Question about Pioneer VSX-D711 Receiver
Amp error when i turn it on, it displays AMP ERROR and then shuts itself off.
  • oleeeelu Apr 12, 2009
    I've had the same problem. It happened just now. I also noticed that the receiver (top vents) are awfully warm.
    Its almost like once it cools its ok & works.
    Im playing songs off my macG4/itunes with a audio cord plugged in the video input on the front.
    Do you think thats a no-no?
    Actually-a different problem(which god only knows why im not listening!)
    sometimes theres a hum. I had the same cords connected to the back aux jacks, it would work fine and then the hum would start.
    Makes me sick, i love my vsx-d711
  • 4 Answers
AMP_ERR means the unit is detecting DC on the output of one or more amplifier channels. This is either the result of a failed/shorted amplifier (or other component) or bad solder joints (as mentioned above).
Posted on Aug 12, 2009
I had this exact same problem, it can indicate that there is an impedance mis-match somewhere. i.e. using 4 or 6 ohm speakers instead of 8. However if you unplug the speakers and it is still doing it then you could have a problem with the actual amp circuit.
Mine was doing it with nothing plugged in and had dry solder joints on the circuit board with the two large output devices are. Simply resoldered those and it is fine now.
It had started crackling before it stopped working all together, which would also indicate the start of dry joints or bad connections somewhere.
Regards,
Rolf.
Posted on Jun 18, 2008
Hii I have sony shake 6D system and whenever I turn the volume up it reaches upto 40 and shows the error of 'protect E01' while the maximum volume is 50. Please help
Most likely, your unit is shutting down due to overheating. You cannot run an amp at that kind of volume very long. It is shutting down to protect itself. Try running the amp at 1/3 your normal level. Most likely, it will not shut down.
Aug 05, 2015 | Sony Audio Players & Recorders
In the past couple of days the oven has been turned on, preheated and then shut itself off with "F1" appearing on the display. Can't figure out what this means. Anyone know?
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
Apr 09, 2011 | Ovens
My camera is displaying error 0000018-4489-957-000, what i do ?
The screen would turn red and i would get an error message. I realized the lens lid stayed open even when the camera shut itself off. I hit the corner of the camera a few times (the side with the lens) until the lens lid shut. Then I tried to turn on the camera and it worked!
Mar 14, 2011 | HP Photosmart R727 Digital Camera
LG 50 PS 3000 tv will not turn on. Flashes a picture then turns itself off
Since your TV comes on and shuts off, the possiblity of the main power developing a fault on switch on to shut off as the error amp is asking it to do so.. Please check for any failure of capacitors in the HT section. use a multimeter and test voltage on switch on. make a note and test after it switches off. you will slowly arrive at the point of trouble. look for dry solder joints. use a good iron to carefully solder all joints suspected to look mushy. check the connectors of the HT drives to the panel. there could be fault in the connection resulting in slow build up and causing the error amp to react to shut off. Hope my advice helps. Good day
Jul 12, 2010 | LG Televison & Video
Error Message: Condition 1
Error condition 1 is a faulty Fan. On these units if one fan is faulty then the sensor will shut the screen down as a protection.
a repair of this unit is possible.
Regards
May 12, 2010 | Fujitsu Plasmavision PDS-4214 42 in....
Sanyo vpc s1070 displays - lens error when turned
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Apr 18, 2010 | Sanyo Vpc-s1070w Digital Camera
GLEQ2152ES the error "PF"
My dryer keeps beeping all by itself. I had to turn the breaker off. Now I tried to use it it it tumbled for a minute but kept flashing err & beeping then flashed E68 & shut off.
May 25, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Hobart LX30 error code wrench & E5
What error code is displayed?e1,e2,e3,e4?I'm a hobart tech let me know.
Apr 10, 2009 | Dishwashers
It says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error?? It says File system error when I turn it on and then it turns itself
it says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error??
Nov 26, 2007 | Creative Labs MuVo V200 MP3 Player
Pioneer VSX-D711 Receiver Logo
1,254 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
