Question about RCA HD52W59 HDTV Projection Television
Lost sound on my HD52W59
We replaced the fuse like you suggested and it fixed our problem. Worked for a week and now he lost sound. Any idea what we need to look at. Please advise.
  • rjones4 Nov 22, 2008
    So are the connectors that I'm suppose to be looking for, are they suppose to be on this same board?
  • rjones4 Dec 06, 2008
    You guys have been great and everything you have suggested has worked. It's just my TV won't cooperate. To be honest the TV is reallly making mad.....
  • 1,030 Answers
Audio is controled on the small signal board. if you had sound for a week after you replaced the fuse. I do not believe it is related to fuse. audio is generate on that board. there are two small connectors usally with a red and green mark on them that go to the speakers. make sure those are not lose. Your speakers could have blown. Also check in your settings make sure the amplifer is set to internal and the speakers are on. If after all those items have checked then it comes down to replaceing the small signal board. Something that requires a tech with a special computer.
Posted on Nov 22, 2008
  • Willie Howell Nov 22, 2008
    yes on the green board top right may be under a board that sits on top
My model nn-p295wf microwave stopped working ,all power just stopped, about a year ago. I took it to a repair shop and they replaced the DIODE and the fuse, then it worked again. Afew weeks ago it happened...
Replace the magnetron, safety fuse and diode as a set and check the door interlock switches.
That should get it working for another year or so.
Don't forget microwave mains fuses are special sand filled and semisurge type.
Nov 16, 2010 | Panasonic NN-P295SF Microwave Oven
Bows at top and bottom of screen double picture color is everywhere
ok this sympton sounds like a complete faliure of the convergence cuircuts. First thing I look at when I get one of these with these sympton in at the shop is = go to the setup menu and see if you have the convergence option in the setup menu. if you do not then you might have a common problem called the fl231 fuse problem. If you do I suggest reading the article fl231 fuse problem in te tips and how to section of this website. If this is not the case then you have lost power to these compents and will have to replace these cuircits
Oct 11, 2010 | RCA HD52W59 HDTV Projection Television
Hd52w59 Convergence - DL231 replacement
DL231 is a fast recovery diode and should only be replaced with another MUR160 diode.
Mar 01, 2010 | RCA HD52W59 HDTV Projection Television
I have an IMODE IP215 that has lost sound. Any suggestions
i am in Colombia, and year ago i bought in USA at Circuitcity (Miami) an Imode Ip 215 Clock Radio with IPOD dock station for a nephew gift. It functions several months without any problem but suddenly it does not sound anymore. A technician examination determined that the problem was not the volume control as i though but the CD8227CP Integrated . The Headphone jack always worked fine in spite of that problem, though the volume was fixed..
Idon't know if this common problem of the Imode devices mut be due to a defective or bad quality sound piece
I hope this help you to determine thereal problem.
my mail:
Dec 18, 2008 | Audio Players & Recorders
Me again TV is driving me crazy....
Ok let see what we can do. These rca can be trouble. Im a technician and i see these alot. I guess that a good recomendation for these set LOL. First question. I take it you had the FL231 fuse problem... YOu replaced the fuse did you do the most important step. RESOLDER the flyback connections. i beleve that is step 7 in the instruction. this is the main reson this fuse blows. i have run into only one other case ...out of the hundreds of fuses i have replaced where the small signal cuircit board cause it to blow. but like i said very rare. i used to just put that fuse in and not resolder... it would come back to me within a day. LEt me know what happens
Dec 06, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 wave
OK those are the correct fuses one in middle does cause lost of convergence FL231,recheck second ribbon connector, make sure it is in correctly also ck cp 150 it will be a green and gold writing on capacitor 2200uf 16v ,see if it is bubbled on top if so replace it and 2 other caps 220uf 35v,what you are saying about it waving could be a big capacitor on small AC board where ac fuse and cord plugs into ck them .Let me know if you need more help . Resolder all connection pinns on flyback.
Dec 03, 2008 | RCA HD52W59 HDTV Projection Television
Hd52w59 convergence fuse
convergence fuse is FL231 it will be middle one next to Flyback transfomer there is 3 of them small brown in color it will be the one in the middle 0.6 volts if bad it will cause lost of convergences
Nov 23, 2008 | RCA HD52W59 HDTV Projection Television
Liquid spilt on front of RCA HD52w59
Hello billew0481,
This might be a switching power supply problem. Since whatever may have spilled got on the broad and over time dried and shorted something out. While this is a possibility, I think that in this case the two incidents are not related. I think that you do have a power supply issue but the spill is not related. Is it worth fixing, That's up to you to decide the only thing I can do is to tell you what the problem may be and give you possible prices. For this job you are looking at a high end payment of $1000.00 if the IHVT, HOT, and High Voltage Tripler (along with associated circuitry) is defective. However it could be as simple as a fuse being defective. What I would suggest is getting an estimate based on a technician troubleshooting the Tv and determining what is wrong. at worst you'll be charged $100.00 for the house call. It's up to you then to decide to get it fixed or not.
I hope this helps,
Thank you,
Jul 02, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD Projection TV Model HD52W59
you have a fusible link that has blown. This is what causes the convergence option no be erased from the menu. You will need to locate the blown link and replace it. They are identified by FLpreceeding the location number on the circuit board such FL221 and etc.
Mar 23, 2008 | RCA P61927 61" Rear Projection Television
Did you chane your ICs recently? If so did you replace the resistor near the ics? These resistors often fail and if you replace the convergence ICs without replacing them they will take out the new ICs quickly.
Jan 27, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
60 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
