I made a handwarmer with ceramic cooking beads & corduroy. I was warming it per the instructions & it caught fire. Now the microwave isn't working at all... the panel lights are out, the inner light is out, it doesn't beep when buttons are touched. It was a small fire, there is no melting or physical damage that we can see (other then it really smells smokey) It is a Whirlpool MH7140XFQ I was wondering if there is a fuse box I can check before we replace this... Thank you in advance for your help.
It probably put too much heat in the "innards" of the microwave and probably opened the thermostat or thermal fuse located inside -either on the chassis of the microwave or or the magnetron. If you or a friend is handy and wants to check and replace it, it's not a hard job as long as you play it safe. It will look something like the attached photo. In my profile you can find a link to my site where you can find critical safety & disassembly tips. There will be numbers on the side indicating the temperature and you can take the old one to a local appliance parts store to get a new one. NOTE: The one for the hood fan will read open at room temperature, so don't confuse it with the other two thermostats, which will read closed at room temperature. Post back if you need more help.
