Question about Pride Maxima 4-Wheel 4-Wheel Scooter
New 55ah batteries but charge won't last.
My scooter is 4 years old. I have bought new batteries less than every 12 months. 55ah, gel. The batteries tested good but they wear down very quickly. I go to Walmart with a full charge, and before I am finished shopping, they are almost dead. Then I have to be pushed or wheelchaired to my car. Can anyone help?
  • 118 Answers
Battery life is affected by many things. But inside a tiled space like Walmart is probably the best possible running conditions. Make sure your tires are fully inflated, and you may need to have the motors check for worn brushes or maybe the wheel bearings are dry. Does the scooter push hard when in free-wheel mode? You may also need to have your charger checked, to be sure your batteries are really being fully charged.
Posted on Nov 27, 2008
Mobility scooter is unresponsive
.good mobility scooter
humm strange
...fitted a new throttle but still no go
any fuses in the system
might need a volt meter to test all the wires voltages and resistance between battery and throttle
info says comes with two batteries
ouch the w/55AH Batteries are about $250
are both batteries holding full charge
May 30, 2016 | Pride Mobility Products Hurricane PMV...
Wont charge up, batteries showing between 3 and 4 volts, batteries less than 12 months old. Charger ok brand new
The batteries are to low for the auto charger to work so either replace batteries or have them load tested to see if they are any good. Personally I would replace them.
Apr 09, 2015 | Health & Beauty
My scooter has started to make a clicking noise
hi , sounds like the brake is clicking which in this case is normal, sometimes as the brake wears the clicking get nosier. Can you please confirm where the clicking is coming from ??.
Feb 27, 2014 | Pride Mobility Products Pride Mobility...
I have the Shoprider Delux scooter.I brought it second hand.I put in a new battery but its not holding the charge. I seem to have to charge it up before any trips out.When its fully charged and I go about...
When you say that you put in a new battery, I hope you mean new batteries. This particular scooter takes 2 batteries and just changing one will leave the remaining one in poor condition. Make sure that you have replaced the batteries with the correct size and type. This scooter takes 2, 40 amp hour batteries. Sealed gel AGM batteries are preferred. The batteries should have the number 40 on them with a date code. You need new, fresh batteries to have them work properly. A date code tag of A1 indicates the A month(1st month) or January of 2011 (1 is for 2011). If you are not sure of the battery condition a local shop can load test them for you.
There is a possibility with a 5 year old scooter that a worn motor/brake will cause excessive current draw and drain your batteries. A qualified technician can determine this for you with a service call.
Hope this helps.
Mar 18, 2011 | Shoprider Sprinter XL4 Deluxe 4 Wheel...
What are the Best replacement batteries for the Jazzy Select 6 and Where is the best place (retail store or online) to buy them? I bought the U1 Gel Batteries at and they...
ggirl why did you buy a pig in the poke they should refund your money because the batteries should have a six month warranty. Now always ask for the date code on batteries you are buying they shouldn't be any older than 4 months old. There are good batteries out there but if I offend anyone I'm sorry but MK batteries are very good also Interstate batteries and probably others that I'm not aware of. The best way to insure good batteries are buying fresh batteries, Charge them before you use the chair and always get into the habit of charging overnite if you use the chair daily. Never leave the charger plugged in more that 12 hours and if you don't use the chair daily charge at least once a week and always put up fully charged. Mk recommends charging the batteries daily for the first 20 days. Never run the batteries or let them fall below the red light on your battery level indicator. Your chair runs on about a 5 volt range (26-21 volts) after that the red light blinks like crazy. If it falls below 20 volts the charger will not charge the batteries. If you take care of them they should last you 3 years or more. Hope this helps
Oct 19, 2010 | Pride Jazzy Select 6 Indoor Power...
I have a Jazzy 1122. Is this a gel-cell battery I can take on a c
I think they will say its to big. They will be ok with a Pride GoGO
May 19, 2010 | Pride Mobility Products Hurricane PMV...
Pride hurricane batteries (2008,model)
You'll get a little more time out of the 55ah ( like 10%)
Mar 31, 2010 | Pride Hurricane 4 Wheel Personal Mobility...
The scooter is about five years old or so, batteries are two years old. Faithfully charged,and well taken care of unit, but, just recently the charger started heating up...very, very hot to the touch...why...
hi, the charger unit is breaking down, Sometimes the batteries can cause this problem but I think you find it the charger, when batteries get older they simply don't hold the charge as much as when new, also the way they deliver power can drop off quicker.
Jan 15, 2010 | Pride Mobility Products Hurricane PMV...
My laptop frequently going out of power for every 15 minutes it requires booting
By going out of power, do you mean the battery dies? Or is it shutting down even when it's plugged in?
Special equipment is necessary to check the battery of a laptop computer. The equipment will test the charging ability as well as the performance of the battery under the standard "load" of operating the computer. If yours is no longer holding a charge, or the charge lasts only a short period, it's very likely that the battery is simply worn out. Typically expect that if a battery is more than 2 years old, you'll be running out of life for it. Some batteries last longer, some much shorter. For example, Toshiba's Tecra series batteries seem to wear out and drain their charge quickly after about 6-12 months, needing a new battery.
If the battery is less than a year old, the manufacturers warranty may stipulate free replacement.
You may find a local computer repair shop that will test your battery for free since it's very simple for them to do.
Hope this helps, good luck!
Jan 12, 2010 | HP Pavilion zd8000 Notebook
Pride Maxima 4-Wheel 4-Wheel Scooter Logo
191 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
