Question about You Software You Control 1.01 (cme73002)
Digital photo album3.5 unable to view memory card
I follow Copy the photo instructions on pg. 18 and when I get to select memory card press ok to start file show it says "no photo file"There are 451 photos on the memory card . what do I need to do ?
  • 849 Answers
Copy the photo's only with recommended format. it will not recognize any other format.
Posted on Nov 24, 2008
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
How can i get photos from my Internal memory to my S.D. card? can't see an option on the menu and can't view photos from the internal memory whilst there's the memory card in it.
Put the card in the camera. Press the Playback button (right-pointing triangle). Yes, you won't see any pictures from the internal memory with the card in. Press MENU/OK to bring up the playback menu. Use cursor-up/down to highlight "Copy" and press cursor-right. Press cursor-up/down to select "INTERNAL MEMORY TO CARD" and press cursor-right. Select the desired option and press MENU/OK.
Full details are in the "Copy" subsection of "The Playback Menu" section of the manual (page 70 in my copy). If you need a manual, you can download one at
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/a/finepix_av100_manual_01.pdf
Sep 13, 2011 | FUJIFILM FinePix AV100 Digital Camera
Hi am able to view my pictures on my camera, but am unable to copy them over to my system, i can see the pictures saved on the camera, but not on my memory card. please help
Follow the steps to move your pictures on your PC.
1- Turn on camera.
2- Press Menu.
3- Go to Memory Stick Tool
4- Copy and select OK.
5- All the pictures on the camera will be copied at memory stick.
6- Turn off the camera.
7- Insert your memory stick in any card reader.
8- Connect your card reader with your PC.
9- Copy all the data from memory card to PC.
And the job is done.
Hope this will help you.
Thanks.
May 14, 2011 | Sony Cyber-shot DSC-W80 Digital Camera
How do i switch photos from internal memory to a memory card
Hello and Welcome to Fixya!
To switch the photos
from internal memory to a memory card follow the given steps:-
  • Insert an SD card into your Kodak V570 camera.
  • Press the "Review" button on the back of the camera and navigate to the photo you would like to copy, then press the camera's "Menu" button.
  • Select "Copy" from the available options and then press the 'OK" button on the back of the camera. Navigate through the available options by using the arrow keys on the back of your camera.Select "Picture" from the list of options that appears to transfer just one picture. Select "All" from the list of options to transfer all of the photos from your camera's internal memory to an SD card.
I hope this solution helps you
For Further assistance, I am here to help
Thank you and Keep Visiting FixYa
Apr 19, 2011 | Kodak EasyShare V570 Digital Camera
Can't get internal memory full message to go away. anybody know how to get this to go off (aside from erasing the few pix on the cameras memory).
Hello
Basically the only other option is to copy the photos from the internal memory to your computer. Once you have copied it, you will need to delete it.
If you insert a memory card the photos will automatically be saved on the card, and not the internal memory.
You can try the following procedure, but the option is not there for all the models. This will basically copy the photos from your internal memory to the card:
insert card> turn on cam to auto> press review> "reading memory card" > press menu> scroll down to image storage> press ok to select> select INTERNAL MEMORY> press ok
scroll down to COPY> Copy pictures to memory card> scroll down to all> press ok
message to expect: "copying"
Hope this can be of help. Do not hesitate to let me know if you need any further assistance.
Kind regards
Lock123
Feb 07, 2011 | Kodak Easyshare C190 12MP Digital Camera...
How do I delete the photos from my Canon PowerShot SX100 IS 10X Optical Zoom 8.0 Mega Pixels camera?
To delete individual images, press the trashcan button (below the cursor pad) while viewing the picture. To delete all images, follow the instructions in the "Erasing All images" section of the manual (page 153 in my copy). Better yet, format the memory card following the instructions in the "Formatting Memory Cards" section (page 59).
If you need a manual, you can download a copy at
http://gdlp01.c-wss.com/gds/7/0900009927/01/PSSX100IS_CUG_EN.pdf
Dec 08, 2010 | Canon PowerShot SX100 IS Digital Camera
How do I get photos out of my internal memory onto a memory card?
Here are the steps.
1. Insert the card.
2. Make sure that the storage location is set to Internal Memory.
3. Press the review button, once the picture you want to copy displayed in to the screen, press Menu button.
4. Press the down/up arrow to select COPY then Press OK
5. Select where you want to copy the picture then OK.
Note: Pictures will be copied but will not be removed.
Thanks.
Regards,
Neerak21
Sep 24, 2009 | Kodak EasyShare C743 Digital Camera
Erasing the memory card;
All pictures in the internal memory and/or on the memory card can be erased at once. This is accomplished through either formatting or the "all-frame erase" function. I copied the following instructions from the advanced manual, which can be downloaded here: http://www.olympusamerica.com/files/d545zadvman.pdf. Adobe reader should open that file with no problem. If it doesn't, that's another issue altogether.
1. Enter playback mode by pressing the play button.
2. Press the OK MENU button.
3. Press the right arrow button (next to the lightning bolt) to access [MODE MENU]
4. Then, press the down arrow to access the [MEMORY(CARD)] tab.
5. Select the [ALL ERASE] function.
6. Select Yes and press OK MENU.
(You'll need to use the arrow buttons to navigate the menus. Please see pg 16 of the manual for instructions on how to do so.)
Note: when the memory card is in the camera, it will erase the pictures off the card. When the card is removed, the function above will erase the internal memory.
Apr 22, 2009 | Olympus D-545 Zoom Digital Camera
I cant transfer pictures from my PC to a Digital Frame
either transfer to a usb pen or a standard digital card and then insert in photo frame good luck
Dec 20, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
Cannot transfer my internal memory photos into my sd memory card
if you insert the card and it would read the card immediately - not allowing you to see the pictures on the internal, that means the image storage is set to AUTO, you have to set it back to internal so you can copy them to card and just put it back to AUTO to reactivate the card
please follow this path:
when it goes to back the menu screen
scroll to IMAGE STORAGE again and select AUTO> ok> "reading memory card"
you're supposed to see the copy of pictures from your internal and pics from your card if there's any
you can visit www.kodak.com/go/manuals
Feb 10, 2008 | Kodak EasyShare Z740 Digital Camera
You Software You Control 1.01 (cme73002) Logo
98 people viewed this question
Top You Software Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Nikki  Mclean
Nikki Mclean
Andrew Taylor
Andrew Taylor
Are you a You Software Computer and Internet Expert? Answer questions, earn points and help others
