Question about Samsung CLP-510 Laser Printer
Clp-510 resetting transfer belt
We are trying to reset the transfer belt but to no avail....any suggestions
Buy at toner cartridge resetter from tonerrefillkits.com
at your transferbelt there is 2 lines of contacts. use pin 1,2 &3 on the first row. connect with wires and cange pin 2 and 3. Push the buttom and wit until light go off. This worked well for me. If u buy toner too u get resetter for free. :) clp-510 resetting transfer belt - 050fbbe.jpg
Posted on Dec 04, 2008
SIR HOW TO RESET TRANSFER BELT,IMAGING UNIT, FUSER UNIT FOR SAMSUNG CLP 510
You can check the level of each item.
1. In ready mode press the Menu button on the control panel everal times until you see 'Setup 'on the bottom line
of the display.
2 Press the Enter button to access the menu.
3 Press the scroll button until 'Maintenance ' displays on the bottom line.
4 Press the Enter button
5 When 'Check Others ' displays on the bottom line,,press the Enter button .
6 Press the scroll button until the item you want to check displays on the bottom line.
7 Press the Enter button The display shows the percentage of item.
8. Press the scroll button display either 'Image Count' or 'Reset'
9a. Choose 'Reset' and press enter to reset the counter after replacing a consumable item
or
9b Choose Image count to display the counter.
10. Press the Upper Level button to return to step 7 and select a different choice or press it a second time to return to step
6 and choose a different item.
11. To return to the Ready condition press the Upper Level button several times until 'Ready' appears in the display.
Aug 23, 2011 | Samsung CLP-510 Laser Printer
Samsung CLP 510 just replaced transfer belts, imaging unit and fuser but now am getting what looks like wet spots on the prints
Some toner may have spilled in the printer. If so, you will need to clean it out. Also, the toner cartridge may be defective and letting too much toner out at one time, the solution is to replace the toner cartridge.
Take care.
Jul 20, 2010 | Samsung CLP-510 Laser Printer
Samsung CLP-510 streaking
You might try cleaning all the feed rollers, but you probably need a new drum. When you change that, you should also change the transfer belt and waste toner tank. Actually, it'll be cheaper to buy a new printer.
Jan 22, 2010 | Samsung CLP-510 Laser Printer
The printout has a scratch in the same place on
check drum and transfer belt.either one could be scratched.
Jul 10, 2009 | Samsung CLP-510 Laser Printer
Need to reset counter for transfer belt
to reset the counter on the toners and transfer belt see:
http://www.dunfield.com/clp510/
Oct 28, 2008 | Samsung CLP-510 Laser Printer
Transfer Belt vs Transfer Roller
Dear Friends:
I have a same problem after replacing both transfer belt and drum for Samsung CLP-510.
Can you help me?
An
Aug 20, 2008 | Samsung CLP-550 Laser Printer
I want to reset the transfer belt
Unfortunately you cannot as there is a resistor on the unit that blows and resets the transfer counter.
Sorry
J
Jan 08, 2008 | Samsung CLP 300 Laser Printer
Reset transfer belt samsung clp-300
Unfortunately you cannot there is a resistor on the unit that when you replace it it blows resetting the transfer counter.
Sorry
J
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
Oct 24, 2007 | Samsung CLP-510 Laser Printer
Samsung CLP-510 Laser Printer Logo
1,098 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
