Question about Maytag Dryers
My dryer takes two hours to dry a load of towels
This dryer is around fifteen to eighteen years old. I thought it might be the thermostat. Is this difficult to replace?
  • ipyaidptlady Nov 22, 2008
    I will give that a try. Thanks so much!
    Sergeant:
  • 229 Answers
It isn't the switch- thermostat switches either work or they don't. One of your heater coils is probably out or if you have a dryer that has only one coil it is probably not working very well and needs replaced. This is an easy and inexpensive repair and for less than around 50 bucks - it is like getting a new dryer.
Good Luck
Posted on Nov 22, 2008
It takes my dryer an average of 4-6 hours to dry a load of towels. A regular load of clothes is about 2-3 hours. What can I do?
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Oct 19, 2010 | Fisher and Paykel DGGX1 Electric Dryer
Dryer not drying in one cycle. takes multiple cycles do dry one medium size load. the machine is less than a year old and we clean the filter after every load. checked the vent hose and its clear with no...
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Nov 23, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
LG Dryer takes way long to dry
Let's work together to get to the bottom of this problem. begin with these thoughts
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
May 29, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Takes 3 hours to dry a small load, dryer is 3 1/2 yrs old
You need to clean vent hose and vent line in wall of house.
May 08, 2009 | Dryers
PYE3360AYW
it could be a deffective cycling thermostat or high limit thermostat. check them and clean any lint built up on them or around them.
Apr 24, 2009 | Maytag PYE2300AY Electric Dryer
Hello: I have a Maytag, do not know model # as I inherited the 5 year old model when I purchased a condo and it is now 7 years old. The front of it states Maytag - Dependable Use, Heavy Dtuty - Large...
I ALWAYS START WITH VENTING WHEN CALLED WITH LONG DRYING TIMES BUT I HAVE SEEN WHERE ONLY HALF OF THE HEATING ELEMENT IS WORKING, WHICH IS PRETTY RARE. A NORMAL LOAD WOULD BE WHATEVER THE WASHER HAD IN IT WHICH WOULD BE LOOSLY FILLED TO THE TOP ROW OF HOLES IN THE WASHER TUB. THE ONLY OTHER QUESTION I WOULD ASK IS IF THE WASHER SEEMS TO BE SPINNING OUT PROPERLY AND IF THE CLOTHES ARE GOING INTO THE DRYER TOO WET.
Jan 10, 2009 | Maytag LSE7806A Top Load Stacked...
It now takes 2 hours to dry towels
lets hit the eazy button first.dry a load with out the venting[wont hurt a thing]if ok its the house venting,if not dryer .GE is only brand that has two elements.so if not ge and heating element ok and its blockage in the dryer.hope that helps God bless ,tom
Jan 04, 2009 | Dryers
Maytag Neptune Dryer--Drying Problems
clean out your vents going out your home have someone also clean out the lint that has been pushed in side your dryer
Mar 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
46 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
