Magnavox 32mf605w 17 no picture.
Blinks once when first turned on and goes black,has sound.
  • dctc1 Nov 22, 2008
    Magnavox 32MF605W/17.Blinks once when first turned on and goes black,has sound
  • dctc1 Nov 23, 2008
    Magnavox 32MF605W/17.Blinks once when first turned on and goes black. Has good sound.
  • 42 Answers
Hi..
this is due to a hard fault to prevent from further damage
u have to take it to a service personel
Posted on Nov 23, 2008
  • 4,806 Answers
LCD's inverers are used to channel the dispay just in the same way a latop or lcd pc monitors do, jamie is correct in his diagnosis of the TV because it is to do with the backlight inverter or the inverter coil (this is a coil that is designed to burn out in the event on failure, but not all lcd's have them) this will be a circuit board connected to the screen itself and you can't always tell which has gone, hence to measure the continuity like jamie says.
To replace them is a different story, tracing spares is hard and i would recomend that you call Philips for instuction on how to replace them and how much it would cost
regards
Posted on Nov 22, 2008
    Brigadier General:
  • 6,966 Answers
Offhand, your description indicates that the unit has gone into protective mode, that is to prevent further damage to the circuitry. this is not a firmware glitch that could be corrected by a reset or unplug from the mains. This is a hardware fault and could possbibly be:
  • the inverter board (most likely);
  • the key control board (likely);
  • the CCF (cold cathode florescent) lamps (least likely).
This would require opening the unit for a look and see. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • 435 Answers
It would be the problem that your tv set is having is coming from the power supply board,either
the board is defective itself or some of the components around the power supply boardare defective like a shorted capacitor or a burnt out resistor can cause this kinds of problems. This is why the tv set is turning on and then off because one or more than one component in the power supply is keeping it on protective mode.Moreover try contacting magnavox see if they have this board,if they do go ahead and get it you should be able to change it out your self with the instructions that come with the board.If for some reason they do not have the power supply board,take it to your nearest tv repair shop depending on the tv repair shop it should not be more than 200 dollars or less to get your tv set up and running ,but it depends on the tv repair shop.
  • 2,326 Answers
The TV has an internal failure with the power supply or the back light inverter board. If your TV is less then a year old still under manufacturers warranty.
If you know how to use a multimeter, you should be able to find the board that has failed by measuring the voltages from the power supply to the other circuitry; if the voltages are measuring good then is more likely a defective back light inverter board.
    Genius:
  • 1,847 Answers
Check this link...
http://www.lcd-television-repair.com/
Hope this will help
Kevin.
    Genius:
  • 1,550 Answers
Did you check fuse and inverter .
  • SAM ANDERSON Nov 22, 2008
    Unplug the power chord for 30 minutes and plug back the power chord after 30 minutes this will reset the tv .
    If there is only one blink it indicates there is low voltage as input better have a check over the input power supply to tv .
How to remove magnavox back panel from model number 32mf605w/17 flat screen tv
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Type in the brand name and type of your device, in the search box [at the top right] of the home page; to get the related posts easily.
Jun 14, 2015 | Magnavox Televison & Video
I have a magnavox 32mf605w/17 flat screen TV my sound us not working is there any way to hook up external speakers to it?
Hi Lisa,
Many a times the speakers in flat panel TVs go bad. You either change the speakers or hook your tv to some sound system like a home theater or some music system in your house. There is AV out sockets at the back of the TV. Out of the three ie. yellow, red and white use red and white to connect to the music system, put the system on auxiliary mode and enjoy the sound of your tv. Good luck.
Apr 08, 2015 | Magnavox Televison & Video
My tv powers off as soon as it is turned on, any ideas?
This is an issue that happens with some of the older firmware versions for this tv. You need to check your current firmware in the menue/features. Then go to the philips website and download the current firmware and follow the company instructions for installation via usb.
Mar 23, 2013 | Philips Televison & Video
A magnavox HDTV model 32MF605w/17. Is there a manual volume control on this set that is hidden somewhere? My remote is broken.
ok you have two different model #'s here so i went and found both pdf manuals , i assume the 32mf605w is the one you want though . but here is both
32mf605w link here , just scroll down and type the numbers shown below click download and open with adobe reader , once downloaded scroll down to page 7 , as you can see the controls are on the top of the tv
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
50ml8105d link here , scroll down to page 5 , as you can see the controls are just below the screen in the middle , probably behind a flip out or up door .
Dec 21, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have the same issue with my MAGNAVOX 32MF605W/17 when i turn the power on it flashes white then goes black and the amber standby light remains on.... you decribed it as a Mainboard Problem... my issue is...
I had the same problem caused by a power surge. Removed the back cover (kind of a pain in the *** because it's a tight fit) then removed the metal cover over the circuit boards. There were three 1000uf 35vdc capacitors on the Left board capacitors 2074, 2079 and 2080, that had bulged out tops. Replaced those with the same capacitor from radioshack (p/n: 272-1032 stock at most radioshacks)for $3 and the tv works fine. During this I also noted that the plug right next to the power switch down by the face was loose, pressed that in and everything is kosher...good luck
Apr 25, 2010 | Philips 32MF605W Television
Hi my name is Eric,
I hope I can help you with your issue ,
 You main a bad mainboard, a repairman will charge about $450 to replace it , use google to try and locate one yourself
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
Sep 26, 2009 | Philips 32MF605W Television
Magnavox 42MF231D/17, screen just turned black,
power supply or inverter board failing if the power board is the problem it will have blown caps
little cans with puffy tops because the caps have vented if you don't see that then your inverter has died that model id out of production so try shop jimmy. com
Sep 22, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
Power
power board is damaged, most likely the capacitors are blown on the board service center could help you
Jul 20, 2008 | Computers & Internet
Philips/Magnavox 32MF605W/17 32" LCD Wide Screen HDTV ready w/ATSC.
Yes you can. This TV has both VGA-In and component in support. The only thing you need to change is the input you're using with your remote control. As easy as changing the channel!
Oct 15, 2007 | Philips Computers & Internet
Televison & Video Logo
989 people viewed this question
Top Televison & Video Experts
