Question about Motorola DCP-501 Receiver
Motorola DCP-501 Had this unit about a year, worked great. Turned it on today & there is no sound. The unit won't even let me go into the "Audio Setup"....the cursor jumps over the words & won't let me select it to get in there. Called Motorola & had the thing reset. It didn't help & neither did they. Any help would be much appreciated. Marz
    New Friend:
  • 48 Answers
  • Likely there is a little battery inside that has lost its juice, or possibly a capacitor that just lost its charge from lack of being powered for a year. No power=no memory=lost settings. You might open it up and look around for a small hearing aid type battery. If you find it, replace it and you will probably be good to go. if it is a capacitor that has leaked its charge, download the schematic from somewhere online, print it out and bring the schematic and unit to your local service guy where he will charge you at least $75 for labor for a $1 part install. Or t
Posted on Nov 17, 2017
4 Suggested Answers
SOURCE: Motorola DCP-501 IR codes
can you use the codes form novii remote for palm?
Posted on Jan 29, 2008
dunnbiker
  • 8546 Answers
SOURCE: No Sound on a Motorola DCP-501
You don't say what else works. Have you tried it with FM to eliminate external source causes? Does your TV get audio passed through to it? That would establish that there is program material to be amplified. Headphones work?
The following is from the User Guide -
Check to make sure that each speaker has been properly connected to the
speaker output jacks on the rear panel of the DCP501.
�� Check that the speakers are working by utilizing the Test Tone function as
described in the “Operation” section.
�� Verify that the DCP501 has not been placed in MUTE mode.
�� Check that the volume control on the DCP501 has been adjusted to an
appropriate listening volume.
�� Verify that the DCP501 is set to the correct source (CATV, VCR, DVD, Tape,
etc).
�� If the front panel displays O V E R L O A D , one of two things has happened:
1 If the DCP501 detects the speakers have a short circuit, it shuts down
the amplifiers. Switch the DCP501 off, remove the short circuit, and turn
the DCP501 back on. The DCP501 should now work as normal. If
O V E R L O A D is still displayed, a short circuit condition remains.
2 If the maximum amplifier output power is exceeded, the DCP501 shuts
down the amplifiers. Turn down the volume a little and switch the
DCP501 off and then switch the DCP501 back on and the DCP501
should now work as normal. If O V E R L O A D is still displayed, turn the
volume down some more.
The Speaker Setup menu has a Speaker Reset (to default settings) option.
Posted on Apr 28, 2009
dunnbiker
  • 8546 Answers
SOURCE: Motorola DCP-501 and PPV
It takes registration of the unit to receive them and it would be unethical and illegal to post a way to hack them here...
The clear protective film on the DCP501 display must be removed and transferred to the inside back cover of your
DCP501 Home Theater System User Guide. The Unit Address and Serial Number found on the protective film is
required for activation of your DCP501 cable TV receiver by your cable TV service provider.
What will cause disc error on the motorola dcp 501
Either a dirty laser, faulty tracking mechanism, or a weak laser(aging) will cause unit to mistrack. When this happens the mechanisms are replaceable and not repairable.
Mar 30, 2014 | Motorola DCP-501 Receiver
I have a Motorola DCP 501 Everything seems to work except the clip type speaker hook-ups no faults displayed
Hello
There are Center Speakers, Surround Speakers[L&R] and Front speakers[L&R]. Which amoung this show fault? Please clarify more about your Amps' problem.
Include the details of fault by FixYa comment box. OK.
Jul 10, 2011 | Motorola DCP-501 Receiver
Having a hard time with comcast cable to activate my dcp501. I have been a great cable customer for many years an pay my cable bill on time every month. Cable company tells me that it can't be done-I...
Comcast does not support the Motorola DCP501 anymore.. The current firmware they push to the box needs more memory than the box can handle and it causes the DCP501 to fail (black screen, unresponsive).
The last firmware to work is 7.xx. Now 8.09 or newer is being pushed-out. It fails on this hardware.
Feb 10, 2011 | Motorola DCP-501 Receiver
etc).
Apr 28, 2009 | Motorola DCP-501 Receiver
DVD Player won't work
DVD's: does it display any kind of error? All DVD's?
To your second question.
The manual explains cable and TV hookup for CABLE but there is no mention of off-air TV tuning.
If you don't have the manual go to:
http://www.retrevo.com/support/Motorola-DCP501-Receivers-manual/id/393bh936/t/2/ and register to get it. It's free.
Mar 09, 2009 | Motorola DCP-501 Receiver
Oct 19, 2008 | Motorola DCP-501 Receiver
Jan 03, 2008 | Motorola DCP-501 Receiver
Sound quit
Check the fuses inside?
Aug 23, 2007 | Motorola DCP-501 Receiver
"Overload" Message
greeting from belize first of all plug in the set into a wall socket and pull it out back quickly it might want to reset,if that does not work take to a tech for repair your chip might be be damage.good luck.
Mar 23, 2007 | Motorola DCP-501 Receiver
Motorola DCP-501 Receiver Logo
156 people viewed this question
Top Motorola Audio Players & Recorders Experts
Steve
GASTON CHOUINARD
InstaRep
InstaRep
Are you a Motorola Audio Player and Recorder Expert? Answer questions, earn points and help others
