I need to wire a cd player into a 1982 ford fairmont
  • 165 Answers
Hello pls be more specific saludos
Posted on Nov 22, 2008
I own a 1982 Ford Fairmont Futura. 200 6 cyl.80,000.one owner.. Power steering pump was replaced. Same problem, no power steering. Mechanic said rack/pinion,I say I got bad pump... Squeal constantly
A perfect pump will squeal... being improperly forced or
trying to work with a defective rack!
Might be tire to heed the advice of your paid professional...
(in my humble opinion)...
And don't forget those tie-rod ends & ball joints while you are DOWN THERE...!!
Rockauto.com: Parts & prices provided below
http://www.rockauto.com/en/catalog/ford,1982,fairmont,3.3l+200cid+l6,1127764,steering,rack+and+pinion+complete+unit,7388?a=Referer+www.bing.com+URL+%2Fen%2Fcatalog%2F
1982 FORD FAIRMONT 3 3L 200cid L6 Tie Rod End RockAuto
May 19, 2016 | Ford Cars & Trucks
Battery fitted to 1982 XD 4.1 fairmont sedan
call any batter shop and they will be able to tell you in less than a minute or as fast as a computer brings up the details
it will take a 12 volt batter around 600 cca but the shop will get it exact
Feb 17, 2016 | Ford Cars & Trucks
Need the correct diagram for distributor cap firing order for a 1982 ford fairmont straight six
The firing order for a Ford straight 6 is ( 1 - 5 - 3 -6 - 2 - 4 ) the distributor rotation is clockwise.
Feb 09, 2015 | Ford Cars & Trucks
Need free wiring diagram for 1992 EB Ford fairmont radio/dash
heres the ford wiring color codes for ford, please take a moment to rate my reply and research on your problem,, http://www.installdr.com/Harnesses/Ford-Wiring.asp good Luck,, Thanks
May 08, 2011 | 1983 Ford Fairmont
I need a wiring diagram for my heater/ac blower motor switch, the manifold is shorting out and i dont have any sort of heat in my vehicle. Its a 1982 ford fairmont, straight six 3.3.
2 possible solutions: Either pick up the Haynes manual from local parts store or Amazon.com or stop by local Ford dealer - parts dept should be able to provide or make you a copy of wiring diagram. Diagrams are getting hard to find free these days online and even harder for older cars.
Jan 03, 2011 | Ford Fairmont Cars & Trucks
How do i remove the 6 stacker cd player out of my au fairmont. cd's are jammed and i want to get them out. radio goes on and then goes off cos it try's to play the cd. cd's can not eject.
Have you removed the "trim panel" that surrounds the stereo? If not, do so 1st, then there "should" be 4 screws that hold the stereo in place, remove those 4 screws then pull the stereo forward (towards you), next disconnect the "bulk wire harness" connected @ the rear of the stereo along w/ the "antenna" cable and you should be home free from there. let me know if this helps.
Mar 26, 2010 | 2000 Ford Expedition
Stereo
if you have not cut the factory connectors off of the car, go to any store that sells radios and buy the connection plugs, they are about $10. the packages list what car each one is for.
If you have cut them, get back to me and i will give you the wiring specs.
Jul 26, 2008 | 1983 Ford Fairmont
I have a Ford AU Fairmont fitted with a Ford Radio/6 CD disc player.The radio works well but the disc player will not load or unload and there is no indication as to what discs are loaded.This action took...
more than likely something got stuck or broken ..
You will need to open it up and see if there is anything you can notice that may be causing the problem. more than likely the loder. if you think you can move it back into place or frmove the jammed components then by all means do. if not take it to an electronic technician.
Jul 20, 2008 | Car Audio & Video
Ford AU11 Fairmont CD Player / Radio
You need some special tools which slot in to the holes at the sides of the stereo, they release some clips and the unit slides out. Then you can take the cover off the unit and remove the jammed CD. These units are notorious for failure, especially the six disc stackers, and are probably not worth repairing, can be more expensive to repair than fitting a decent aftermarket cd player. Most audio installers or your local Ford dealer will have the tools to remove the unit, and if you just want the radio, you could remove the jammed cd and refit the stereo and just not use the cd player. You'll need to get the radio code from a Ford dealer to get the stereo going again if you disconnect and reconnect it. They may need the serial number off the unit to give that to you, and you may need to prove ownership of the vehicle.
Jun 26, 2008 | 1983 Ford Fairmont
 Grubhead
Grubhead
