Question about Goodman GMS90703BXA Heater
Replaced Fuse on Board. Unit keeps running
I replaced the fuse in my board. The unit fired right up, but when it reached the pre set temp. on the thermosat it would not shut off. It sounded like it wanted to,but would start right up blowing warm..not hot hair. Any info is greatly appreciated. Thank You
  • 1,420 Answers
Sounds like crossed or shorted wire going to the thermostat. Disconnect the wire from the thermostat and see if it shuts off. If it does, it is the thermostat. Then disconnect either the white wire or red wire at the control board and see if the furnace shuts off. If it does, its the wiring. If it continues on, it is the control board. Remember you will need to tape the access panel door switch to the on position to be able to run the furnace with the panel off.
Posted on Nov 25, 2008
The 3A fuse on the white wire keeps on failing. what could the reason be?
Most likely bad PC board.
The fuse stops damage such as fire, but the PC board probably needs to be replaced.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Other causes might be wrong polarity on 120 volt outlet, use a circuit tester to make sure the hot, neutral and ground are correctly connected.
Jan 28, 2017 | Rheem Water Heaters
After turning off the unit the display is off but the unit is still running.
If it has humidity control and the cool is still on but set temp is higher than the room temp, the humidity control will override set temp. If it has no %rh control then it probably has a circuit board fault; micro relay is stuck closed and board needs to be replaced. Its probably the circuit board. On it, there is a little black box(s). About 1" X 1/2" in size. With long run times the small contacts inside will fuse/melt together.
Jun 20, 2015 | LG Electronic Window Air Conditioner
OLEVIA 242FHDT11 KEEPS BLOWING FUSE EVERY TIME I REPLACE ONE
Fuse keeps from blowing is an indication of short circuit on its line. This is to avoid fire, and further damaged to other parts. Most of the shorts came from the rectifier diode, main filter electrolytic capacitor and the voltage regulator IC/transistor. You should test these parts using the multimeter to isolate the faulty parts. You must pull-out these parts from the board to have an accurate reading and avoid mislead by the reading of other parts connected in parallel.
If you can't troubleshoot the unit yourself, you may replaced the entire power supply board. Click this LINK.
Mjsazon
Oct 17, 2011 | Televison & Video
Hi there We had a powercut overnight and now the ST7100 will not run. I can hit set and set the times etc but when I hit Run the screen goes blank. Any ideas greatly appreciated. thanks
Hi, when you lost power, it may have taken out a fuse to the indoor unit if this is the kind of system you have, I don't know. As far as the stat going blank when you hit run, it may be the 24 volt circuit board fuse, I would need more information on the system you have. See if your stat has batterys also.If nothing is running at all, check all breakers, fuses and so on. If you do have a split system, the indoor unit will have a circuit board where the stat wires are terminated. The fuse looks like a auto fuse, 3 to 5 amp. This may be blown. If so, replace and your back in business. Like I said, if I new what kind of unit you have, it would be very easy to trouble shoot. It may have taken out the transformer also. Just make sure all power is restored, no breakers tripped and fuses blown at the indoor unit. This should be very easy for you to take a good look at this unit. The display on the stat runs off batterys most of the time, but some are powered from the transformer. Try what I have said, as you will need to have 24 volts to the stat to fire up the unit, and if you do and the stat still goes blank, you have a faulty stat board. Keep me posted. Best of luck to you.
Shastalaker7
A/C, & Heating Contractor
May 12, 2011 | Heating & Cooling
Pioneer sd-643hd5 fuse issue
The fuses may not be your problem--I have fixed several of these---The large power board is on the right side as you look from the back?
Lots of these sets develop bad solder connections on that board--several sites on the internet offer to have you remove and send them the board to resolder--this set used lead free solder and after some years has problems--a few I have opened had clearly broken solder joints--I usually in this case remove the board(mark all the many plugs and make a diagram) and solder almost all of it by hand----usually fixes this kind of trouble.
I do this here for free so if this information was helpful give me a vote here....I am here to help people.
If you have any questions or need advice reply to this posting here.
SD TECH
Sep 12, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Air conditioning unit not running but fan keeps running even though thermostat is turned to off, auto, and temp set to highest position 90degrees. 3 amp fuse keeps blowing on the circuit board in the...
if the fuse is blowing then this is generally indicative of a short in the low voltage wiring, isolate the wires on the thermostat and the unit ends, use an ohmmeter to verify that there is no path for continuity with no wires touching, if there is then you must pull new t-stat wire to the thermostat, (a guess would be that the green and red are shorted, by the symtoms you gave.
Jul 20, 2009 | Heating & Cooling
Blowing 3amp fuses
You have a low voltage short. A lot of low voltage shorts come from the wires that go out to the outdoor unit. Go outside and inspect those wires and that they are in good condition. Also check for any splices in those wires that they haven't degraded in any way. This is the only thing that will blow the fuse. That's why it's only 3 amps and based on the size of your fuse, it's a gas fired unit right? Have a great day!
Apr 10, 2009 | Ruud UBHC Air Conditioner
Our heater blows cold air.........
most boards have a small 3 or 5 amp fuse on the board it looks just like a car fuse. do not put in wrong size fuse it can allow damage to the board.
Nov 22, 2008 | Amana PTH153B50AE Air Conditioner
Fans not working
I had the same problem as other bloggers--temp would not decrease and fan did not run. . . as suggested by others, I replaced the 5A heat-shrink wrapped fuse in upper left corner of circuit board (fuse is covered in black heat shrink wrap and is in a U-shape). I unsoldered the two ends of the fuse on the circuit board (be sure you locate the correct two holes) and then replaced it with two parts from Radio Shack--a 5x20mm Inline Fuse Holder rated at 250V AC, 5A (part # 270-1238) and used a 6.3A slow-blow 250V fuse (part # 270-1066). Now the wine Refir works great!
To replace the part take all the screws off the sheet metal covering on the back of the refrigerator. Remove the circuit board from the plastic holder. I left all the wires plugged in and just unsoldered the fuse with the circuit board still connected--but to solder you will need an extra pair of hands to hold the board while you solder.
If you don't have it, get some silver solder while at Radio Shack and a thin, needle-point soldering iron tip. Radio shack has 30W soldering irons for less than $10. You really don't need soldering experience--just a steady hand. Even if you have none of these parts your total outlay at RadioShack is less than $25 for everything.
Apr 14, 2008 | Oster 12-Bottle Wine Cellar - Black
Problem with RSKP 0006 control board
If the unit has an outdoor thermostat, this turns the aux. heat on very cold days. It may need to be replaced, or removed completely, if its kicking over to soon before it gets that cold. If its set to turn on the electric at 30 degrees, then its working the right way. Also, look for different temp. setting on the board you lust installed, there should be some sort of adjustment options on it. Especially if there is no thermostat outside.
Feb 28, 2008 | Amana PTH123B25AJ Heat Pump Air...
Goodman GMS90703BXA Heater Logo
108 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
