into my system usb port, the system does not recognize it
try it in another PC...if it reads there then
format the flash drive in another PC and then try in this PC....
else
could be a problem with device drivers.
Right Click My computer.
Select Properties
Select HARDWARE tab from the properties dialogue box
Select Device Manager.
Now Search for Universal Serial Bus Controllers.
Reinstall the driver.
else
the next option is to remove and again insert the pen drive and let it install it so that you can browse it. Do cancel at the time when it displays you found a new hardware
pls leave a feedback...
reg
May 10, 2010 | Toshiba Satellite R10-S802TD Tablet PC
I cant use the pen. the hard disk is changed so now i cant use pen and the keyboard doesnt appear in desktop
you change the hard disk you lort thr driver's chek the old hard disk for driver's,you will find the driver's in: windows/system32/driver.cab
Jan 17, 2009 | Gateway M275 Tablet PC
Fujitsu Stylistic 3500 Pen calibration in XP Tablet Edition
Well there is a few ways to try to fix it first with a usb mouse check that the resolution is at it's native pixel count. This can be found on the manufacture website. If it is already at that resolution ensure that the CIC XPen drivers are installed. Those should have placed a recalibration program in the control panel. If those both fail, try uninstalling the drivers and restarting, then reloading the drivers. Hope this helps! food luck and godspeed!
Jan 11, 2009 | Fujitsu Stylistic 3500 Tablet PC
Will a Bamboo Pen work on a Toshiba tablet pc M200
^The question is NOT asking about a USB thumb drive, and a lot of people seem to have failed to understand this.
This is a comprehensive forum thread regarding digitizers that work with Penenabled Tablet PCs: http://forum.tabletpcreview.com/showthread.php?t=12695
I don't believe Bamboo pens work.
Dec 26, 2008 | Toshiba Portege M200 Tablet PC
How to use the pen
Using the pen is quite simple.
You extract it from its storage space and use it as a mouse, left clicking it as you would a mouse.
By pressing the tip of the pen on an area on desktop or on an application window and maintaining the pressure for a short while, you activate the context menus (the equivalent of a right click.)
On the Windows task bar (for Windows XP) there is a small icon near the start button that shows a pen pointing outside: that is the input panel. Click the icon with a mouse or your pen, and an input area opens. In that area you write with the pen (writing Pad) or enter letters and symbols one at a time (Character Pad) or use a virtual keyboard.
Under the red X that closes the input panel there is a small gear. C;ick the gear with the pen or a mouse to configure the settings.
Your pen may have an eraser at the rear end and/OR on the side. It is used to erase characters or whole sentences.
To actually record (write) what you enter with the pen you must have a text-editing application open and running.
Whenever you approach the pen to the screen near a text-area (search area of IE or other compatible applications) a small icon appears to be clicked to enter text. This happens is you select UNDOCK in the input panel configuration.
This should get you started with the pen. Try these steps, and if you have any other questions post them as comments to this thread and it will be my pleasure to answer them.
Nov 30, 2008 | Toshiba Portege 3505 Tablet PC
Pen problem
to connect yo,r pen in usb port and anotner one solution is to uninstal your usb drivers in yo,r devicemanager and restart your system then connect your pen
May 08, 2008 | Fujitsu Siemens LifeBook T3010 Tablet PC
Gateway M275 Tablet PC Logo
478 people viewed this question
Top Gateway Tablets & eReaders Experts
ashburton
Ricky Ostrom
Ricky Ostrom
vojvodabudva
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
