No sound from my laptop
I have a MEDION MIM 2120 and i have no sound coming from it. One day there was no sound.
  • Vincent Wright
    Vincent Wright May 11, 2010
    Verify that the drivers are installed. What operating system are you using?
3 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: fitting new screen medion mim 2120 laptop
I could not find a breakdown for you laptop. But from a picture I saw on the web, I could tell you that it is probably the same as most laptop. First, there are screws under the round inserts. You need to pry those up and stick the aside ,in order to put them back when you finish.
Then remove the screws, usually 4 on each corner of the screen. Some laptops have 2 screws on top of the screen near the latch.
Then you need to pry the front bezel off the screen. You can use a small straight screw driver. Carefully (as not to scratch the case) insert the screw driver and pry the bezel away from the back casing of the LCD.
Once you have the bezel off you will see the screws that hold the actual LCD screen in, remove them and lift the LCD out. You will have to un-hook the cable from the System board to get the screen completely out. Then install the new screen.
Please remember to rate all users who assist you for free :)
Posted on Oct 01, 2008
babes_ganda0
  • 381 Answers
SOURCE: Wireless connection problem with Medion MIM 2120
hi..go and try to find the (Control Panel) then double click the icon of name is (Network Connections) then find the wireless LAN connection..if you have wireless connection u need configuration..if not no have wireless connection you need re-install the LAN card driver..Thanks and good luck..^_^
Posted on May 10, 2009
I am trying to purchase a laptop charger for my medion laptop - mim 2310 pc notebook. can you please advise me where I can purchase one. Thanks
Two choices:
1) factory laptop charger: from factory website / phone number, expect to pay 70$ +.
2) Universal charger: from any computer shop. Check the packaging to make sure that your make / model is part of the supported tips that comes with the charger. $70 +
Jul 05, 2011 | Computers & Internet
My power lights keep going from red and green then they go off altogether. i have to fiddle around for a bit before the power comes back on mim 2120 medion laptop
Could be three things causing this. First, the DC jack soldered on the motherboard could be loose. Over time the solder will crack loose. Most likely this is the problem. Second, the AC adapter could be going bad. Finally, the battery could be going bad. Each of these items should be checked.
Nov 17, 2009 | Computers & Internet
Medion mim 2120 laptop
Hi
First i reccomend checking the power cable and seeing if there are no short circuits or breaks in the circuit. - to do this unscrew the end of the power cable - this part wares out often and costs about 50 cents to replace.
Hope i could help
CBZ
Comment if you need more assistance
Apr 27, 2009 | Medion md40298 Notebook
Feb 01, 2009 | Medion md40298 Notebook
Medion 2120 stuck on f2 screen
put the cmos battery back in and before you turn it on press and hold down the f2 key should send you to bios where you will have to reset all funcation becase you removed the battery
Dec 11, 2008 | Computers & Internet
Fitting new screen medion mim 2120 laptop
Oct 01, 2008 | Computers & Internet
Medion mim 2130 Laptop
Its not good idea to but your computer on fire, but i hope you didn't use real fire ;)
Sounds like some of your buttons are stuck on keyboard and need some cleaning.
Sep 01, 2008 | Medion md40298 Notebook
NO SOUND DEVICE FOUND AFTER RELOAD WINDOWS XP
hi reloaded windows xp on medion mim2220 laptop unable to find sound device to work sound for my laptop cant play any music can you help please
Feb 25, 2008 | Medion (40010998)
Medion mim2080 notebook
my sugestion is to leave laptop unpluged from wall and removed battery and leave to cool for 3 days and then check on the fourth day replace battery. and reboot laptop. if problem accures take to be repaired, as the hard disc may have over heated plus comntatcs for hard disc and motherboard this is the only help I can give I leave mine on for 5 -6 days somtimes then turn the thing off to cool down the other addvice is if it works get it a laptop cooler which it sits on and keeps it cool. best of luck on the laptop
Aug 13, 2007 | Medion MD-40954 Notebook
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
