Question about Apple iPhone Smartphone
Phone will not power up
I changed the setting on my sim1 to highspeed and phone turned off. it will only power up if i am connected to usb. i dialed *#36633 to get setting now can not do nothing
  • 21 Answers
Pu the phone into recovery mode and restore hold home + sleep button down and plug into itunes and rstore
Posted on Nov 22, 2008
Blackberry w9700 dual sim. it says "not allowed to dial." how fix this? :(
You should be able to reset your phone by taking the following steps:
Turn on your phone, and go to the dial screen by pressing the GREEN phone icon.
In the dialing screen type the figures *#3646633#
The phone should go into engineer mode. Scroll to RF (radio frequency) test tool, this is the 10th option and will be in the second screen.
Select the RF(radio frequency) test tool option and then select the GSM option.
When a message appears hit ok to verify.
Go to the power scan option then select the band option. Click on the right arrow till you see DCS 1800 . Press OK.
The phone should enter into scan mode, wait a few minutes until it appears to have stopped, if it hasn't stopped within a 10 minute time frame proceed to the next step.
Plug the phone into a computer via a USB connection.
You will see the following options.
  • Mass storage
  • Webcam
  • COM port
  • PictBridge
Ignore all choices (!) and press on the RED (cancel call) phone key.
The phone should power OFF at this point.
Switch the phone back on and go into the settings menu
Select network setup
Select prefered mode, select GSM preferred and press OK
This step is crucial. If the change does go through you'll see mode switching to GSM, then to OK.
If it goes through smoothly go to Settings again, and click on 'Restore Factory settings...
If it the phone doesn't accept the setting you'll see mode switching then it will display UNFINISHED.
If you see that message, please go back to the first step and do everything over again. The definition of madness is doing the same thing again and again and expecting different results. But it's worth a try.
You'll be asked for a password. The password is 1122. If that doesn't work try 1212, 0000, 8888, or 1234.
A message will appear. Click Yes.
When the phone starts up again, you'll see a Chinese message. It's asking you to click on the screen for screen calibration. Click on the touchscreen.
Once that's done you'll be shown to the main menu.
Oh No! It's In Chinese!
Fear not...
To change the language back to English, just go to SETTINGS (the gears/cogs icon).
Then choose menu item 4, then 3 and you'll be able to choose English.
Still more steps...
Go back to SETTINGS, then NETWORK SETTINGS, then click on SIM1 network setup (or SIM2 network setup depending on which slot you previously put into WLAN Only).
There you'll be shown two choices: Network Selection and Preferred mode.
Make sure that Network Selection is set to AUTOMATIC and not MANUAL. If it says MANUAL, go in and change it to AUTOMATIC.
As for Preferred mode it should say GSM Preferred. If not please start the beginning again.
Dec 03, 2010 | Dual Electronics CECT P168 Cellular Phone
Purchased B5722 samsung cell phone yesterday. Kindly assist me in solving the following problems: (a) Cell Phone Sim1 and Sim2 both reject calls made from residence Landline, but when calling from Sim1...
Dear Please find the answers below:
(a) Cell Phone Sim1 and Sim2 both reject calls made from residence Landline, but when calling from Sim1 and Sim2 to residence Landline, both calls go through.
This is actually the problem of service provide I think as this some times happens with me as well, try other landline nos, if it works it is not the handset problem.
(b) To set Ringtones to Call Alert Sim1, tried: Menu - Settings - Phone Profiles - Normal - Voice Edit . The screen does not change on pressing Voice Call Ringtones. Spent countless hours trying to set Ringtones for incoming calls of Sim1 & Sim2, Messages alert for Sim1 & Sim2, but did not succeed
You have to do as follows: Menu - Settings - Phone Profiles - Normal - Edit - Voice Call Ringtone - Music - Card / Phone and chose your required Ring tone.
(c) Could not clear multiple Icons overlapping each other on main screen.
You have to tap on the Screen the Widgets will come on left side. Put your finger on the Icon - Icon will increase in Size - now without picking the finger from Screen just drag the icons on the Left Widget Slider bar, it will go on it.
Prompt reply shall be sincerely appreciated
Hope this will help.
Nov 29, 2010 | Samsung B5722 Cell Phone
M001 Phone when trying to make a call it says : NOT ALLOWED DIAL"
This is for another similar clone marked with the "vaio" name but it might be useful to someone out there. I found that by following solution one above (thanks Mrfixit) to step 6 as below and then following the second part of what I found at http://chinamobiles.org/archive/index.php/t-16088.html worked for me. I reproduce the steps below:
1. make sure to have 2 sims in phone(do not use 3g sims) 2. make sure wlan is disabled 3. enter engineer mode (type in *#3646633# 4.scroll up not down to number 10 RF test tool 5.choose gsm touch ok verify ok touch power scan 6.select band dcs 1800 press ok phone will go to test looking for DES(frequencies) wait until phone crashes or seems inactive
BUT THEN
Connect your mobile via USB cable to a PC, DO NOT CONFIRM any connection mode at your mobile, just and ONLY connect the cable!!!
11. Press the Menu button (second from the left, the one with the seven small dots on it) until you are at the main menu with the 12 icons on the display.
12. Go to "Settings" --> "Network Setup" --> "SIM1 network setup"
13. Go to "Preferred mode" and choose "GSM preferred" or "GSM only"
14. The mobile will switch to your selection, but the message that it will stays on display. Do not press anything else, just wait for about 10 - 15 seconds.
15. Disconnect the USB cable from the phone, it will show you that it has switched to your selection.
16. Get back to main menu, switch off and restart the mobile --> DONE
Sep 22, 2009 | Cell Phones
"Not allowed to dial" new c5000 wi-fi phone
Guys I had the same problem with the k599 Sciphone and none of the solutions found on the internet helped me. New chinese models tend to restart after testing is over and this results in turning the wifi application on. So I spent many hours on thinking how to bypass this function and this morning I woke up with an idea that really worked!! The steps are quite similar with the ones followed to debug older models:
put 2 chips on cell
Disable WLAN.
1-enter in factory mode *#3646633#
2-go to RF Test Tool
3-choose GSM, confirm OK!
4-go to Power scan
5-Select Band DCS1800 click OK
6-the cell frozen
7-wait for 3 minutes testing
8-while testing connect to a pc using the USB cable (do NOT select ANY of the options appearing on the cell screen)
9-Click the CENTER button of the cell until you go back to principal menu
10-go to settings/network settings and choose GSM Preferred or any other option (except WLAN only!!)
In this way the cell does not reboot, and the wifi application stays off, so the option can now be changed...
Hope this helps!
Greetings from Greece!
e-mail me to akiss_bd@hotmail.com if any questions..
Sep 03, 2009 | Dual Electronics CECT P168 Cellular Phone
"not allowed to dial"on f003 phone
hi mate,just follow these instructions 1. make sure to have 2 sims in phone(do not use 3g sims) 2. make sure wlan is disabled 3. enter engineer mode (type in *#3646633# 4.scroll up not down to number 10 RF test tool 5.choose gsm touch ok verify ok touch power scan 6.select band dcs 1800 press ok phone will go to test looking for DES(frequencies) wait until phone crashes or seems inactive(can take 3 to 15 min) press the end button (red one) phones with one middle button use that one phone will go off turn on phone and it will be reset to flight mode....(you can try to make call to verify,phone wil say cannot make call,not, not allowed to dial like before) go to settings and network setup,sim1 network setup,prefered mode and select gsm prefered...(phone will now change mode unlike before saying unfinnished) try the phone to make a call (should be no prob now) not finnished though .... go into settings again select restore factory settings (password 1122) wait for phone to restart...now its all done .....now you can change your tones and turn wlan on etc do not for any reason select wlan only or gsm only again...
Jul 19, 2009 | Dual Electronics CECT P168 Cellular Phone
Cant make or receive calls
are you in network coverage? if so then software problem best to phone netwok operator
Jul 12, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Mi F003 show the error NOT ALLOWED TO DIAL tis is a video of the error: http://www.youtube.com/watch?v=bhJj21J6z_M Thank´s
put 2 chips on cell
Disable WLAN.
4-go to Power scan
6-the cell frozen
Hope this helps!
email me to akiss_bd@hotmail.com if any questions
Jun 30, 2009 | Dual Electronics CECT P168 Cellular Phone
HOW TO DEACTIVATE IP DIALING IN CHINESE ALFATEL H1 ?IP DIALING IS ACTIVATED IN MY PHONE IN SIM1 AD 2?.HOW CAN I DEACTIVATE IT?I DONT WANT THIS.
Jun 26, 2009 | Handmark Software MobileLists (950142) for...
Internet promplems
for dial up simply a modem .... on laptops if you do not have a builtin modem you can purchase a pc-card modem that goes into your pcmcia slot ... for highspeed either a ethernet (same option as modem) but almost all modern laptops have a built in ethernet ... or usb ... also I highly recommend a router if you are going highspeed ... even if you only have one computer ... a router will protect your system because it provides a NAT firewall. If you go with a router make sure to set up the internet connection on the router do not tunnel through the router with a PPPoE connection
Mar 30, 2008 | Computers & Internet
Apple iPhone Smartphone Logo
20 people viewed this question
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
