Question about JVC AV-32D502 32" TV
Help ,help. When I push the power button, on the tv.the button flashes,tv make noise , and then goes out.if you push button alot it sound like it might ,but will not. remote will not turn tv on also. Tv is four years old. Could someone give me idea what it could be .Thank you,
  • joesmalz Jul 16, 2008
    I turn TV on light keeps flashing, no picture or sound and I can't turn Tv off.
On- timer light flashing no picture no sound.
Posted on Aug 22, 2009
    Problem Solver:
  • 13 Answers
It looks to me that your tv is starting up and then shutdown. I have suspect that your tv have a high voltage shutdown. Check your B+ voltage, if not correct rectify it. If it sound like gibridge to , then seek professional help. good luck
Posted on Dec 23, 2006
I have a Kenmore elite washing machine and when I power it on it goes on . then I push the start button and I hear a humming noise and the timer is flashing . Please help.
oh oh a humming noise usually not a good sign, and usually is from a bad motor with windings that have gone out. in ur case u may be hearing what u think is a humming noise? but in reality may be a bad push start button which can sound like a hum but is more of a buzzing sound
Feb 19, 2015 | Kenmore Washing Machines
Recently we replaced the bulb in our LG 52SX4D-UB. Once the bulb was installed we reset the hours for bulb according to the instructions that we reviewed on-line. Once the power button is pushed on the...
Tv goes off and on.It have alots of clicking noise sounds too?Yes.The board that call the Ballast board it is also dead too.The Ballast board only job it is to help to ignite the tv projection lamp.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Apr 03, 2011 | LG 52SX4D 52" HDTV
I have a Toshiba 51h84.I push the power button and I get a solid red power light. There is a click from inside, kind of like a relay clicking on. No picture, no sound. If I leave it on I get an occasional...
Tv have "LAMP" indication LED light blinking?The tv projection lamp is dead,require changing.Hearing alot of clickings sound too?Mean the board,call the Ballast board is dead.Require change the Ballast too.The Ballast board,the board that help to ignite the projection lamp.
Aug 06, 2010 | Toshiba 51H84 51" Rear Projection...
Whenever i plug the unit in i hear a clicking sound from the back of the television it is for about 3 seconds and it usually takes 2-5 seconds before it starts the noise. The power light only comes on for...
Ur tv turn on now,hear alot of clicking?The tv LED light "lamp" on front panel flashes or light up?The tv projection lamp is dead.The Ballast board dead too,if hear alot of clicking?The ballast board help to ignite the projection lamp.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
Rca model D52W20BYX1 comes on for a moment then goes off rite away
rca model d52w20byx1 itc222. sounds like shutdown mode. Does the led flash. unplug the set leave set unplug for 30 min. this reset procesor. now i tell you this in the shop its never that simple but it first step. IF you have a flashing led when you push power button. it tells you alot. it tells you main fuse is good the processor is getting power and it detects something wrong. leading causes are shorted horzontal output transistor. shorted cp150 capacitor. technicians have a computer that read error codes much like that of a car. let me know if i can help troubleshoot it down.
Nov 23, 2008 | Televison & Video
RCA HDTV #D61W20, CHASSIS ITC222, Power button flashing 1, pause, 9. Possible error code 19, anyone know what this means
This is not a friendly chasis, the only easy fix that you might check on the power supply board and the left side (looking from the back) 3 capacitor (220,330,and 2200uf 16V) have the top pop up. Other than that poping, arcing noise, burn smell when first start up is bad york, Flyback Transformer and even the cooling leak for those tubes you will need professional TV repair man. Those TV picture not very nice anyway.
Nov 07, 2008 | RCA D61W20 61" Rear Projection Television
Flashing light - video going out
When you push Power Button on remote, TV goes to Standby state i.e its power light (LED) lit but no picture / no sound. Power button on remote has symbol looks like.. ( ! )
Aug 14, 2008 | Sony KP-53HS10 TV
Green Light Flashing in Power Button
so the sound of mouse click is from the button being pushed.
is the light flashing codes at you in the form of flashing?
looks like you may have a short in the p/s.
Apr 09, 2008 | Philips 55PW9363 55" Rear Projection...
Will not turn on?
the lightining battery is not working very well. You should exchange it, so the TV power could get to the Tv and let it Work.
Feb 28, 2008 | RCA F36685 36" TV
Flashing standby message.
Are any of the buttons not making a click feel when you press them like maybe one is stuck?? You didnt say if the same thing happen with the radio as did with the cd. If it is then a switch is stuck or bad or a problem with the switch matrix for the Microprocesor . Only way to trouble shoot this is I would use a scope and check all of the matrix {ie scann lines as well as input lines for distortion or noise and make sure when the buttons are pussed that they change and switch accordinly. If they dont then the processors bad. Good luck
Apr 23, 2006 | Sony DAV-SC8 System
JVC AV-32D502 32" TV Logo
189 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
