Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Hln5065wx/xaa red lines and dots on dvi input only
I have a hln5065 that i recently bought used had to put a color wheel in it worked fine for a month or two. recently while watching a dvd on dvi input the color got wierd red clouding and eventually tv just cut out color wheel still spinning and fans still spinning but no contorls no picture no volume. controls wont do anything unplugged replugged turned on samething red clouding and pixelation. then red verticle lines then cut out but wheels still spinning. unplugged switched to svideo for cable box no problems worked all day only problem with that which i have noticed since i got it is pure red backgrounds or blue back grounds i can see verticle bars ghost like swaying back and forth about 1/4 inch. im pretty sure that its a dmd failure but looking for some expert advise before i go spending more money.
  • 150 Answers
SOURCE: Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Posted on Jul 17, 2007
MikeMaierTV
  • 206 Answers
SOURCE: Sudden discoloration, ghosting, bowed horizontal lines in top and bottom of picture
Everybody here seems to have basically the same problem so I will write a general fix for these Samsungs. First what you got is known as Convergence failure, A Ic or resistor, fuse or some other component has failed in the convergence circuit. So finding the service menu and trying to align the colors or spinning magnets on the CRT’s or a real bad idea of tipping a CRT or mirror would be the equitant of ripping the transmission out of your car because it had a flat tire. When the convergence fails no adjustment will bring it back, and if you do one of these stupid things then you have two problems. Now most of these Samsungs have an easily replicable board that all the convergence amplifiers are on. This can be found by removing the back and seeing if there is a board about 9 X 5 inches big and mounted to the CRT mounts, there will be 5 connector to this board. Now if your set does not have this board and instead has the two convergence Ic’s (these are about the size of a playing card and have the numbers STK392-040 on them) mount down on a board below and to the right ( this is known as the deflection board) this repair will not work for you. Instead you will need to component level repair the convergence circuit. But if you do have this separate convergence board the repair is fairly straight forward. Go to www.vancebaldwin.com or some other supplier and order BP95-00142E this is the convergence board. This board has been crossed several times through the years but this is the current version. Now once you get this board simply replace it making sure to get al the connector back in there original spot. The fire up the set and run Flash focus and for about 95% this will fix the set
Posted on Feb 13, 2008
  • 74 Answers
SOURCE: DLP DMD board
BP96-00249A $937 at partsore.com i hope that isnt the problem
Posted on Sep 22, 2008
SOURCE: DMD Board failure on Samsung DLP
Try here:
http://www.partstore.com/GetModel.aspx?MfgName=Samsung&BrandName=Samsung&ModelNumber=HLN5065WX&PartCategoryName=&Keywords=board&Page=1&SortBy=price&SortDirection=asc#PartsearchSKUList
Posted on Feb 02, 2009
  • 3 Answers
SOURCE: Green Plaid then Vertical Lines, Failure of hard controls, Analog Board?
You are absolutely correct, When anyone complains of vertical lines or bars, the next step is to see if it happens on only digital inputs ( digital board ) , only analog inputs ( analog board ) , or both ( DMD board ) .
Analog board can be purchased at www.partstore.com ,
Posted on May 24, 2009
I have a 50" Samsung Tv. Model Number:
Some of these (many) had issues with a color wheel---high pitched or fan light sound that declines when set turned off----Got this?
Nov 04, 2012 | Televison & Video
We have a Samsung #HLN5065WX/XAA that has started making a very strange noise and flashing "Check fan no. 2". The colors are also off. What can I do to fix this?
The tv is making loud noises like humming or motor noises and tv have strange colors flashes or black and white backgrond flashes.The tv Colors wheel it is dying and not spinning the right speed of it RMP speed any more.The tv colors wheel must have be replaced to solved this problems.Have no mechanicals skills hire a tv tech. to change the tv colors wheel because u have to take out alot of mechanical parts out before u can come to the tv colors wheel itself to replace it.
Aug 20, 2011 | Samsung HLN5065W 50" Rear Projection...
Replacin the color wheel in HLN5065
U machanically incline?Not hire a tv tech. to this,because,u have to take out many machanical parts,before even can take out the Colors wheel to replaced.Try website like You Tube Type in Samsung colors wheel replacing.U will get a tutoring by some one doing or trying to replaced the colors wheel.
Jul 12, 2010 | Samsung HLN5065W 50" Rear Projection...
I have no color on my samsung hln5065wx/xaa DLP tv. Is it my color wheel or bulb ?
If it is just no color but you still have a picture it should be your digital board. This is the board that mounts behind the light engine and should be encased in a shilver colored metal sheild
Aug 13, 2009 | Samsung Televison & Video
DLP Colors Are Off - Picture Is Mostly Blue and Yellow
Sounds like you've lost your red video signal (chroma) somewhere along the line. This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. The analog has all your inputs on it, except DVI and RGB which go straight into the digital board. The digital scales (upconverts) the signal to HD (1080 or native) and sends it to the DMD or light engine. See which inputs are distorted. If only DVI is clean then you problem is the analog board. If you menu and everything is distorted then suspect the DMD board. If you run component or DVI through the resolutions (480i, 480p, 720p, 1080i) you can get an idea between the digital board and dmd. The menu is generated on the digital board. Somewhere red is getting lost.
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
48 people viewed this question
Jerry Greenberg
Jerry Greenberg
