Question about Microsoft Zune JS8-00001 Digital Media Player
Zune 8GB Player
My Zune froze and then shut off. I can't make it turn on again, I tried the reset process but it just wouldn't work. Before it failed, the battery was almost full and it was working fine. I don't know what could be the problem. If someone knows a solution, please let me know asasp! Thanks.
  • 2 more comments
  • kdhard7 Nov 27, 2008
    My Zune just shut off and I can't get it to turn back on. I tried charging it and connecting it to the computer, but still nothing.
  • dbestow Jan 11, 2009
    zune will not turn on any more
  • Anonymous Mar 02, 2009
    my friend got the same problem any idea comme on people think think think :P we cant let this bug unpunished :P
  • chkellball Mar 09, 2009
    same
I'm having the same problem too.
Posted on Nov 25, 2008
Bought a 8gb zune
OK, plug it in for about four hours, and then it should start to work. What has happened is it has frozen during standby mode. Hope this helps :-).
Dec 06, 2009 | Microsoft Zune JS8-00001 Digital Media...
My Zune 4gb won't sync with my software and will not charge
I had a similar problem with my 30GB Zune. The first normal solution is to make sure that the USB port is providing enough power to the Zune to charge it by trying a different port or computer, but since your other Zune charges it is likely not the problem.
Other possibly solutions are performing a hard reset on the Zune (hold back and up until it resets), or allowing the zone to completely discharge and try again. In my case, none of these solutions worked and I was forced to send my Zune in for a new battery, which Microsoft was willing to replace for free.
Jul 29, 2009 | Microsoft Zune JS8-00001 Digital Media...
My 30gig zune is froze and unresponsive. Please help
there is a "lock" button on the top on the left side make sure this switch is turned to off.
Try one or more of these solutions to resolve this problem:
  • The Zune may be locked. Move the hold switch to the unlocked position. It may help to move the switch back and forth. Then press the play/pause button for a second.
  • The battery may be drained.try recharging it
  • To reset your Zune, press and hold the back button while pressing up on the Zune pad. Resetting turns Zune off and on again.
May 27, 2009 | Microsoft Zune JS8-00001 Digital Media...
My Zune froze from using the wrong charger
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
If this helps Rate this a FIX-YA.
Jan 01, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune froze when I turned it on. It is frozen on the Zune welcome screen with the loading bar at the bottom. I have tried the back and up button and it has not worked. I have also tried the back, up and...
There's a fix:
Your Zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the Zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the Zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connector. Your Zune should start up immediately. Press the backing of the Zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
It's an easy process but if you're unsure don't attempt it.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune stopped working and now will not turn on
I figured out the solution by just getting upset.
Hold the Back arrow (<-) and Up on the touch pad and it will restart the Zune. This works for the 8gig and 80gig Zune.
Oct 20, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Reseting my zune
Hold power slider for 10-15 seconds.
User's manual/help here:
http://www.zune.net/en-us/support/usersguide/default.htm
Apr 07, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune wont turn on
I turned on my Zune and the screen froze so I turned it off but it would not turn back on.
I went online and read somewhere that if the screen freezes then you should press up and back and wait for the zune insignia to come on. Well my zune was not just frozen it would not go on but I tried the up and back thing and it worked. it took about 9-13 seconds but it worked so give it a chance and if that doesn't work try charging it overnight. Hope that helps :D
Nov 12, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
After charging it froze up!
I have the same problem, it is completely frozen and will not turn on or off even after I charge it. It appears to be completley frozem, help!
Aug 29, 2007 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Zune JS8-00001 Digital Media Player Logo
212 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
