Question about Mitsubishi WT-46805 46" Rear Projection Television
Tv has no power and will not power up
I have a 1998 mitsubishi 50 inch rear projection big screen tv i purchased it used and it worked fine for about 5 hours then it went dead no power at all i then discovered the picture tube the blue one had been linking fluid on the middle circuit board and burnt a little brown thing i,m not sure what,s called but it,s brown with two prongs that is sordered to the board well one side of the little brown flat piece was burnt loose from the board i sordered it back and got power back and watched it about 2 more weeks it had a great picture sound and all but after that none of the buttons would work the tv such as power channel up or down buttons would not work the tv but it still had a good picture and sound but when i unpluged it it will not power back up no power at all help me help me
  • Anonymous Dec 25, 2006
    the tv problem posted by zippo about the 1998 mitsubishi that wont power up is a model no vs-50603 mitsubishi this was added by zippo the owner of the 1998 mitsubishi
  • SunTzu Jun 20, 2008
    I have a Mitsubishi WT-46805 48 in., Rear Projection TV which has sound, but not picture. It has been suggested by a technician that the problem may be in the power supply, but that was just a guess.
  • 734 Answers
First: Check the power outlet. Check it with a good lamp so you know you are getting power to the set.
Secondly: Check the power cord. Wiggle it around the molded ends to make sure it is not open inside the molded portion of the plugs.
Thirdly: If you know for sure the set is getting power and still no indication at all (you should be getting some little light on the front panel; standby indication) then there may be a fuse on the back panel or just inside the back cover (you will have to remove it; after unplugging the power cord) that needs replaced.
Fourthly: After all these checks if you are getting nothing, you may have some failure inside that is very serious. Normally we do not recommend serious repairs to a set over 4 years of age. This is because the set is likely to develop some other problem soon after the repair is made; further, the repairs are getting more expensive day by day while the price of new sets is coming down dramatically. Lastly, the new sets have better picture, longer lasting circuits and better features.
Hope this is a good solution for you.
thanks for your questions.
Posted on Dec 02, 2008
This problem has been resolved please give me a solution to my other problem i have posted on this same 1998 mitsubishi
Posted on Dec 29, 2006
SOURCE:
Mitsubishi VS50605 rear projection TV won't come on
The power supply caps in the light engine power supply were faulty when they were installed. You need to remove the power supply and take it to your local electronics shop where they can remove the (7) faulty 1000uf 16v electrolytic capacitors and insert new ones. If you remove the power supply yourself (takes only a philips screwdriver) and reinstall it yourself, the electronics shop shouldn't charge you for more than an hour worth of time. The caps would be about $10.
Here's a photograph (thanks Don Crawford).
Nov 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi 50 inch projection tv
you probably have a problem with the convergence board.
Video
What kind of input are you using
Nov 05, 2017 | Mitsubishi VS-5043 50" Rear Projection...
Hitachi 51F510
Have you tried the MFGR's authorized centers?...accordianman
Feb 11, 2008 | Hitachi 51F510 51" Rear Projection...
Wavy picture on television screen
First do the self test on these threads or goto ctechnicians.com
Dec 29, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-585R
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Dec 21, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Protective screen
I replaced the screen on my 62 inch big screen for about $50 and the picture is very good! You simply need to purchase a piece of plexiglass from a glass shop or hardware store and have it cut to the EXACT dimensions you require for your TV2.gif. NEXT the plexiglass must be FROSTED. This can be done by a fine particle sandblaster or power sander with a fine grade paper. I used a power sander and sanded BOTH sides methodically and vertically on BOTH sides. I recommend buying a couple of 12 inch wide strips to test which method pleases you most by placing them in the path of the projected image where the old screen was removed. In any event, I recommend frosting BOTH sides.
Nov 01, 2007 | Hitachi 51F510 51" Rear Projection...
Mitsubishi model vs-70707
You can contact mitsubishi At 1-800-332-2119 and they will direct you in the right direction. Good Luck
Apr 08, 2006 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi WT-46805 46" Rear Projection Television Logo
107 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
