HP OfficeJet 6210 All-In-One InkJet Printer
Problem for HP OfficeJet 6210 All-In-One InkJet Printer
Using an HP All-In-One of Fax Product on a DSL Phone System
By imaginejwl99 on Nov 22, 2008
one line for outgoing faxes only - rings and rings - will not pick up. How should it be configured?
Comments:
Nov 22, 2008
- No. I only have capability for outgoing fax. One telephone number 248 569-7976. Set up new telephone yesteday to Comcast modem. Have Comcast High Speed Internet and Phone Service. Answering Maching with new phone. Need configuration set-up help. Never had trouble till now sending outgoing fax on my HP Office Jet 6210 All-In-One. Fax will dial up, but just keeps ringing and ringing. Having trouble with OUTGOING fax.
Nov 22, 2008
- I have tried several previously succesful fax numbers - all with the same result ring ring ring - no pick up. The number 248 569-7976 is my home phone FYI. The fax machines I am calling are not turned off I have checked on all of them. I think it is the wiring is configurated. I've spent hours and numurous types of connections - all with the same result. The things that have changed since I began having this problem was connection of a new telephone and changing of my ink cartridges.
Barbara
Clarification Request
Posted by comment on Nov 22, 2008
You speak of outgoing , but refer to incoming.? Which is it that you are having trouble with? The fax you are calling, or the incoming fax?
If incoming, is it set to answer? If not, set the fax answer mode to ON.
Solution #1
posted on Nov 22, 2008
Somewhat Helpful)
comment
Rank: Wiz  HP Expert
Rating: 83%, 54 votes
Have you tried a different number.. It almost sounds as if the fax maching you are calling is turned OFF. You might try a different fax number that you know to see if the results are different. Were there filters provided for the VOIP devices?
Was this helpful?
Yes
No
Popular Solutions for HP OfficeJet 6210 All-In-One
Questions and Unsolved Problems for HP OfficeJet 6210 All-In-One
Do you recommend HP OfficeJet 6210 All-In-One InkJet Printer?
Answer
Answer
The printer cartridges are stuck on the right side of the machine and no longer slide on their own.... (More)
Answer
Scan function says "no Scan Options. You need to install install or run device software."
Answer
My HP Officejet 8500 doesn't allow me to make black and white copies without having all of the color... (More)
Answer
Error: 0xc0620004 - This appeared after a paper jam and I dug in the machine
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
