Question about Novatron 1000ws Standard Head with 25' Cable Flash
Syncing Nikon D300 with 600VR strobe system
Does the Novatron 600VR battery pack strobe system produce negative voltage of more than 250 Volts through the sync?  In the past I have used the 600VR with a film SLR as well as with a medium format SLR with really good results.  I would like to use it with my new Nikon D300, but understand that damage can occur if the voltage is too high.  Can I use the old sync cord that I used with the film cameras?  If not, what wireless system do you recommend for this combination of flash and camera? Thanks so much for any advice you have.
  • 22 Answers
A wireless system such as the line of Pocket Wizards is a good choice- the are builr to professional standards and are very reliable.
If you wish to hard wire your flash unit to your digital camera, you can purchase a protector wivh reduces the trigger voltage to a safe level refatdless of the age or design of the flasg system you are goinf to use, Under no circumstances should you use this combunation of equipment without a radio triggering device or the protector, The protector attache to the hot shoe of the camera and provides a standard PC synch cord terminal for connecting your flash system to the camera.
You can test the voltage by putting a volt meter set a 250 or 500 VDC across the synch socket in the flasg unit, If the meter deflects negatively just revers the polaity for a correct reading. If there is under 5 volts there is ptobably no issue, however, I still would take no chasces abd use a radio or a protector. If the falsh won't fire with the radio or protector in place, tha probably means tha the synch voltage is very low.
Posted on Nov 26, 2008
2005 Hyosung GV 250 Aquila not charging
Hi, Manny before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Battery Test:
The battery needs to be a fully charged and load tested to ensure proper readings, connections need to be clean and tight. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test:
Start motorcycle, measure DC volts across the battery terminals you should have a reading of approximately 13.2-15 DC Volts.
3. Connections and wires:
Inspect the regulator stator plug, and check the battery terminals for connection corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC output and resistance test fail and stator test passes then the rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Unplug the regulator plug from the stator start motorcycle and change Voltmeter to AC volts. Probe both stator wires with your meter lead. The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. Reading will vary depending on system, check service manual specification
Generic Specs:
22 amp system produces about 19-26 VAC per 1,000 rpm
32 amp system produces about 16-20 VAC per 1,000 rpm
45 amp system produces about 19-26 VAC per 1,000 rpm
Stator Resistance Check:
Switch your multimeter to Ohm x 1 scale. Probe each stator wires with meter leads and check resistance on the meter.
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on the system, check the service manual for specifications.
Generic Specs:
22 amp system produces about 0.2 to 0.4 ohms
32 amp system produces about 0.1 to 0.2 ohms
45 amp system produces about 0.1 to 0.2 ohms
5. Stator Ground Check:
Probe each stator wire with your positive lead on the multimeter and the negative to ground.
There should be no continuity to ground on either wire.
If there is continuity your stator is shorted to ground and must be replaced.
6. Regulator Test:
Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Battery Charge Lead- Wire going from the regulator to battery positive.
AC output leads- Wires coming from the Stator to the regulator.
Ground- Wire from Regulator to ground or regulator may be grounded via the physical bolting to chassis.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from the regulator body to chassis ground).
Fwd/Reverse Bias Test/Diode Test:
This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
Switch multimeter to Diode Scale.
Place your Multimeter positive lead on each AC output wire.
Place your multimeter negative lead on the battery Charge wire.
The meter should read voltage typically around .5 volts.
Next, switch your multimeter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire. The reading should be Infinite. With your meter on the same setting, place your multimeter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multimeter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires. The reading should be Infinite.
Note: Below is a table to show the readings:
Positive Lead Negative Lead Reading
AC output 1 Battery charge lead Voltage
AC output 2 Battery Charge Lead Voltage
Battery charge lead AC output 1 ?
Battery charge lead AC output 2 ?
Ground AC output 1 Voltage
Ground AC output 2 Voltage
AC output 1 Ground ?
AC output 2 Ground ?
For more information about your issue and valuable "FREE" downloads for viewing or printing that you will need please click on the blue links below. Good luck and have a wonderful day.
2009 Hyosung GV250 Battery not charging Fixxit
http://racetechelectric.com/files/pdf/rte_troubleshooting_flow_chart.pdf
Hyosung Aquila 250 Service Manual
https://www.alpha-sports.com/Parts/H_GV250.htm
HYOSUNG GV250 User Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 16, 2017 | 2005 Hyosung GV 250 Aquila
Cb 250 not charging battery
Hi, Anonymous before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
6. Regulator Test:
Identifying Wires:
cb250 74 charging problems
Honda CB250 Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB250 Nighthawk Owner Manual
Mar 16, 2014 | 1991 Honda CB 250 Nighthawk
How to check stator on honda cb250
Hi, Anonymous before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
6. Regulator Test:
Identifying Wires:
How to test CB250 Superdream stator
https://www.reddit.com/r/HondaCB/comments/4smem7/how_do_i_test_my_stator
Sep 05, 2013 | 1991 Honda CB 250 Nighthawk
Charging voltage to high, cooking batteries and head lights
Hi, Anonymous you may need a new voltage regulator the following is a comprehensive charging system test that I found on a Rider Groups website 1. Battery Test: The battery needs to be a fully charged battery that has been load tested to ensure proper readings. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Most places like Auto Zone, Advance Auto, and Pep Boys will charge and test motorcycle batteries for free. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test: Start motorcycle, Measure DC Volts across the battery terminals (you should have a reading of approximately 13.2-15 DC Volts).
3. Check Connections/Wires: Inspect the regulator/stator plug, and check the battery terminals for connection/corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolate the stator & Rotor, If AC Output test Fails and Resistance Check, and Stator IB Test Pass then Rotor is at fault (Pull Primary covers and inspect rotor for damage).
AC Output Check:
Start motorcycle and change Voltmeter to AC volts.
Probe both stator wires with your meter leads.
The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. (Reading will vary depending on system, check service manual specification)
Generic Specs:
Resistance should be in the range of 0.1-0.5 Ohms. (Reading will vary depending on system, check service manual for specification)
Generic Specs:
Stator IB test or Ground Check:
If there is continuity to ground your stator is shorted to ground.
5. Regulator Test: Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Battery Charge Lead- Wire going from regulator to battery positive.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from regulator body to chassis ground).
Fwd/Reverse Bias Test/Diode Test: This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.jetav8r.com/Vision/Stator/fault_finding_by_www.electrosport.com.pdf
Electrical issue and fault finding chart
Yamaha zeal 250 service manual
Manuals Data Zealous
OEM parts for Yamaha
Dec 02, 2012 | 2000 Yamaha FZX 250 Zeal
03 wr 250 is blowing light bulbs
Hi, Dean the following is a comprehensive charging system test that I found on a Rider Groups website 1. Battery Test: The battery needs to be a fully charged battery that has been load tested to ensure proper readings. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Most places like Auto Zone, Advance Auto, and Pep Boys will charge and test motorcycle batteries for free. Standing battery Voltage should be 12.5-13.2 DCV.
AC Output Check:
Generic Specs:
Generic Specs:
Identifying Wires:
2004 wr250f blowing bulbs
03 WR450 lights blowing
YAMAHA WR250F Owner Service Manual
http://mybikemanuals.com/yamaha/yamaha-wr-owners-manuals
Nov 08, 2012 | 2003 Yamaha WR 250 F
Honda Forza S 250 not charging
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
6. Regulator Test:
Identifying Wires:
Scooter Charging System Check Is It Working
How to test your motorbike battery with multimeter multimeter tutorial
How to test and repair the charging system on scooter
Test Your Battery in 10 Seconds Reliable Load Test with Only Multimeter
Honda NSS250 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda NSS250 Owner Manual
Oct 30, 2017 | 2004 Honda Forza S
Need help in operatingthis pack
You would be best served if you bought and optical slave trigger or a radio trigger for that camera. If the Novatron unit is old enough, the voltage may be too high to use with the Nikon D40. Once you have a trigger, the camera can be used in the Manual mode like your F3HP. the synch would be 1/60th and you set the camera aperture through the control dial.
May 06, 2009 | Cameras
Vivitar 283 with new Nikon Digital camera
the nikon D80 has a 250 volts safe range and i have the same issue but readin on the internet i learned that yo can now the voltage of your flash with a voltage metter ond the hot soe.
Vivitar 283 has diferent ranges of voltages depending on the year of fabrication so older ones can achieve 300 volts and earlier have 230 volts so the best is to get a vivitar 285hv for about 75dollars or a safe sync for about 55dollars, you can find all on ebay or other brouser the safe sync converts up to 400 volts to a safe 6 volts that are yust the normal voltage for digital flashes.
Jan 06, 2009 | Vivitar 283 Flash
Novatron 240 Flash Kit
First you need to isolate the problem by doing some troubleshooting.
1) try a known good sync cord to determine if the problem is the sync cord and not the power pack.
2) try a known good sync cord with a known good camera to determine that the problem is not in the camera.
3) try your camera with a different power pack to confirm your camera is triggering the power pack OK.
These steps will isolate the source of the problem.
Aug 24, 2008 | Cameras
Novatron 1000ws Standard Head with 25' Cable Flash Logo
712 people viewed this question
Top Novatron Cameras Experts
Marvin
Marvin
Are you a Novatron Camera Expert? Answer questions, earn points and help others
