Question about Whirlpool RF378 Electric Kitchen Range
Whirlpool Freestanding Range Flashing E1,F2 and beeping!!!
Our freestanding Whirlpool Range will flash E1,F2 and beep.It does it at different times. We press cacel and it goes off. Doesn't seem to effect it's operation
  • 1 more comment
  • Mark Meeker Dec 25, 2006
    It happened it the middle of the night. It was not on, just the clock was displaying the time!Then it started beeping and flashind E1,F2
  • matagorda May 18, 2008
    My display flashes E1 and F1. When I try to clear the code it beeps for about 2 minutes. The cooktop works but the oven does not. When I turn on the oven it flashes and the light blinks telling me to turn off the oven. We had a power surge right before this began happening.
    flashing oven
  • Anonymous Mar 28, 2014
    how do I fix it
    President:
  • 878 Answers
Farkle, outside of Gendos's excellent advice, the issue could be with the keypad. If your model has a keypad ribbon that attaches to the main board, remove it and take a eraser and clean the ends. Then reinsert it. On the board there should be two clips on the end where the ribbon attaches. Lift these up and the ribbon will pull out. See if this solves the problem...Catriver.
Posted on Dec 25, 2006
  • evansx Oct 27, 2010
    E1 -F2- = the keytail (connector ribbon) that plugs into the control board is not making good contact. first unplug your range and then remove the two screws on the underside of the back-splash controls panel to access the back of the control board. now simply cut a slip of heavy paper such as a business card to the width of the ribbon and slide it into the slot along with the ribbon connector. that will help press the contacts on the other side together snuggly. screw the back-splash back in place, plug in your range, and the problem will vanish. if the error ever returns, try pulling out the connector, cleaning the contacts with a pencil eraser (see -http://www.fixyourboard.com/techzone/ove... - for illustration), reinserting it into the slot and repeat above with the paper. good luck.
My oven has an error E1 F5. It was working fine until I tried to use the self cleaner. Now the oven and self cleaner will not work . Only beeps when I try to cut it on.
Hey I found your manual and error codes on-line and was surprised that Whirlpool did not have it hard to reach. Click Here=> Whirlpool 30 in Self-Cleaning Freestanding Electric Range Error Codes
Have questions please ask and rate this solution, Thanks Sea Breeze sea_breeze_128.jpg
or greater.
Error codes are on page 61 section 5-1
Please Rate This Solution, Thank You! Sea Breeze
Mar 27, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
After preheated it beeps and display shows f2
The oven temperature sensor is defective and must be replaced.
Apr 12, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Won't auto clean, after one minute it beeps a few times and puts a E1 F5 on the screen
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@DS
Mar 26, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.T$%^%ETG
Dec 15, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
The oven starts to beep and flashes F2 when the
the f2 is telling you that the tempature is to high. It could be your control board. I personely would call a tech as its got to do with the contacts on the control board or the door lock. can be several different problems.
Nov 06, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Have Whirlpool Electric Range super capacity 465 with accubake system. Turn off power to stove to clean oven and back of stove. Finished cleaning and turned power back on and get this beeping sound every...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^TF
Sep 24, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I used the self cleaning oven and now it wont unlock and it keeps beeping f5, e1 what does this mean and how can i unlock the oven?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&URTGF
Mar 27, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool RF378 Electric Kitchen Range Logo
1,797 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
