Question about KitchenAid KSM50PR Professional Series Stand Mixer
Mixer speed turned erratic!
My mixer is about 4 years old, but has only been used for one year, sporadically. The other day when I was mixing on speed 2, it spontaneously changed to a very high speed - 6 I think. Now it only operates on speed 6 or 10, even when on the Stir setting.
  • Anonymous Feb 10, 2009
    I start my mixer on speed 1, then up to speed 2 then it takes off and goes crazy up to a very high speed for about 3 or 4 seconds then turns off completely.
  • 16 Answers
I would recommend that you first check the Hall effect sensor which determines the speed.  I had this exact problem and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My blender worked as good as new! But I was curious to know if my original sensor was defective so I put it back in mixer and again made sure all of the connections were tight.  Guess what?  My original sensor also made my mixer work!  There was nothing wrong with my original Hall effect sensor except the connection between the control board and sensor was not adequate--unfortunately I didn't check the connections before I decided to buy another one. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations.
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall effect sensor looks like. BTW the part number is 9703312. 2.  You'll need a phillips head screwdriver to open up the mixer. 3.  Make sure that the connection between the control board and sensor is absolutely tight and snug. 4.  Also, make sure that the orientation of the sensor connection between the control board and sensor is correct. it's hard to know which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or facing down. If, after you've made the connections, the mixer still doesn't work.  Disconnect the sensor and reconnect it with the prongs facing the opposite direction and try it.  I actually found the right orientation through trial and error.  By going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work it were reconnected with correct orientation.   5.  This whole process probably takes less than 10-15 minutes to perform.  6.  Make sure you use common sense and unplug the mixer when making connections and such.
Posted on Dec 30, 2008
How doI fix mixer that leaks oil out beater holes
There ate two ways to fix this problem, but first there is the matter of understanding what is leaking. The oil you see leaking is actually a food safe vegetable based gear grease. The grease separates during heavy use (years of service) or when the mixer has not been used for an extended period of time. (months or years) The recommended way to fix the problem is to do a full tear down then clean then add new grease and a new gasket, cost (By Kitchenaid at a KA service center) around $140.00 US + or -, It involves shipping and around ten days in time. The second way is kinda simple and does not cost anything. Get a towel, thick and soft to protect your finish, get your wife or husband, get an extension cord, spread the towel out on an open counter top, plug the extension cord into the outlet, turn the mixer upside down on the towel, have your significant other hold the mixer by the base while you plug the mixer cord into the extension cord, turn on the mixer no more than 2 or the second click on the speed control switch / lever, hold the mixer upside down like this while the mixer is running and keep it running for at least three (3) minutes, turn the mixer off and turn it right side up and turn on again for two minutes, then do it again two or three more times, upside down for a couple minutes then back right side up and so on and so on, after about 15 minutes stop. put everything away, you are done. What you have effectively done is re-mix the grease and it should be good for another couple of years. When it starts to leak again re-mix again. Or send it to KA for the rare and unique opportunity to spend a hundred bucks that you don't' want. hope this helps. By the way if you get some drops in your mix it will not hurt anybody. But you do not want to eat a great deal of it or you will require the use of a laxative afterwards.
Jun 18, 2014 | KitchenAid 32685 Mixer
We replace the motor and found it gets pretty warm to hot when using for awhile approx. 10 mins...and it started to leak oil.. we were told the person who replaced the motor used the wrong grease.. th
NOT TRUE!!!! the re is actually no oil in your mixer it is a vegetable base food safe gear grease. It separates after time and use and just need to be re packed and a new gasket installed. There is a quick trick to try to see if your mixer grease is at end of life or just separated from non use.
Turn your mixer upside down on a towel on the counter and turn it to speed six for two minuets then turn rite side up and run for two minuets again then do the process again at least one more time, if the leaking grease stops dripping then you have successfully re-mixed the grease if it continues to drip then your grease is at end of life and needas to be repacked. If it stops you will be good for another few years. i would suggest that you do the remix before you use your mixer if the remix works, even though you use it to grind meat it may be that you are still not using it enough through the year. So before mixing re-mix. Hope that helps, if you are at end of life on your grease you will have to do a tear down to clean all old and re-pack with new and a new gasket, Cheap to do but rather messy a two roll of paper towels job. nice thing is because it is vegetable based it washes right up with mild soap and water from all surfaces and your hands and your clothes, but don't wait to wash the clothes as it will stain if you leave it too long.
Mar 14, 2013 | KitchenAid Vintage K45 Hobart Mixer Mixer...
Delonghi DSM7 Stand Mixer won't start after overheating. Is there a reset button?
take it in to an appliance repair shop for a proper diagnosis and quote but it is probably not worth repairing ( armature and brushes )
Apr 09, 2017 | DeLonghi DSM7 Stand Mixer
Mixer has lost all speeds, only works when moving the lever back and forth. The mixer is about 9 years old.
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
Adjust the mixer speeds:
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Aug 14, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Our Sunbeam Mixer (stand variety) is about 25+ years old and has many miles on it. . About a week ago, while mixing a light concoction it slowed down and then stopped. It started a couple days later...
You will need to search for a repair shop. There are replaceable parts in the speed control assembly that will cause your symptoms when they fail. The question is - can those replaceable parts still be obtained after 25+ years?
May 10, 2017 | Sunbeam 275 Watts 2369 MixMaster Series...
When the mixer is turned on, you can here the inside going, but the outside part does not turn
Sounds like a problem we had years ago. We put too much pressure on the motor by mixing a very thick dough for cookies. It stripped the "gears" and couldn't be used on slow.... it would instantly go to the fastest speed. We had to take it to a reputable appliance store that does repairs on KitchenAid products. I'm still using mine and that has been 15 years ago. It still works great!!
Aug 29, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
When I turn on my Kitchenaid mixer at any speed, it ramps up to high speed and then shuts down after maybe 30 seconds.
You need a reputable repairman. My gears were stripped after trying to mix a very thick dough. It would only work on high speed. After it was repaired.... I still use it, all the speeds work, and that has been 15 years ago. My mixer was at least 8 years old at the time of the "stripping".
Aug 21, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Top wobbles and beaters scrape bottom of mixing bowl when in use
Turn the mixer over and look up where the pin goes through the two pieces. There is a screw there which secures the pin. Tap the pin into position and tighten the screw.
Apr 08, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Mixing bowl is jammed into the base and won't come out
you may have the old style frame which is why the bowl jammed old bowls are no longer avaible you may need to purchace a new mixer
Dec 10, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KSM50PR Professional Series Stand Mixer Logo
267 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
