Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2005 v-twin fouled plugs
I have a 2005 dyna v-twin with less than 4,000 miles on it. Bought it used last Summer and it seemed to burn oil. this summer I noticed it ran rough and found the plugs to be carboned up. also some oil on the breather tubes that run from the air filter back to the motor. also, some smoke out the exhaust when I first start it. any ideas where to look ?
  • 216 Answers
Fouling can be serious..... or not ....can just be the enricher on to long or worn/bad piston rings. Burning oil and smoking would also indicate bad rings. Could also just be bad plugs. Make sure you got the right ones in there. For $ 4.00 go get new ones at the dealer. Do a compression test - If its OK (over 90 and both within 5 lbs) .... its not the rings. Make sure you have the right amount of oil, and (believe it or not) a weak battery can cause the problems u describe, so check that out as well.
good luck.....let me know how it goes, OK ?
Posted on Nov 22, 2008
I took spark plugs out of 2001 Ford Ranger 3.0L to place plug fowlers in. Spark plug will fit in fowlers, however; fowlers will not fit in engine. Placed plugs back in engine and now will not start.
Sounds like that car is the proverbial POS. Did you check for spark? - need a strong one with a car burning that much oil and the plugs getting fouled like that. Need to replace those rings!
Nov 30, 2015 | Ford Cars & Trucks
Spark plugs foul immediately
Fouled plugs may be caused by oil leaking into the cylinder. Does it smoke when running (cold), are you using up the crank oil. Black smoke is excess gas comsumption, blue smoke is oil burning. If your plug is fouled with black carbon, you are most likely running to rich.
Apr 07, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
I bought a pontiac sunfire 2000, 2.4 twin cam. Bought housing water pump n now the car is throwing black smoke through muffler. Also when I drive mix firing on low speed. It drives great on high speed.
u may hav bad rings or valve guides causing oil to git in the combust chamber burn and foul plugs--watch how much oil is used-may not be that bad cause ok goin fast--try usin a 40 weight oil-called heavy duty on the container---giv that vehicle a detailed inspection before goin hiway--55 and no long trips
Oct 12, 2013 | Cars & Trucks
I have a 1994 Chevy C1500 w/ 4.3 liter and my plugs are fouling out about every 500 miles or less and everything else maintanence wise I've replaced resently. Can someone give an idea on what need
Does the truck run right? Does it smell real gassy, fuel mileage go south? If it is fouling plugs that fast it either has to be burning a lot of fuel or oil. Is there a check engine light on? Engine wore out, burning a lot of oil. Fuel injector stuck, using a lot of gas. Air filter dirty, making it burn way rich. I would think this truck would really smell bad if it is fouling out the plugs that fast.
Jan 21, 2012 | 1995 Chevrolet C1500
I have a 2003 Nissan Morano
your burning oil the plugs probably need replacement ---and the oil can cause fluctuation in rpms ---carbon valves --problems with o2 sensors --clog cat converter-foul plugs etc
Apr 24, 2017 | 2009 Nissan Murano
2005 Kawasaki KX 125 spark plug keeps fouling
Hi, Molokaiboy96 and the usual suspects are:
1. The first thing to do if your spark plug has been fouled is to check the air filter. If it's really dirty, that makes it difficult for air to get through to the engine, causing a rich condition. Either clean it thoroughly with some Air Filter Cleaner or buy a new filter. Before you put it back in the air-box, treat with some air filter oil or spray. "WARNING" adding too much oil can also clog up the filter, resulting in another fouled plug.
2. While the gas/oil ratio doesn't equate to what the jetting is, you can still foul plugs, or worse, if the mixture is wrong. Depending on your bike, it's best to look at your owner's manual for the correct ratio. For most 2-stroke motocross bikes, a ratio is 32:1 or 40:1, the gas being 32 or 40, and oil being 1. For those that don't it, it means that for every 128 ounces (one gallon) of gas, you add 4 ounces of 2-stroke oil for a 32:1 ration, or just over 3 ounces for a 40:1 ratio.
If you have too much oil in the mixture (such as 12:1), then you will probably end up fouling the plug because it is more difficult to burn that much oil. Don't try to cut corners with the oil though, because it's very important for your dirt bike's engine. 2-stokes need the oil for lubrication on the cylinder walls, so if you don't have enough (or any for that matter) then the cylinder walls will run dry, causing it to overheat and seize the engine very quickly. So it's very important that you put in the right mixture pre-mix to your 2-stroke gas tank.
Also, 2-strokes have reeds that air and fuel go through into the cylinder, so if they are cracked or broken the bike will not run right. This could cause the plug to foul, so before you go out and buy anything expensive, make sure the reeds are still good.
3. While this usually isn't the main problem, it could be that your spark plug isn't burning hot enough. Having a hotter spark will ignite the fuel stronger, leaving less residual gas/oil in the cylinder that could cause the plug to foul. This "ISN'T" the best choice, but I'd say it's safe to go one plug hotter than stock. Keep an eye on the plug color you're looking for a light tan color anything whiter and you could burn a hole in your piston. Spark plug manufacturers aren't always the same, so make sure you find out how they rate them.
4. Almost every motocross bike comes rich from the factory (especially Honda 2-Strokes when they were being made). It's usually a pretty simple fix, but many riders are too lazy and would rather continue buying plugs instead of spending a few bucks on jets.
5. Piston rings badly worn or broken.
6. Faulty ignition coil low output.
For more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2003 kx125 fouling plugs
Spark Plugs Keep Fouling
OEM Parts for Kawasaki
2005 Kawasaki KX125 Owner Manual
Jul 28, 2010 | 2005 kawasaki KX 125
Oil fouling out the sparkplug on cylinder #2
with 159k on the clock you should be using 5/40 in winter and 20/50 in summer,non synthetic,as it is more expensive than normal oil.(winter grade is for temperatures less than 0c,helps cold starts)
most modern cars use/burn about a pint every 1000 and that is exceptable,when it uses more than a pint every 250 miles then think about a rebuild....please do not use stop leak unless you are using it to sell the car on or as a temperary measure.
use an engine flush(de gunkes the internals) when you next change the oil and add molyslip.
Jul 23, 2010 | 2001 Ford Windstar
Blue smoke
Blue smoke is never a good thing....
Blue smoke is caused by engine oil entering the cylinder area and being burned along with the fuel air mixture. As with the white smoke, just a small drop of oil leaking into the cylinder can produce blue smoke out the tailpipe. Blue smoke is more likely in older or higher mileage vehicles than newer cars with fewer miles.
How did the engine oil get inside the cylinder in the first place? The car has many seals, gaskets, and O-rings that are designed to keep the engine oil from entering the cylinder, and one of them has failed. If too much oil leaks into the cylinder and fouls the spark plug, it will cause a misfire (engine miss) in that cylinder, and the spark plug will have to be replaced or cleaned of the oil. Using thicker weight engine oil or an oil additive designed to reduce oil leaks might help reduce the amount of oil leaking into the cylinder.
your engine has worn valve guides, piston rings An engine that burns a lot of oil (more than a quart in 500 miles) is an engine that needs to be overhauled. Normal oil consumption should be a quart or less in 1500 miles. Most newer engines consume less than half a quart of oil between oil changes (every 3000 miles). So if your engine is burning oil, it's essentially worn out and needs to be repaired.
Because the cost of overhauling or replacing an engine often exceeds the value of an older car or truck, many people will just keep on driving a "mosquito fogger" in spite of the blue clouds of smoke it leaves behind. Never mind the pollution it causes, oil is cheaper than a new or rebuilt engine they reason. That philosophy may be okay if you live out in the sticks somewhere. But in urban areas that require periodic vehicle emissions testing, an engine that's burning oil usually won't pass the test because of excessive hydrocarbon (HC) emissions. You may get by on a waiver after you've spent some money (in vain) on a tune-up, but the fact remains you're still a polluter.
An engine that burns a lot of oil will also eventually foul the spark plugs. Thick, black oily deposits build up on the plugs until they cease to fire. Then the engine misfires and loses power. Cleaning or changing the plugs may temporarily solve the problem, but sooner or later they'll foul out again.
Forget about "miracle" oil additives or pills that claim to stop oil burning. They don't. Better to save your money and put it towards a valve job and new set of rings.
Feb 23, 2010 | 1990 Ford Festiva
1988 GM 4.3 V6 Using about 3 quarts of oil in 75 miles.
the intake gasket is your proublem it is very comman it lets oil into the cylinders and it burns the oil witch fouls ur plugs
Mar 31, 2009 | 1988 GMC C1500
Oil loss
how much oil is loosing? a lot or just a little be? because belive it or not a little oil losse is normal on engines but not a lot.
May 31, 2008 | 1998 Chevrolet K1500
Lands Phones Logo
105 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
