Question about Sharp EL-733A Calculator
Cannot calculate Standard deiation using sharp EL-735
Hi There,
I need help!! I have an exam Monday and cannot seem to calculate Standrd deviation using my sharpe EL-735.
The question gives the following annual returns:
2001: 15%
2002: 18%
2003: 17%
2004: 14%
2005: 18%
2006: 20%
What are the key functions to calculate the risk?? I know the answer is 2.191% as I have used excel to determine this, but cannot work it out on the calculator....Also, we dont have excel in the exam :(
Thanks, Lauren
I need help with my calculator settings sharp el-535 every time when calculate statistics it give me error answers and.even when I set it to a stats mode it will show a frequency table
There is a really great website called www.mathsatsharp.co.za that is dedicated to answering questions and helping people who own the Sharp scientific calculator range.
For Stats - i assume you are using the 535 with the table. Simply type in each data value, press = after each. Press change.
Press alpha and the number of the function you would like (for example 4 gives the average). Be careful with your standard deviation for population (on 6) and sample (on 5). In school we use the population standard deviation formula and not the sample standard deviation.
Sep 02, 2017 | Sharp Office Equipment & Supplies
Sharp advanced EL-531x how to input number after number for stats
First you have to set the calculator in STAT mode, presumably Standard Deviation or SD. The display should show a STAT annoucer to the top. To enter values use the key M+ (or the key next to which is marked DATA. The screen displays the number of data values entered so far.
To get the statistics you must use the keys marked with x bar, n, Sigma x, etc.
Feb 27, 2013 | Sharp el-531x scientific calculator
I have just purchased the Sharp El-W535 and am unsure of its capability. Will the sharp el-w535 compute the sum of a list of 10 standard deviations? or do the individual standard deviations have to be...
Thank you for purchasing the SHARP Scientific Calculator Model EL-W531/W531G/W531H/W531HA/W535.
About the calculation examples (including some formulas and tables), refer to the reverse side of this English manual.
Refer to the number on the right of each title in the manual for use.
After reading this manual, store it in a convenient location for future reference.
Notes:
• Some of the models described in this manual may not be available in some countries.
• This product uses a period as a decimal point.Displaying calculation results
When possible, calculation results will be displayed using
fractions, r, and ?. When you press U, the display will cycle
through the following display styles:
• Mixed fractions (with or without ?) ? improper fractions (with
or without ?) ? decimal numbers
• Proper fractions (with or without ?) ? decimal numbers
• Irrational numbers (square roots, fractions made using square
roots) ? decimal numbers
Notes:
• In the following cases, calculation results may be displayed
using r:
• Arithmetic operations and memory calculations
• Trigonometric calculations
• In trigonometric calculations, when
entering values such as those in
the table to the right, results may be
shown using r.
• Calculation results may extend off
the edges of the screen. You can
see those parts by pressing l
or r (depending on whether the left or right portion is
hidden).
Jan 17, 2011 | Sharp ELW535 Calculator
Hi! I am using the Sharp EL-735 and I don't
Setup DSP TAB
then you can choose between 0-9 decimal places
Apr 20, 2010 | Sharp EL-738 Scientific Calculator
Where can i find sharp el735 manual
GOTO http://support.sharp.net.au/
in the pickup menu .. choose alculator... and put in model EL-735
Ive just done that.
Aug 20, 2009 | Sharp EL-733A Calculator
How to do standard deviation calculations?
M=500 and S=100 in a normal distribution, what percentage of the subjects have scores between 400 and 600
Jun 03, 2009 | Casio Office Equipment & Supplies
Standard Deviation
You must first enter the data you are doing statistics on.
After you finish entering the data, do as the figure below describes.
Hope it helps.
Mar 11, 2008 | Sharp EL-531VB Calculator
User's manual Sharp EL-531WH
You can download the manual from the link below: http://esupport.sharp.at/html/om/index.php?StartRec=50&ListLimit=10&Lang=%&TemplateLang=en&ProdLine=30&SortOrder=DESC&OrderBy=Title&SearchString=
Aug 10, 2007 | Sharp EL-531VB Calculator
Sharp EL-733A Calculator Logo
527 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
