Question about Epson Stylus Photo 1280 InkJet Printer
Tiny shadow lines around text & graphics
I have an Epson 1280 with dyesub ink system hooked up to it, it has been working fine until recently anything I print whether it be text or graphics there are tiny hairline like lines wrapping around everything perfectly, it's not random at all.
Looks intentional like there's a fine gray shadow behind objects, I installed new driver and done all the normal fixes to no avail....it seems to be a software or driver problem....it does the same thing printing from different programs.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Epson Expert
  • 97 Answers
Sometimes a problem is with the printhead if it does that. Most likely a printhead. I'm sorry. Print a nozzle test pattern and you will be able to see what color has extra ink.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Posted on Jun 07, 2017
3 Suggested Answers
  • 12 Answers
SOURCE: I have replaced all the Ink Cartridges in this
Go to your printer properties box and do a nozzle check then head cleaning and that should resolve your issue..
Posted on Jan 08, 2010
cns assoc
  • 677 Answers
SOURCE: Epson Stylus Photo 1400 Prints Dark Shadows Red!
Did you use Epson Genuine Cartridges? ????
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE
BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on fixyourownprinter.com’s forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Feb 16, 2010
I cant seem to print text. i can only print graphics. i recently put in new ink cartridges, tried to print a page of only text and the pages were blank. tried to print another page with text and graphics,...
Have you tried printing text in different colour if that works the black jets are blocked- try running the cleaning cycle to clear (it may not use black ink in graphics)
Nov 15, 2010 | Brother DCP 130C All-In-One InkJet Printer
I'm trying to resurrect an old Epson 1280 Photo Stylus. I've changed ink cartridges, and run the head cleaning/nozzle check utility numerous times, but nothing prints out on any test pages, nor on any...
It's time to "cut your losses"; either the electronics that tells the inkjets when to shoot ink is screwy, or the inkjets are totally plugged, despite the "cleaning" cycles.
Responsibly recycle the printer, and buy a new printer.
Maybe, try to find another Epson that accepts the same ink-cartridges that you recently inserted into the old printer.
Nov 19, 2009 | Epson Stylus Photo 1280 InkJet Printer
Black and white not printing correctly, color is fine
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Feb 10, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Epson stylus photo 1280 Isn't the printer working if I only have a black ink full?
It doesn't matter whether the cartridges are full, but both cartridges need to have ink in order for the 1280 to work.
Jan 17, 2009 | Epson Stylus Photo 1280 InkJet Printer
Not to be too facetious, I decided to invest in another printer...so that's how I'm going to "fix" this problem. I was told that it was an internal electrical problem and that I should take it back to where I had it serviced for overflow ink pads. The printer worked fine until a few days ago. What that technicion told me at the time, is that he didn't replace the ink pads, just cleaned them and re-set the counter (that tells you when to replace those pads). I suspect now that the problem might be in the counter. Yes, I could take the printer back, a pain-in-the-neck; whether they would charge me for another visit, I don't know since this is a different problem. The unit is a few years old....do I pump more money into it or just get a new one, since they are relatively inexpensive. Because of that, I'm not sure I want to invest in another Epson brand printer. The difference in the problem, is that when I needed new ink pads, the red and green lights flashed alternately, even though it wouldn't print. Now none of the lights comes on. Aleg Assai (alegassai = music term)
Jan 16, 2009 | Epson Stylus Photo 1280 InkJet Printer
My Epson 1290 only prints half a page
Hello I am use in 1290 printe in epson problem in hafe page print and red led on and printing in hang pl.. uragent in
Thanxx.
Rawat
Nov 10, 2008 | Epson Stylus Photo 1290 InkJet Printer
Epson stylus 1280 printer
Based on the lights you are already out of one or more ink cartridge or an ink cartridge is not being recognized/expended.
-You cannot print if any ink cartridge is expended.
-Leave the empty cartridge installed in the printer until you have obtained a replacement.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
1. Open the printer cover and press the INK REPLACEMENT button, located under the printer's cover. The print head moves to the center and the lights flash.
2. Lift up the ink cartridge clamp. The cartridge rises up from its holder.
3. Remove the cartridge and dispose of it carefully. If ink gets on your hands, wash them with soap and water. If ink gets in your eyes, flush them immediately with water.
4. Unpack the new ink cartridge and remove the yellow tape. You must remove the yellow tape from the top of the cartridge. Do not remove the clear seal underneath the cartridge. Do not touch the green circuit board on the back of the cartridge, or you may inhibit normal operation and printing.
5. Tilt the new cartridge toward you slightly as you insert it. Lower the cartridge so that the tabs rest on the hooks. Do not place the cartridge tabs under the hooks.
6. Press down firmly on the ink cartridge clamp until it snaps in place.
7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8.
8. Press the INK REPLACEMENT button and close the printer cover. The printer begins charging the ink delivery system.
9. Wait until ink charging is finished (the power light stops flashing and the red error light goes out).
Jun 17, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson 1280 wont print
hi i was tring to chat with you where u getting my messages
Jun 08, 2008 | Office Equipment & Supplies
Epson 1280 Printer breakdown
it is the wasted ink pad, they are full.
to have your printer work again
turn off the printer.
press and hold the ink and paper button while turning on the printer, wait for 5 seconds then release the button and press the paper button for at least 10 sec.
if done correctly , you will see the carriage start moving
Jan 20, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus Photo 1280 InkJet Printer Logo
60 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
