Question about Digidesign Digi 002 Rack FireWire Pro Tools LE Music Production System Volume License for PC, Mac (MX002R)
Digi002 interface not powering on
When i engage the power button on my rack digi002 it makes a clicking sound and will not boot entirely. The small red light on the optical connector just blinks and i hear a clicking sound that i am concluding means the power is overloading OR the unit might for some reason not be getting enough power. Sometimes it boots after the 3rd click and some times it just does not boot and keeps clicking. I took the top off and noticed that a ribbon cable was pushing over a few capacitors but the problem still exists even when i made sure all the connections were fine.
thanks for caring !
  • 3 more comments
  • leafT Nov 30, 2008
    Digi002 makes clicking sound instead of booting up. Green light next to fire wire port blinks in time with clicks. I have been "hot plugging" the firewire cable for a year without realizing it would burn out the port, assuming this is the problem. I just read this hopeful note: " It took a year of hotplugging for my ports to break, but when they did it was easy to get fixed using the website." on a Muscian's Friend review... have not been able to trace this so-called easy fix. Looking forward to a reasonable solution!
  • Zoutman Dec 12, 2008
    I have the same problem with my 002 rack. When I turn it on and it clicks 3 times then the 002 works for about 5 minutes and then the sample rate light goes out again and the whole thing stops working.I have searched on google and I hear a lot about Firewire port problems, but I don't think this problem has to do with the firewire port. Any solutions wich someone with a little solder experience can perform?
    Thnx
  • Anonymous Jan 31, 2009
    I need help too. I heve the same problem!!!!
  • Ricfer Feb 25, 2009
    Exact same problem...Help!!!!!!
  • Anonymous Feb 28, 2009
    Thank you so much for your help! i cant wait to get home to try this solution. i bought my 002 off of ebay and the problem never acted up until it was a few weeks after the auction so i could not return it as DOA. thanks thanks thanks!
I just talked to Digidesign and apparently this is a problem with the DC power harness.  You can call them and they will send you a replacement harness at no cost, since it is a repair and a known issue.  Basically I was told that the problem was due to oxidation on the power contacts.  The oxidation prevents the unit from having constant power.  The clicking you hear are the relays going through the initial power sequence multiple times as they get power and then lose it again. In theory you could fix the problem temporarily with some contact cleaner.  They will be sending me a a package with the new (and improved) harness, instructions and contact cleaner.  I am assuming this will fix the problem once I get the chance to swap the harness myself.
Posted on Feb 26, 2009
Contact cleaner did the job for me. It took me 3 years to make it so dirty it wouldnt work anymore. I guess I can go on for another 3 years now :)
  • 3 Answers
Www.rainbowaudio.nl can provide you brand new power supply arhitecture, replacement for the old problematic power supply isue, digidesign will sound and work perfectly after our RAE Mod on 002 unit
Posted on May 23, 2012
  • 4 Answers
Musicians Custom Electronics in Chicago can fix it. 708 755 6960 is their number. Good luck!
Posted on May 01, 2009
My power steering is out what can be the problem
Usually the power steering pump is the most likely culprit. Check you power steering fluid level. If it is good and there is no power steering, then the pump is probably not pressurizing the system. It is doubtful that the fluid has leaked out entirely as most power steering pumps are lubricated by the fluid and total loss of fluid would result in a terrible shrieking sound and almost certain pump destruction. Other causes could be a bad or leaking rack. Look for leaks at the rack boots.
Dec 21, 2014 | Cars & Trucks
How to install the drivers for digi 002 on windows 7
Here is the official AVID page regarding the digi 002 drivers: http://avid.force.com/pkb/articles/en_US/Download/Digi-002-003-Drivers
Feb 05, 2013 | Pro Tools Digidesign Digi002 Mixer Avid
Pls give me the download details of stadalone digi002 driver for windows xp64bit
Below is the link for your requested download
Link for driver download.
Tell me how it worked for you.
I am following up.
Regards.
Aug 09, 2010 | Digi 002 Rack FireWire-based Pro Tools LE...
Turn digi 002 on and the mute light keeps stay on
I just had the same problem... It has to do with the connectors from the power harness. Found this on the internet and it did the trick for me...
It seems like it's only a matter of time before the digi002 (rack and non-rack) have this problem. You'll go to turn it on and the mute light turns on and nothing else. You don't hear the 3 clicks that you usually hear when turning it on. Your computer doesn't recognize it. Then you start swearing and promising to quit recording forever. After all that happens, you have 2 options:
1. call digidesign. they've been replacing the power harness (source of problem) for just about everyone, even if you're out of warranty and it's free (including the tech support over the phone). don't pay them anything. maybe shipping.
2. most people seem to have the same problem after a while after getting their new power harness. lots of people are saying it's not even the harness - just the connectors. so last night i had this problem and i opened up the top of the box and unplugged and plugged back in the little rubber-covered wires going from the power cord to the rest of the 002. turned it on. works fine. i may try to use some of that connector-cleaner from GC if it happens again.
so if you find this happening, don't panic. try the above. takes 5-10 minutes (only because of all of the screws)
Jan 26, 2009 | Digi 002 Rack FireWire-based Pro Tools LE...
Avalon pre amp AD2022
Take transcendecant out of main board, this will override the vu meter therefore solving your problem...
Jan 13, 2009 | Audio Players & Recorders
002 rack red light only
DSQRD here...
After disconnecting power source, I went back in and unhooked and rehooked the white plastic connector located at the front of the unit. It's in between the power switch and the mainframe and has about 6 wires through it. This time it worked and the 002 lit up. It's kinda humid in my studio and I think the connections film up easily. I plan to address that issue as well. It was a coincidence I guess that all this started the same time I hooked up the external drive. It through us off as to what had happened.
Good luck
Feb 23, 2008 | Digi 002 Rack FireWire-based Pro Tools LE...
About Digi002 rack..
no worries..when you talk about a rack, are you speaking about a mounting rack? can you provide the full part/model number for this device?
Feb 17, 2008 | Edirol UA-4FX External Sound System
No Audio
Hi, when the Technician repaired your system he has probably deleted the audio driver for your sound.
Take the computer back and insist that it be put right at his/her expense as this should have been done at the time of repair.
Regards mistyman
Dec 18, 2007 | Tascam Gigastudio 32 Sound Card
Digi002 Rack
Reinstall the driver with the unit dissconnected. Check to make sure your version of OSX is stable with your current version of Protools, especially if youve done any software updates.
Keep me posted.
Aug 30, 2007 | Digi 002 Rack FireWire-based Pro Tools LE...
DIGIDESIGN DIGI 002
www.rainbowaudio.nl : the new solid bild power supply as the part of the modification for your digidesign 002 solves power supply isue
Apr 01, 2007 | Digidesign Smack LE (RTAS + AS)...
Digidesign Digi 002 Rack FireWire Pro Tools LE Music Production System Volume License for PC, Mac (MX002R) Logo
2,101 people viewed this question
Top Digidesign Computers & Internet Experts
Marvin
Marvin
ali_zulfikar
ali_zulfikar
Zhenya Ogorodnikov
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
