Question about Acer Extensa 4620 Notebook
PCI MOTHERBOARD - Acer Extensa 4620 Notebook
I have an MSI 7529 motherboard with a standard PCI slot, can i install a FX5800 sound card to it? if not, can io change the PCI slot?
Check the sound card to see if it says it is PCI or PCI Express. If its PCO Express you will need a PCI Express port on you motherboard to use this card. Unfortunately you cannot add a PCI Express port to the motherboard. If you don't have you you will need to upgrade your motherboard to use this card.
Jul 29, 2011 | Computers & Internet
Is nvidia 9600gt graphic card compatible with asus p5rd2vm motherboard
1) The Asus P5RD2-VM motherboard has a PCI Express x16 slot.
The Nvidia 9600GT uses a PCI Express x16 slot.
2) The PCI Express version used on the Nvidia 9600GT is PCI Express 2.0
The PCI Express technology used on the Asus P5RD2-VM motherboard is PCI Express 1.1
The motherboard chipset used on the Asus P5RD2-VM shows us this.
The motherboard chipset is an ATI RD480. (Before AMD bought ATI out)
The ATI RD480 chipset came out September 27, 2005.
Scroll down until you come to > RD480 in the left column, then read across.
The PCI Express technology started under another name, then was changed to PCI Express.
The first version was PCI Express 1.0
Then PCI Express 1.1
In 2007 (January 15) the PCI Express 2.0 technology was brought out.
The PCI Express 2.0 technology is Backward Compatible with the PCI Express 1.1 technology.
(With PCI Express 1.0 also, but it depends on the graphics card being used)
In otherwords, a graphics card that has been based upon the PCI Express 2.0 technology, will work on a motherboard based on the PCI Express 1.1 technology.
You won't get the full capability of the PCI Express 2.0 graphics card.
Will you notice?
[ If I had my choice I would run an Nvidia 9800GT instead.
Depends on the price, and availability of the 9600GT I would assume, though.
You may also need a more powerful Power supply.
Example, not advertising, ]
Nov 03, 2010 | ASUS P5RD2-VM Motherboard
What is a pci cummnacation controller
pci means it is the one in the is color white socket..
there you put your pci sound card pci lan card pci usb slot..pci modem it has some times 4 slots in your motherboard...
in your case pci communication maybe refering to your souncard...
Feb 07, 2010 | Dell OptiPlex GX520 PC Desktop
What type and location are the board slots om the EP-8VTAI motherboard. which is PCIe, etc.
Any "modern" motherboard will have several "PCI" slots -- usually "white" in colour, and identically shaped.
The motherboard may optionally have one "AGP" slot (for an Advanced Graphics Port video-card), or one, or more, "PCI-E" slots.
The AGP slot will start FURTHER away from the "back" of the computer than the PCI slots.
The AGP and PCI-E slots will be different in shape than the PCI slots, and not lined-up with the PCI slots.
Dec 28, 2009 | EPoX EP-8VTAI Motherboard
My integrated video is not working may i used any video card in pci slot or agp slot is it poossible
there are three kinds of graphics card
  1. PCI-E
  2. AGP
  3. PCI
if you have an intel motherboard and have a PCI-E slot you can use that if not you my be able to use a spare PCI slot with a PCI gc
If you have an AMD motherboard you can use either AGP or PCI depending on which slots you have
PCI gc's are not particularly common and are generally more expensive and less power full
Oct 13, 2009 | Intel Desktop Board D845EPI Motherboard
Can I My motherboard support a PCI video card?
Hi there.
Your motherboard will support both kinds of Video card.
PCI is quite old and is only supported up to 128MB of video memory.
PCI Express is new technology and is by far the best card that you can buy giving you the best graphics experience and can support up to 1GB of graphics memory making it good for gaming.
Good luck and thanks for using FixYa!!
May 13, 2009 | Intel D101GGC Motherboard
I have a intel D865GVHZ motherboard...wanna install graphics card
From what i can find, it doesnt have a agp (like you said) or pci-express slot so you cant install a pci express graphics card.
You could use a pci craphics card but wont be very good,
If you go for a pci card make sure it isnt pci-e
Apr 16, 2009 | Intel D865GVHZ Motherboard
Server power issues with PCI cards
Have you tried inserting it in a different PCI slot? I understand that this one in not faulty, but obviously the HP isn't getting its POWER OK signal ...
Mar 18, 2009 | HP ProLiant ML110 Server
Tv card & Capture that support intel motherboard dg31pr
The Intel DG31PR motherboard has one PCI-Express x16 slot & two PCI slots. The motherboard also has 1 PCI-Express x1 slot.
You can use any of these slots. I am guessing you are using the PCI-Express x16 as you're primary video display. If you're not using the PCI-Express x16 slot & using the onboard graphics you could use anyone of these PCI-Express x1 capture cards.
For the PCI slot (Two whit in color). Any one of these.
Video capture devices include a learning curve. Do not expect to add one of these into you're system without reading the instructions. (I know little of this format). The PCI-E x1 will be faster than the PCI cards.
I hope you found this helpful!
Good Luck!
Jul 15, 2008 | Intel DG31PR Motherboard
Acer Extensa 4620 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
