Question about Sony DVP-NC80V DVD Player
Error message E 26 00
My DVD player is acting abnormally. The trey seems to have a problem and it flashes E2600. The manual says to call a sony repairman and tell him the code. Do you know what the code means?
Removed outer cover.
Unscrewed center screw on 5 disc exchanger tray.
Removed exchanger.
Operated system without tray.
Received error message E 27 00
Replaced exchanger tray and tightened center screw.
Operated player with eject button and it functioned correctly.
Replaced outer cover. Tested with DVD. All OK.
Tab
Posted on Feb 05, 2009
  • mtpgraham Dec 04, 2010
    This error may just mean that the disc exchanger tray is stuck. Removing the center screw, repositioning the exchanger, and replacing the screw fixed everything. Thanks!
My son and I just turned the unit upside down and opened it allowed the tray to open.  Apparently the disks weren't seated properly.  In order for it to open they need to be seated or totally not found...which is what we fooled it into believing.  Once it opened we were able to shake the disks out.  Everything's back to normal now!
Posted on Jul 14, 2008
  • gulf2golf Mar 22, 2011
    Turn it up and down and shake the hell out of it...turn the power and off then press the disk skip button...repeat the steps..we had all 5 disks stuck and it took 3 tries altogether and they came out!!!
Sorry to be the one to inform you (& anyone else facing this problem), but I just called Sony product helpline & boy let me tell you - They were NO HELP AT ALL! They informed me that if the unit was purchaced within the year that I'd have to spend my $$$ to send the unit (along with the reciept) into one of their service centers to have it evaluated & then repaired. I asked 1)If that was the only possable way to fix this specific error code on this particular model/part#? They said it was. I then asked 2) How long was this process of eval/repair? They said it could be up to 2-3 months depending on the volume of repair items recieved ahead of mine. So finally I asked 3)What I could do if I was unable to find the reciept? They informed me that I wouldn't be able to send it to them for repair by them. So I only have 2 choices; I can either hope to come up with the proof that it's under 1 year old, or else I'm stuck with their "Thanks for giving us your $$ for this item, but now your stuck with a unfixable broke-ass piece of *$&^%^$ Sony product so why don't you go out & spend some more $$$ to purchace it's replacement, then wait-n-see if it too doesn't break." In any case I personally won't be buying anything from Sony for quite a loong time. Hello Awia
Posted on May 05, 2007
SOURCE:
Sony bravia KDF-50E2010 RED LIGHT FLASHES 4 TIMES THEN 3
Sony TV LED & Blinking Codes - What Does It Mean When Standby/Timer Light Flashes Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue.
when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself.
Sorry but unless you may be able to repair the television set yourself , please call a local repair shop to the have a repairman sent out,,
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 08, 2011 | Televison & Video
My sony dvd player model dvpC6700 won't play just showing E2600 and it shut off the power
Sounds like the disk reader needs replacing, I recommend returning it to where you bought it and ask for a replacement if it is still under warranty or pay for a repair.
May 04, 2011 | Sony DVPCX985
My sony dvd slv-300p blue light progressive scan light is on and i cant do anything ?
my sony dvd vcr combo has a progressive scan flashing light when plugged in. i put a vcr in and now it's stuck. none of the buttons seem to be working. it is making a clicking sound inside on machine. how can i get this thing to work again?
Jan 23, 2011 | Sony SLV-D300P DVD Player/VCR
Xbox 360 Console: Trey will not open or respond.
This happens WAAAAAAY to often with these consoles.
The culprit is a magnet inside of the dvd player that holds the tray from opening because the magnet is slightly too strong. The magnet is used to hold the dvd/games in place while they spin. The way to fix this is to buy a package of those hole reinforcment rings that you use to fix the holes in paper to keep inside of a binder. at staples they are called portable reinforcments.
What you have to do is place one or two fo these ring stickers over the magnet inside of the dvd player. If you open the dvd player you will know exactly what I'm talking about.
here is a tutorial video link:
http://www.youtube.com/watch?v=5ur-ewRUWXU&feature=related
Jun 02, 2009 | Microsoft Xbox 360 Console
Trey locked
There is a lock on this on the remote or end the menu system I do not remeber witch. You can unlock this software if not you need to unlock it hardware witch gets a little tedious.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 24, 2009 | Sony DVP-NS700P DVD Player
How to open back cabinet to portable player, sony dvp-fx820
Would you like to mention model number of your Sony dvd player to provide you help.
Nov 03, 2008 | Televison & Video
Tring to connect a sony video camera to my Gateway notebook
Macromedia's Flash Player is commonly used within video handling packages as a utility to enable compatibility across systems and platforms. It is available as a free download from Macromedia via the Internet. Suggest you install it as instructed to enable you to complete your DVD write.
Apr 28, 2008 | Sony Handycam DCR-TRV480 Digital Camcorder
Sony DVP-NC80V DVD Player Logo
2,244 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
