No picture on my hitachi
Hi, I received a new bulb it appears to be the correct bulb but didn't fit so I put the old bulb back in...now all I have is a red light. Is it because I wasn't careful with the old bulb? I wasn't rough or anything. The new bulb has feet on it and didn't fit in like the old bulb. But the web site showed it as the right one. Should I try again to use it? 60vs810 Hitachi
  • 129 Answers
SOURCE: problem in Hitachi 53UWX10BA
The convergence ic's, and related components that could'be affected need to be replaced cost to repair 250.00 2hrs job max with alignment this depending on the tech. If you need more help let me know
Posted on Jun 14, 2007
acdr
  • 1913 Answers
SOURCE: hitachi 60vs810 blue screen only no other functions but on, off
check your power supply and eartihing probelm.
open the case of your tv and clear dust and also dry the all things amy be there is dust .
Posted on Sep 30, 2008
  • 864 Answers
SOURCE: Picture intermittently goes dim.
How many hours on the lamp timer?  If 10,000 or more the lamp is approaching end of life and should be replaced.  Lamp will dim when approaching end of life rather than just go out.
Posted on Jun 03, 2009
SD Tech
  • 14553 Answers
SOURCE: hitachi 53fdx20b picture is red
This is a set first made in 2002. I have seen a few of them with too much red.
Most likely what is wrong is the RED SCREEN CONTROL. It is located behind the front grill assembly at the front of the set. Screws usually secure it from the back on either side and then it pulls off--held by pegs usually.
Behind it is an inspection plate with several screws. Behind that is a BLACK block about 3 inches square with six controls(everything is black) One row of three will be marked FOCUS--stay away from those. The other row will be marked SCREEN.
With a flashlight you will have to look closely at the two rows of controls--they will have r,g,b marked next to them. (red, green, blue)
If you go to a Black and white program and the background is redish etc--take the set to a unused Video input2_bing.gif and after you locate the RED SCREEN CONTROL turn it slowly (less than 1/8 of a turn) to the left---the idea is to adjust just until the screen does not show red---on a blank input it should be black.
Double check it on a Black and White program and then if it was the problem the color should now be normal.
These sets did have some problems with that Screen /Focus block going bad--the entire block costs under 25 dollars and all the wires on the back of it plug in; if you have to keep adjusting it over a short period of time replace it or live with it.
I do this here for free so if this has helped you rate this solution as I do this here for Free.
SD TECH
Posted on Nov 30, 2009
ladywinn
  • 5138 Answers
SOURCE: hi my hitachi 61sdx01b red power light is working
CK fuse F903 if it blows it again then replace STRM6511 CK all of the pico fuses 5and 6 amps they look like resistors they willbe green or yellow they are fuses.
Posted on Dec 21, 2009
Brought LED back light the wires black,red,yellow, the old back light on my bike as two bulbs with six wires 2 x red 2 x blue 2 x black n yellow.three too each bulb when i connect my new light too bike...
Hi, firstly dont think for a miniute that the black wire on your new light is the earth, using the battery as a power source put one of the wires to earth and the other to live, as the led light will only work if the power is conected to the rite pole it is important to establish wich of the new wires is earth, you may have to swap them around to get the correct order, and then conect each of the other wires to the batt poss to check the lite works,when you are happy you have the correct order you can fit it to the bike, on the kawasaki blk and yellow is earth , although you have 6wires they are only 3wires in the loom wich double up to 6 for the 2 bulbs in the lite unit, you can leave 1 of eah colour disconected,
Mar 12, 2011 | kawasaki VN 750 Vulcan Motorcycles
I have a hitachi 55vs69 projection television. Lately, it has been shutting down every 15 minutes or so. The screen turns dark but you can still hear video until about a couple minutes later the led light...
First step is to unplug the 120 vac power for a few minutes to clear any corrupted data that may be present in the controller circuits.
If a "power" reset doesn't help and the lamp or bulb is installed correctly, you most likely have a failed replacement bulb. The symptoms are all standard indications of a failed bulb.
Reduced lamp life can be caused by:
  1. Lightning and other 120 vac power bumps.
  2. Collisions with vacuum cleaners or other incidental impacts while the TV bulb is operating.
  3. Starting the TV without a complete cool down. Bulb will consume a small amount of mercury with each start. Excessive consumption occurs when bulb is "Hot" and turned on.
  4. Wrong bulb installed as replacement.(Philips original replaced with Osram or El Cheapo)
  5. Poor quality or damaged bulb installed as replacement.
  6. Bulb damaged during replacement
  7. Bulb installed incorrectly at replacement.
Almost all Hitachi 55vs69 "No Picture" failures are related to the bulb.
Many of our service events are with customers that purchased El Cheapo bulbs from "shopping cart" websites or picked up a bulb from a small "local" TV shop. Many small shops stock of 3 or 4 bulbs and try to substitute or cross reference to fit more than 200 models of TVs from 7 different manufacturers. If a premature bulb failure occurs, they have the opportunity to sell you some expensive service.
Go here to see all of the different Hitachi TV bulbs that are available in Canada.
Find Your Lamp
Use the correct bulb for your model and if you are uncomfortable with the replacement procedure, get local service.
Jun 08, 2010 | Hitachi 55VS69 55" Projection HDTV
I have a 50vs810 dlp. The blue and red lights flash in sequence when I turn it on.When they stop flashing the red light for the lamp is on. The yv has no volume and no picture. Is it just the bulb or does...
More than likely, it is the bulb. My hitachi 50v715 would come on(light up and show picture) 3 to 30 sec's with out the lamp indictor even lighting up. Put a new bulb in and works great. So I would try a new bulb. Look in your manual for the bulb number. Buy an original hitachi bulb they last a little longer.
Nov 05, 2009 | Hitachi 50VS810 50" Rear Projection HDTV
Purchased a new bulb because my old one was starting to fade this will be bulb number three received a new bulb for my infocus 61md10 install was very easy no problems beautiful picture as usual after 45...
This is an ATC323H Chassis. The DM module could be the problem. Here is a factory Troubleshooting guide to confirm the correct operation of all of the Light Engine circuits. Be careful on this one because there is 20,000 volts present to fire the Lamp. You should call a good TV Tech in my opinion.
http://www.repairworld.com/index.php?act=Attach&type=post&id=14822
Jul 30, 2009 | InFocus ScreenPlay 61" Rear Projection...
Poss. convergence problem with Hitachi 53UDX10B Ultravision
You have convergence problem. Either bad connections on ics, ics are bad or voltages to convergence circuit are missing. There are no bulbs in this set. 3 picture tubes,red,green and blue produce a picture than when alighned(converged) correctly on top of each other gives you a color picture.When not you get the effect you are describing. Frst you can try the magic focus in the menu.
Apr 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
I can't seeem to find out how to put the new lamp back into the t.v
if this is either of the 51" or 56" DLP tv's, it is very simple.
-Make sure tv is UNPLUGGED!
-Open the side compartment on left side of tv as you are facing it from the front.
-Take off the door and you will see the lamp housing.There are 2 screws facing you.Unscrew these and set the screws aside.
-Now pull on the housing a little and it should slide out.You may need to wiggle it a little.
-Set housing down on table or somewhere with good light.Make sure not to touch bulb of either the old lamp or new as oils from fingers can distort picture.
-Now,undo screws on shiny metal piece.There are 2.Take off metal housing piece.
-You now see the back of the bulb.If you look at the lamp from the front,you will notice where the 2 wires are fitted into a bracket with 2 screws.
-Unscrew those screws to loosen the bracket.The replacement lamp should have the exact same bracket.If not you can just undo the wires to the old lamp and connect the same wire harness to the new one.
-once the wire bracket is unscrewed, pull it out of its fitting and then unscrew the 4 screws holding the lamp in.
-Take notice of how the shiny metal clamp-fitting is situated to hold the lamp in place so you can put it back on the right way.
-Once loosened, the bulb should be able to come out and you can put the new one right in it's place. Make sure to keep the top wire connector on the bulb at about 11 o'clock and that a nub on the bulb fits through a spacer on the shiny metal clamp-fitting.
-Now tighten the 4 screws on the clamp-fitting and make sure the wire screw connectors on bulb are tight as well.
-Take the now loose rubber-covered wires and tighten them into the bracket-fitting the way the old ones were,with plugs and lamp facing the same way.
-With everything now tight,put metal housing back on and tighten the 2 screws down.
-Take the whole unit and slowly slide it back into the tv making sure that the plugs slide into their rightful place.This should be easy,but may require a wiggle or two.
-Now screw in the 2 screws you have left into the plastice mounting piece. Re-attach the door and plug the tv in.Wait a few minutes and then turn on tv.
-It should work.If not, unplug tv and check all connections.
TIP:Do not put a cold bulb in and then turn on immediately.I like to let the bulb sit in the tv with it plugged in for a while until the bulb is warmed and ready.
Good Luck! -Chris
Mar 10, 2009 | Vivitek V37835 46 in. LCD Television
My hitachi 50v720 bulb blew and the replacement doesn't fit
I have a 50V525E and I have the same problem....My bulb is suppose to be a LM500 and I received a P22 Phillips (And I did check their web site and that is the bulb they recommend), and like you said...The 4 little glass tabs will not allow the bulb to sit flat in the housing.....
I am waiting for the vendor to answer my inquiry...But I recommend to anyone ordering a bulb...Ask if it is Phillips, and if it is...stay away.
Steve
Jan 23, 2009 | Hitachi 50VF820 Projection TV
I believe the lamp you need is the UX21516. not the 21517
I have a 50VF820 and this is the lamp for it.
By the way my unit just hit the 3 years and the lamp just blew as well.
Dec 14, 2008 | Hitachi 50V720 Television
Blue Haze in middle of screen vertical
There is no solution with Hitachi products.
If you have read many of the posts, you would have known not to buy Hitachi Telivisions or like me avoid all Hitachi products. There help line is not very useful, they just blow you off. I have never had a worse experience with other manufacturers. Take Onkyo for instance, they had a problem with a chip in their THX receiver and it was a year later ... I called their help line they located a repair store about 40 miles from where I live (in Texas that is not very long) and got my receiver fixed and this was 8 years ago.
Also use Consumer Reports to check the frequency of repair record for the product you are going to buy. In Plasma - Panasonic is a safe brand, in LCD's Sony or Samsung have good repair records.
Research the product before you buy it, avoid walking into a store have the salesperson direct you to a product. And then you save money if you order it online. Amazon online is very good.
Nov 10, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Problems with my 50 inch hitachi ultravision projection screen tv
the best thing 2 do is buy a new one and get guarnteed with it again
if u try 2 fix it it not 50% working
if u got guarnteed then take it back (or phone them to come)
Nov 07, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
