Question about Toshiba 52HMX84 52" Rear Projection HDTV-Ready Television
Toshiba 52hmx84 shutting off
This is my second bulb on my toshiba 52hmx84 while watching it shuts off and try's to start back up. I try to start up but no picture but sound. Shut off again' turn on picture works for awhile what's up with it piece of junk just did it again
  • elliott6969 Nov 22, 2008
    and plays again
When the bulb on one of these Toshiba DLP units burns out, the unit will show a blinking green and a solid red, and restart itself 8 times, then show blinking green and red lights. A replacement bulb costs about $200 and is very easy to replace. If you replace the bulb and the symptoms continue, the problem is probably the ballast. The manual and Toshiba support will direct you to an authorized service center, but if you are ambitious and want to save the expense, here are instructions for replacing the ballast yourself. First, many thanks to those of you who have done this before me and posted elsewhere. There was a request for pics of the ballast board install, so here it is.
FULL DISCLOSURE AND WARNING: YOU ARE ON YOUR OWN AND I WARRANT NOTHING FROM THESE PROCEDURES. I AM NOT A TV TECH. THERE ARE SOME VERY HIGH VOLTAGES IN THE BACK OF A TV BECAUSE OF THE LARGE CAPACITORS. BE CAREFUL. THERE ARE ALSO MANY DELICATE CABLES AND CONNECTORS IN THE BACK OF A DLP TV. PROCEED AT YOUR OWN RISK! IF YOU ARE UNCOMFORTABLE WITH ANY OF THE STEPS, CONTACT A TV TECHNICIAN IN YOUR AREA TO DO IT!
You will need:
1. A slightly long standard head Philips screwdriver.
2. A leatherman or small pair of pliers.
3. The Toshiba service manual. Refer to it often if you get lost. - download it here.
4. The ballast board (Toshiba Part Number: 23122468). I got mine from Conn's in Flordia here.
5. Some tape or a marker to label some of the cables so you don't forget what went where.
The Steps
1. UNPLUG THE TV! Put the TV somewhere so that you can easily get to the back of it. You'll need at least 3 ft of room behind the TV. REMOVE THE LAMP ASSEMBLY NOW.
2. Remove all of the screws on the lower part of the TV. Set the cover aside. It should look like this:
3. To get an idea of where we're going, as you look at the back of the TV, just behind the fan and lamp assembly is the ballast board, looks like this:
4. Next, remove the screws from the silver brace arm in the middle and the bronze screws that hold the light engine assembly. This brace is attached to the ribbon cable by a Zip tie; you do not have to cut the Zip tie if you don't want to. Refer to the service manual if the pic below doesn't show the screws clearly, but it will be obvious when you are looking at the "ltoshiba 52hmx84 shutting off - 9b694bf2.jpgsled".
5. Remove the bronze screw holding the plastic shield that angles down to the lamp. This screw is kind of hard to see just looking at the back of the TV, it is located up and abovetoshiba 52hmx84 shutting off - 18abb633.jpgcable attached to the back AV board.
6. Using a small pair of pliers, squeeze the plastic nipples in and push the cable hangers out of the pltoshiba 52hmx84 shutting off - e7e5f5a9.jpg. Remove the shield carefully from the back of the TV and set aside.
7. Slowly and very carefully, remove the copper ribbon cable as shown. This copper ribbon cable was the hardest thing to put back in during reassembly, I kid you not. I hate that ribbon cable with all of my soul. Next, remove the yellow, blue, and red connectors as shown. Itoshiba 52hmx84 shutting off - fd248cd9.jpg where they went, the connectors are different lengths and only go to one and only one receptacle.
8. Slowly and carefully, pull out the light engine assembly. There are 2 yellow leads that power the lamp assembly that you can remove if needed. To remove them, slide the rubber footing off, and you will see a very small clip, push the clip back while pulling on the lead and it will come off. If you do take the leads off, be sure to label them with a marker or some tape. Mine were quite stubborn in letting go (I didn't see the clips under the rubber footing before this posted), so I left them on. If you do leave them on, be carefull of the stress on the cable going around the letoshiba 52hmx84 shutting off - 8ed15863.jpg I removed the cables from the plastic do-hickey holding onto them and moved the yellow cables to the front of the lens assembly.
9. Next, slowly pull out the light engine sled and turn it so that ytoshiba 52hmx84 shutting off - smile.gifccess to the ballast assembly, like so:
10. Noticing how filthy your ballast board probably is , remove the two screws holding the ballast board.
11. Now, remove the 2 connectors attached to the ballast board like so:
12. Next, gentoshiba 52hmx84 shutting off - 8d8ac6b6.jpg plastic tabs holding down the ballast board to the light engine assembly and gently push up the ballast board to loosen it from the plastic tabs grip. There are two other tatoshiba 52hmx84 shutting off - ee3d4539.jpgher side. Now you'll now be able to remove the ballast assembly entirely to install your new board.
13. Now, on the ottoshiba 52hmx84 shutting off - a92acb87.jpgthe ballast assembly is the lamp connector. Remove the screws as shown.
14. Gently turn the lamp connector towards you to remove it; notice the orientation of the connector so you install it correctly when you put the new board in.
15. Now, install your new board and put everything back together in reverse order. This would also be a good time to take some compressed air and blow out all of the dust in there. Take your time during reassembly and be very, very, very carefull connecting everyting back together.
16. Be sure to put the back cover on, and re-install the lamp assembly before connecting your inputs and powering back on.
17. That's it! If you did everything carefully enough, you should be enjoying your Toshiba again and just saved about $350! Congrats!
Posted on Dec 16, 2008
  • JoeSGriffith Dec 16, 2008
    Sorry, FixYa removed the pictures from the solution after I posted it, so the instructions are not very useful.
Shuts off and on while trying to watch, the power light flashes 30 times when off then the tv comes back on again
Power supply trouble. The TV keeps trying to start then operates for 2 seconds and shuts down. The cycle keeps repeating until eventually the TV will not start at all.
Nov 27, 2013 | Sony KDF-60X5955
Have gone through replacement lamps quite frequently - twice in the last year. Is this common or should we be looking for a contributing cause?
If you have a bunch of dust or per hair on the cooling fan, that would lead to shot bulb life. Also if the power to the set is shut down before the cooling fan is done running it will really shorten the bulb life.
Sep 30, 2010 | Toshiba 52HMX84 52" Rear Projection...
I just replaced the bulb on my 52hmx84 tv and after about 20 minutes the screen started flickering with flashes. I am not sure if there is a problem with the new bulb.
i think theres a defect.in the board causing the flickering and flashes the screen .you nee a qualified technician to troubleshoot the problem in your tv.
Jun 24, 2010 | Toshiba 52HMX84 52" Rear Projection...
ON and off itself every few seconds.
The power light may be flashing or if you are runing with a series light bulb it may be cycling on and off continuously. There may be a chirping or clicking sound from inside the set. (Note: using too small a series light bulb load during testing for the size of the TV may also result in this condition.)
If there is a low voltage regulator or separate switching supply, it could be cycling on and off if the horizontal output, flyback, or one of its secondary loads were defective.
Does this TV have a separate low voltage regulator and/or switching power supply or is it all part of the flyback circuit? For the following, I assume it is all in one (most common).
Some simple things to try first:
Verify that the main filter capacitor is doing its job. Excessive ripple on the rectified line voltage bus can cause various forms of shutdown behavior. An easy test is to jumper across the capacitor with one of at least equal voltage rating and similar capacitance (make connections with power off!).
Use a Variac, if possible, to bring up the input voltage slowly and see if the TV works at any point without shutting down. If it does, this could be an indication of X-ray protection circuit kicking in, though this will usually latch and keep the set shut off if excessive HV were detected.
Take Care.....
May 21, 2010 | Toshiba 52HMX84 52" Rear Projection...
Turns on and off then back on then off
Discovered bulb had blown out.
At power on button, red light and green light flashed and no picture was present. I opened side panel after unplugging tv and let the bulb housing cool, then removed the bulb and discovered it had blown. Luckily I had a replacement bulb from the purchase, replaced it and it worked again.
Oct 01, 2009 | Toshiba 52HMX84 52" Rear Projection...
START AND SHUTDOWN
Hello Mr. Bond.
I believe that you have a rear projection TV where the light from
a powerful halogen light bulb is focused onto a micro-prism
viewing screen through a Liquid Crystal Video Chip.
The light-bulbs have a finite life, degrade with time and eventually
burn out. It is likely that you have a burned out light bulb.
Replacement light bulbs range from about $150 to $250 from
the dealer, depending on the exact model.
The bulbs are somewhat cheaper by mail order from the Internet,
if you can wait that long. Also, some bulbs are available without
the integral mounting bracket, further reducing the cost, but
skilled hands and careful handling is required.
Never touch the glass of a TV light bulb with your bare fingers.
The bulb runs very hot, and residual sweat from your fingers
may cause th bulb to crack and explode.
(use gentle white cloth gloves when handling the new bulb.
I believe that bulb just burned out on its own, and this has
nothing to do with your attempt to connect a DVD player.
On my TV (Sony 60"), a flashing green light indicates a
normal power-up/ bulb warm-up cycle. If the bulb fails to
respond, the TV will detect a bad bulb and shut off again.
Apr 15, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 52HMX84 Sound no picture.
It's not a 1k Resistor but a 10k...it's the resistor R3 on the Circuit Board Part Number RPB-4434ZA (P/N: 23122468). If you don' replace the resistor you will keep burning your lamp. If you decide to replace the resistor by yourself...you should take the time to look at all the on the back of the board. This Board is made by the company Rubicon Corporation for Toshiba and it's a issue on the Toshiba DLP TV (62-52HMX84). If you don't wanna do the job yourself..bring your TV to a repair and give him the part number of the board and ask him to replace the board for you. If the price is higher than $350.00 go somewhere else...He try to fu....^&*%*%&%.
My email address is sleeper773@hotmail.com
Jan 16, 2008 | Toshiba 52HMX84 52" Rear Projection...
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Some tapes will start and immediately shut down
the vcr is on threshold of belt life. try replacing (or cleaning with alcohol) the take-up reel belt. The vcr has a built-in time-out feature to protect the video tape. if it takes too long for things to happen, shut-down occurs.
Aug 30, 2007 | Toshiba M655 VHS VCR
Toshiba 52HMX84 52" Rear Projection HDTV-Ready Television Logo
1,737 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
