Question about Pioneer PureVision PDP-503CMX 50 in. HD-Ready Plasma Television
Pink pixels across plasma screen.
I have recently started seeing pink pixels across the screen, sometimes more noticable than others. There are times when I have a beautiful HD picture with out a trace of a problem, then the scene will switch, and I can see thousands of them across the screen about 1/3rd down from the top. I can see them whether if it's HD I'm watching or standard. Sometimes they are barely noticable, sometimes I can even see what I'm watching. Dark scene, bright scene, doesn't make a difference.
  • 2 more comments
  • DaSnotty1 Jun 19, 2008
    I have this exact problem. Mine has been doing this for about three years. It seems that the problem arises (gets warmed up) when a bright solid color is on the screen for a while. The monitor used to have a high-pitched whine as well when there was a lot of white on the screen, but that seems to have gone away.
    Nothing I have tried adjustment-wise has helped.
    Have you had any success dealing with this issue?
  • Rick Gartner Aug 24, 2008
    I have the same problem. Once the screen warms up pink pixels across the top of the screen. This has been going on for about 1 year and seems to be getting worse. Anyone have any ideas?
  • DaSnotty1 Feb 19, 2009
    Everything I have fund out through researching this is that the problem is due to not enough pressure in the plasma.... My problem started during a hurricane. Supposedly, the only fix for this is a new panel. Might as well buy a new TV, it's cheaper. I just bought a 65" Panasonic.... Very nice.
  • azstrider Apr 11, 2009
    I have the same problem. My unit is 7 years old and I just spent $100 for zero help since the problem was not observed in the service center. The problem has been increasingly noticeable for about 3 years.
    It takes about an hour for it to appear and then it slowly increases across the top 1/3 of the screen. This looks to be a heat related problem since it was running a DVD at the service center for over 2 hours and the problem did not show up. The center is kept fairly cool so this may be why the problem was not observed. I went to the center to verify that the problem was not observed after they told me the unit had been running for about 2 hours.
    Do others with this problem have their small top corner fans working correctly? Is there a way to set these to run continuously since this may be related to a heat related problem with the display due to heat build up.
I have the something going on w/mine!!! Are your fans turning on?Mine are not.I think that's my problem...Get back w/me..thanks,jon.
Posted on Feb 19, 2009
  • 65 Answers
Usually it has to do with overheating. I started seeing a small amount on mine after watching a DVD and then a blu-ray for about an hour. It was a small amount but on the right side of the screen toward the top.
Not sure what the solution is though. Most of the heat on mine is right at the top of the screen.
Thanks,
Ced
Posted on Mar 21, 2009
    New Friend:
Had the same problem. Called the TV repair person and they turned up the voltage on the green pixels and it fixed it right away. Took about 20 min to do. Luck I bought extended coverage for an in home visit. But he said it's a common problem on plasma screens and most TV repair people are familiar with it and can do the repairs. Just make sure the person you take it to is an authorized repair person for your brand.
Posted on Oct 29, 2013
Posted on Apr 11, 2009
SOURCE:
Red and pink dots on the screen Samsung plasma tv
I can't see the points on the video. However, I think you are talking about dead pixels. I'm afraid dead pixels can't be repaired.
Feb 03, 2013 | Televison & Video
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
Pink and green diagonal lines rollng across the screen??? panasonic 42" Plasma . Only purchased about 3 years ago - but been used very rarely.
Have you tried lifting the ground on the TV? That set has a grounded (3-prong) plug and sometimes sccrolling lines can be caused by a ground loop in your power lines.Are the green and purple lines very short, like just a few rows of pixels tall, or multiple inches, like 3 - 8 tall?
May 04, 2011 | Panasonic TH-42PZ800U Plasma TV
PINK SCREEN ON DAEWOO PLASMA TV
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
May 09, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Samsung Model: HP-R4262 42" Plasma Problem, pink pixelation/ghosting
Onece the plasma heats up it shrinks a little, i think the cause is that you are low on plasma, so when i heats it shrinks and since the plasma cycles, the area low on plasma wil move slowly around the screen, take this to a repairman and more plasma can be added to it.
Jun 19, 2008 | Samsung LN-R268W 26 in. HD-Ready LCD...
Pixels exposing themselves across my screen. PDP-502MX
If these pixels are always in the same place, then I would suspect the plasma display panel. Pioneer is best known for their "Elite" series HDTV which have great picture quality, but for my money the rest can go to the dumpster. If the pixels change to different areas of the screen, then you probably have induced electrical noise in either the wiring or the circuits. Could be faulty engineering or workmanship. In that case, it could be worth getting it looked at. You may need to display a "static" picture, either from freezing a DVD scene, or getting a calibration DVD to see if these pixels are always visible. If the pixels only become visible after being on awhile, it could be the heat build-up causing a solder connection or semiconductor to act up (this model does use 470 watts of electricity when on, and you know that puts out a lot of heat to help breakdown components). Sorry I can't give you a magic cure, I absolutely refuse to work on pioneer TV's so I'm "out of the loop".
Jan 03, 2007 | Pioneer PureVision PDP-502 50 in. Plasma...
Pioneer PureVision PDP-503CMX 50 in. HD-Ready Plasma Television Logo
2,097 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
