Question about ASUS P5GL-MX Motherboard
No display out of asus p5gl-mx motherboard, even i use video card
Suddenly no display is coming out of my video card, i tried to connect the monitor to the built in video output still no display, but it seems that my cpu is booting properly.. what could be the possible cause of this problem? is my motherboard already fried?
  • anoopjawahar Nov 30, 2008
    the system seems to boot properly. But the monitor is not working. the keyboard is also not lighting up. I removed the RAM and switched it on and the processor was beeping. What should i do?
  • ASUS Master
  • 4,806 Answers
Check the memory, then clear the cmos and try rebooting before you think the worst
regards
Posted on Nov 22, 2008
I want to replace vedio card 128k to 512k my motherboard is asus p5gl-mx is it available?
Any PCIE video card will work in the slot provided, although some larger cooled ones may stop you using pci slot 1.
Jul 25, 2011 | ASUS P5GL-MX Motherboard
Hi there,,,, i have my mobo, asus p5gl-mx. i lost my driver disk. could anyone help me please where I can download the driver for my sound, chipset n video card onboard.
Go to ASUS Downloads
Type your model into the box in the upper left. Click Search Info.
When the model number comes up in the large window, click on it.
You must then select your operating system from the drop-down menu.
A list of availble drivers will then be displayed for download.
Thanks for using Fixya.
Nov 15, 2010 | ASUS P5GL-MX Motherboard
I have a ASUS P5GL-MX motherboard. When I turn on the computer I see nothing on the monitor. I had the opportunity to get my keyboard, mouse, monitor and even the memory checked out to make sure they are...
The operation of the onboard video is programmed into the board, so it should work without any drivers being needed. If you verified that the monitor is working then I'd say the onboard video had gone bad. Your motherboard has a PCIe x 16 slot so you can get around the problem by adding an aftermarket video card. The cheapest of them have quality that surpasses any onboard video and they can be found almost anywhere. Follow this link to see some suggestions.
http://www.tigerdirect.com/applications/Category/guidedSearch.asp?CatId=28&sel=Detail;55_158_13067_13067
Oct 17, 2010 | ASUS P5GL-MX Motherboard
No video output. what video cards are compatible?
Your MB takes a PCI Express x16 (max. 2GB/s, x4 mode) video card.
Please note the warning in your manual on Page 1-22 about using "Qualified" graphics cards. Here is a link to your manual:
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5GL-MX/e2222_p5gl-mx.pdf
If you are not getting video, have you tried to reinstall the VGA driver? Just a thought. You can get it by typing your model number into the search box on the Asus support site.(Just use P5GL-MX.)
Asus Support
Aug 29, 2009 | Intel Asus P5GL-MX 800MHz FSB 915GL...
No sound
i have ASUS P5GL MX Motherboard yesterday i installed win 7 ultimate so that i want display driver
Jun 02, 2009 | ASUS P5GL-MX Motherboard
My PC is starting but the monitor is not starting meaning the light of my monitor is blinking on and off and there is no display. So what should i do? Motherboard version=P5GL-MX.
First check your input devices, the keyboard & Mouse. If they are OK, i.e. no bent pins or try a working keyboard & mouse. If the motherboard beeps more than twice then remove the RAM from the slot, clean the contact points. If that too does not work check all connections as snug-tight.Remove all hardware accessories except for the HDD. Use the bootable OS disc and reload the OS..............sodeep
May 12, 2009 | ASUS P5GL-MX Motherboard
ASUS P5GL-MX is not showing display power button is pressed
Pls go through the steps given below...
1. Ensure that the 12 volt 4 pin connector is fixed correctly
2. If there any Beep sounds(Long beep=Memmory complaint)
3. Try replacing or re-installing RAM and HDD
4.Try with another SMPS (Display will not come if 3.3V,5V....missing)
Mar 01, 2009 | ASUS P5GL-MX Motherboard
Memory Issues with P5GL - MX
Some motherboards require that you install the memory in matched pairs. That could explain why they won't work together.
When you put the 1 GB in alone, what slot did you put it in?
I would suggest the blue A1 slot (closest to the CPU).
It may be that you have a bad memory module.
You could try the Windows Memory Diagnostic:
http://oca.microsoft.com/en/windiag.asp
You may also be interested in the motherboard's manual:
Feb 06, 2009 | ASUS P5GL-MX Motherboard
ASUS P5GL-MX Motherboard Logo
163 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
