Question about Jenn-Air JDS9865BDP Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
OVEN KEY PAD FROZE UP AFTER PUSHING CANCEL ACCIDENTALLY
I just got my range two weeks ago and successfully preheated to convect bake. I went to set the timer and accidentally hit 8 hours instead of 8 minutes and hit cancel instead of back or timer again. Now my key pad it totally locked up and nothing will unlock it. HELP. Did I do something when I hit cancel.
bigg t
  • 640 Answers
SOURCE: Convection oven not working properly???
your correct the only difference between a regular oven and a convection oven is that it has a fan.when you open the oven door the fan should be spinning to a stop if this is not the case you may have a problem with the fan.
Posted on Aug 15, 2007
SOURCE: Cancel, convection bake, and bake buttons don't
Had to order a new membrane.
Posted on Jul 10, 2009
protek480
  • 1730 Answers
SOURCE: Kitchenaid electric convection range - preheats
Put an oven thermometer in the oven on convection bake and check the actual temp inside. I'll bet it's not maintaining the correct temp in convection.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 25, 2009
EllaWatson25
  • 725 Answers
SOURCE: The convection fan does not
This is your convection motor that's gone out. If you will call or email us, we;ll be sure to send the correct motor along with the schematic for your Jenn-Air range. This is an easy problem to solve so please get in touch with us soon so you can get your oven running right again.Remember...Thanksgiving is just around the corner, so lets get you cooling again real soon. We hope to hear back from you real soon,
Posted on Sep 30, 2009
kdrake84
  • 262 Answers
SOURCE: i went to change the
This link will take you to your part drawings and wiring schematics.
Click on the link http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Range-Parts/Model-SCE30600W/1266/0124160?searchedModel=SCE30600&blt=
Looking at the schematics and the info you have provided the issue you are having is in the control panel Having the control take some of your commandsand not others,demonstartes the control is bad.
In most cases this is the most common reactions of a control board. The control will not very often completely go bad but just some of the options.
The control board is made of of circuits and relays. Each relay is responsible for different functions. In most cases the relay is what goes bad.
This link is the part that you need. http://www.repairclinic.com/Shop-For-Parts?s=t-%2071001799-%3d%3d They have a no questions asked return policy for 1 year.
Any other questions or concerns please post.
Keith
Posted on Mar 13, 2011
Err codeF2EO Stuck Key onContol panel touch pad
Hi have a nice day
F2 - E0 Oven temp too high
1. Test operation of door lock on self-clean
2. Test relay contact operation
3. High resistance in oven temperature sensor
Guruood Luck !!!!!!
Feb 16, 2008 | Kitchen Ranges
Aug 14, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
My stove and oven froze with an error of 5ab6 bath or 6ath wont do anything
Sabbath feature.
These stoves are programmed for the sabbath.
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 22, 2011 | Maytag MGR6775 Stainless Steel Kitchen...
The actual temperature (as measured by repairman's device) is 20 to 30 degrees lower than indicated on the control panel. Should the control panel be replaced in a 7 year old range or should the range be...
You can adjust the bake average temp +/- 35 degrees this is called calibration.
Here's How:
To Adjust: 1. Press the BAKE pad (upper or lower oven) and enter 550° F. 2. Press and hold the BAKE pad (upper or lower oven) for several seconds until TEMP ADJ is displayed. 3. Press the AUTO SET pad - each press changes the temperature by 5° F. The control will accept changes from -35° to +35° F. 4. If the oven was previously adjusted, the change will be displayed. For example, if the oven temperature was reduced by 15° F, the display will show -15° F. 5. When you have made the adjustment, press the CANCEL pad and the time of day will reappear in the display. The oven will now bake at the adjusted temperature.
Do this first and you will be back to normal. If your using a oven temp. checker make sure you let the oven cycle for awhile. Preheat should take about around 10min. Remember 350deg is an average temp.
Have a great day!
Dec 07, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Kitchenaid electric convection range - preheats just perfectly in regular bake mode, but takes forever on convection bake. This model has 3 elements - broiler, lower covered element and a convection...
Jul 24, 2009 | Jenn-Air JGS9900BDS Stainless Steel Gas...
Convection fan doesn't turn on
Found this site cuz I had the same problem- as your purchase was 4 years ago- not sure that I'll help you... But help others who are stumped... I pushed the QuickBake button to preheat then to turn the fan on I pressed it again... ( actually a couple times messing with it...) Once it gave me a " double beep" and sometimes just a single beep but none the less, the fan turned ON!!! Good luck!
Nov 18, 2008 | Frigidaire Gallery 30" Self-Cleaning...
Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Jan 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air JDS9865BDP Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
