Question about Toshiba 32A43 32" TV
Sometime Tv gets stuck on a input or menu. Please HELP!
The tv often gets stuck with the menu on screen with no way of removing it. Sometime the buttons on the front of the tv wont work as well. Can I disable the button and just use my universal remote?
  • Rancher1119 Dec 14, 2007
    I have the same TV and the buttons on the front do not work, unresponsive. I have to unplug the TV to make the power shut off, the volume will automatically go to the max, and the channels will change automatically from highest to lowest or vice-versa. Sometimes the "mode" button works, but usually by hitting that button, the channels and/or volume goes haywire. I was going to just buy a remote for it and see if that works.
Unfortunatly the problem sounds like a software error which could only be sorted by an engineer, also your buttons on the front are also controlled by software,and cannot be disabled.
Posted on Dec 23, 2006
Anyone know why my LG tv has the input menu stuck on the screen. it is not the remote and the buttons are not stuck.
Disconnect the television overnight. Remove the batteries from the remote as well. Tomorrow, put new batteries in the remote and plug the television in.
Nov 04, 2017 | LG Televison & Video
My Sanyo tv stuck in Please Select Language screen. I have unplugged tv, changed batteries in remote. I'm also am stuck. Tv is a year old. No power outages either.
Depending on the unit you have if you have more than one input (mine has four HDMI, Computer, Standard TV, etc) you may need to be on the right channel or input. You should be able to bring up an On Screen Display that will let you make changes, You might want to try the Menu key on the remote to bring this up. If nothing else go to http://sanyo-av.com/support/ and find your TV and look at the manual.
Jan 26, 2017 | Sanyo Televison & Video
I have a Dynex 32" TV. I have lost the remote. I am using the controls on the TV, Menu, +-Volume, <> input and on/off. I am stuck in the menu and can't get out. Can you help me? Thanks
unplug your TV for 30 seconds and then plug it back in. Or just follow the directions on screen on how to use the volume control buttons and that should help.
Jan 29, 2015 | Dynex DX-L32-10A 32" LCD HDTV
TCL Blue Screen "No Media"
I HAVE FOUND THE ANSWER!!!! I just bought an TCL TV last night and was given the wrong remote. Screen was stuck on "no media" screen BUT I noticed that when I turn the tv on and keep pressing the menu button, the menu screen would pop up for a half second before the no media screen popped up again. So I knew it was able to access it. SO, it took a few try's and with no exact method I turned the tv on, waited til I saw the TCL logo and then simultaneously pressed the menu and channel up button repeatedly. It will open the menu for you and allow you to move between the input channels!!!! It WILL take a few tries to catch it but it worked!!! Your welcome!!!!
Dec 29, 2012 | Televison & Video
I have a Sharp Aquos LCD TV Model LC-32BX6M , when I try to connect a new generation Android TV Box HDMI Out to TV's HDMI input the Android Logo appears and after sometime the screen goes blank t
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
Oct 15, 2012 | Sharp Aquos Televison & Video
I have this menu stuck on my tv. Is there anyway to remove it?
Switch off the TV manually. Remove battery of remote. Switch off power and remove plug. Retry after sometime. Try changing the input device to some other like a DVD player. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Televison & Video
Tv is stuck on blue screen
i would suggest cycling thru the inputs- av1 av2 rgb hdmi. blue screen is indicator of no input.
Apr 07, 2009 | Televison & Video
Setup Menu will not display on TV screen
Ok, on the back of the unit, there is a single yellow composite output. There may also be a Red, green,blue.Component. Take 1 RCA cable and plug it into that yellow output, and route it into your TV input, also a yellow composite. Make sure that whatever input you put that into on the tv, that you change the TV input to that to view your player. when and if you get a picture, you should be able to get to the menu through the GOVID remote.
Later once that Path is working, you can upgrade it to the Red,. green, blue, if your TV has the inputs. You did not give a model for the TV or I could tell you what it has.
If you need any more clarification, please reply.
Best Regards,
Charles
Jan 05, 2009 | GoVideo Go Video DVD/VCR Combo
Can not get the image back on my astar hdtv when I choose the option
First check Tv menu comes on screen?
Connect DVD Player at any a-v input and confirm picture on tv. This will confirm that tv has no problem except in tuning circuit.
Now check Antenna / cable hooked up in RF input of tv properly.
Perform Auto-Search / Auto-Tuning / Auto-channel on TV menu and tune all available channels.
Still blue screen? means TV Tuner looks bad.
Sep 16, 2008 | Astar Televison & Video
Small Green K on the screen
With your tv on and the green K box on your left.
*unplug your tv from the outlet
*HOLD DOWN the (Volume - and input)
*Holding down the (Volume - and input) plug tv in
Tv will power on.
Now Tap the (Volume - and Channel -)
you will go in a menu tv mode
with the "remote" hit the down in the arrow (not channel or volume)
Now hit (volume +) and the tv will get arrows ex.(/////////)
The tv will turn green "meaning it was resetted"
Unplug tv from the wall.
Wait (30 Seconds)
Turn tv back on.
Since the Tv was resetted, go through the initiative Welcome startup screen. (Pick your Language, etc..)
Dec 26, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Toshiba 32A43 32" TV Logo
147 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
