Question about HP OfficeJet 7410 All-In-One InkJet Printer
Won't Scan I am trying to scan a document but keep getting this message first:  "Unable to connect to device" and then "Unable to communicate with TWAIN data source." It is an HP All-In-One psc 950 connected to a MacBook. I have no problems printing or copying. Thank you.
  • 1 more comment
  • rivarose888 Nov 22, 2008
    OK, this is new to me to do.  How do I check the Firewalls....and then how will I know about the correct twain drivers?
    Thank you.
  • rivarose888 Nov 24, 2008
    I have just learned from HP that the HP 950 scan does not work with mac os x v10.5.  Only the printing and copying functions work.
    Thank you for your suggestions and help!
  • Mike S
    Mike S May 11, 2010
    Check you Firewalls.. make sure you have the correct tain drivers installed.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
I would suggest you to seek help at a Mac forum.. if it was Windows I could tell you...
I would suggest going to the HP site and look for the software, but for mac. and which mac version?
this is the website.Direct to the.HP PSC 950 All-in-One Printer
http://h10025.www1.hp.com/ewfrf/wc/softwareCategorylc=en&dlc=en&cc=us&product=60259&lang=en
I would uninstall the software and reinstall.. good luck...
Posted on Nov 22, 2008
    Scholar:
  • 85 Answers
OK
PLEASE REINSTALL THE PRINTER DRIVER AGAIN.
Unable to scan, I keep getting error message.
Samsung ml-2570 mono laser printer not work destop print
Jan 06, 2014 | Lexmark X2600 InkJet Printer
Won't Scan -- "Cannot properly communicate with the scanner"
I think the USB cable is defective or the scanner is failing.
Apr 25, 2017 | Epson Gt-15000 A3 Flatbed Scanner Eu-45
I have my lexmark multifonction ,i install it normally in windows 7 64 bit, i can print normally but i can not scan document please i need your help when i scan a document i receive this message unable to...
Please download and install the scan drivers on your computer from support.lexmark.com website. Make sure to properly filter the operating system and then click on the downloads tab, you may select the link under drivers "Complete drivers and software for setting up, configuring, and using your device" when you install you may customize and select the local scan drivers.
For further assistance, please contact Lexmark Technical Support.
Jul 18, 2011 | Lexmark X543dn Laser Color All-In-One...
When I try to scan I get this message: No scan
>open solution center icon on your desktop
>go to settings and check scan options
Oct 17, 2009 | Office Equipment & Supplies
Scanner not working
Hi Jkey !
As per the information you have provided, I understand that you are receiving an error "No scan option refer to the documentation" on the printer, when you try to print from the front panel of the printer (I mean from the printer's side).
However, plz provide me the proper error message so that I can assist you in the best possible way. If you are unable to scan from the printer's side, then try to scan from the computer and check if it is working or not. It should work when you try to scan from the computer, if not there may be a communication issue between the two devices.
To check the communication perform the below steps:
IF the printer is connected via USB cable, then perform below steps:
Useful scripts For Windows XP:
To isolate the issue I suggest you to try scanning from the Windows Image acquisition(WIA) wizard on the computer.
Follow the below steps to Scan using WIA
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
If you are able to scan fine using the above steps, please write back to me along with the exact error message.
With Regards
Mike.
Jun 27, 2009 | HP Photosmart 2575 All-In-One Printer,...
HP 1210 all in one scanner connection error
I found a solution to this...
1. Go to the Windows Start Button
2. Click on Programs
3. Click on Windows Fax and Scan
4. Use that program to scan documents
Apr 21, 2009 | HP PSC 1210 All-In-One InkJet Printer
Won't scan nor fax
HP multi units are notorious for scanner failures. It is just a weak component in their machines. I have seen this time and time again. The only solution is to change the scanner out or purchase a different machine. Just keep in mind the notoriety HP has which failed scanners. If you want to venture into the replacement of the scanner the following website might have the product you are looking for. Otherwise, search around the net for a scanner assembly unit for the OJ7310. But, be prepared scanner units are not cheap.
Check here first...PrinterFixer.net
Nov 13, 2008 | HP OfficeJet 7310 All-In-One InkJet...
I can't scan
This document applies to the PSC 2210, PSC 2210v, and PSC 2210x. When you see the scanner failure message, turn off the PSC 2210. Wait a few seconds and then turn on the PSC 2210. If you see the message again, please contact HP Support. http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&cc=us&docname=c00055511&dlc=en&product=79499&rule=45570&lang=en
Dec 04, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
442 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
