Question about Brother MFC 240C All-In-One InkJet Printer
How to solvc machine error 50?
Machine error 50
Paper jam
  • kamjam Jan 22, 2009
    Printer is saying there is a paper jamb when there is no evidence of a paper jamb
Main board is HS !!
the print head does not move, the engine is good, it is the component on the motherboard that runs the engine of the print head, which is HS.
I took the motherboard of a MFC-240C with the front panel and I put in the DCP-330C and everything works well. My PC is a MFC-210C ...
Posted on Jan 23, 2009
    Champion:
  • 320 Answers
Sounds like you have print error. if it under 1 year, yyou still have warranrt, then take the machine to a service center brother tech. ps you can not do this by yoursekf!
Posted on Jan 17, 2009
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured
Clean 50 is either Dirty Encoder Stripe or broken Maintenance Unit. In first case clean thoroughly the vertical Encoder Stripe and it should work. In case 2 better exchange the machine
Nov 23, 2015 | Brother Office Equipment & Supplies
Paper jam
You may need to make sure there are no small pieces of paper left in the machine. Unplug it and let it set for about 30 seconds and then plug it back in and let it reset itself. Sometimes a jam can bend some small metal parts and cause it to give an error message. Check for this also. It should clear the error out once unpluged. If it is hardwired into the wall then the breaker will have to be turned off for the same seconds. Hope this does the job for you, all copiers and printers can be a headache when you need them most.
Col. Dana Gillespie
Jul 05, 2014 | Canon IR1022IF 220-240 VOLT, 50/60HZ
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Error 50 of Brother printer DCP-130C
Details of this error code are.
50,51,52,57,5A,5B,5C
5D,5E The machine does not work due to a paper jam or some sensor problem. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us".
May 01, 2011 | Brother DCP 130C All-In-One InkJet Printer
Unable to print 50
Error 50: The machine does not work due to a paper jam or some sensor problem.
See here for illustrated instructions on how to clear a paper jam.
If the problem still continues after clearing the paper jam it could mean a problem with a sensor and you may need to contact a service representative.
For future reference a list and explanation of Error Codes can be found here.
Trust this is helpful.
Jan 04, 2011 | Brother MultiFunction Center MFC-440CN...
Unable to print
I have a Brother MFC665CW and it has error message
"Unable to change 50" after paper jam. Paper is all cleaned
out of machine and still shows message.
cenprop@bigpond.com
Apr 08, 2010 | Brother Office Equipment & Supplies
Brother printer mfc 240 error 50?
this error is due to the machine does not work due to a paper jam.Clear the paper jam or may some mechanism not functioning properly check it ....
Dec 12, 2009 | Brother MFC 240C All-In-One InkJet Printer
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Error message print unable 50
the encoder strip which gives the printhead the position is out of place (error 50). You have to open the printer and reinsert the strip:
http://www.fixya.com/support/t211210-brother_mfc845cw
Stick a 1.5 inch tape onto the printhead cover where the strip runs thru. This will prevent this accident in future!
Nov 05, 2007 | Brother IntelliFax-2480C Fax
HP D155xi - Error Message: Clear Paper Jam (when there is none)
Have an HP office jet d155xl printer and every time I put it on, it takes sometime to warm up then the "scanner failure" pops out on LCD with instructions to put printer off and on again. Same thing happens all over again.
Oct 18, 2007 | HP OfficeJet D155xi All-In-One InkJet...
Brother MFC 240C All-In-One InkJet Printer Logo
1,298 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
