Question about Samsung Digimax A400 Digital Camera
Memory card problem
I have had my camera for a year now, and i used it yesterday and it was fine, and then put the memory card in one of those machines that prints off ur digital photos, and that all worked fine too. today i put the memory card back in my camera, and it wouldnt turn on. but when i would take the memory card out, my camera would turn on and work fine. WHAT THE?? please help, i dun wanna have to get a new camera. xx
    Sergeant:
    Champion:
  • 326 Answers
Hello traceyyyyy, you do not have to by the new camera. Just buy the new memory card. Best regards, Arpad
Posted on Dec 23, 2006
SOURCE:
Pictures not going to memory card
What make and model camera?
Try downloading all your pictures from the card to your computer and then reformatting the card. Alternatively, try another card. What happens then?
Mar 06, 2013 | Cameras
Card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here. If these don't help, and you do end up having to format your card, see the recovery software, along with the corrupted card procedures in this blog article.
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
HI! I have a one year old Lumix DMC-FS15 that I barely used for some personal photos, I bought a 4 GB SDHC memory card with it, it used to work just fine but now whenever I turn o the camera I message...
If the memory card works on your pc, chances are it is fine.
So you have two things to do : first backup on your computer any picture on your card.
Secondly put it back in the camera, go into the menu and find where to Format the card.
Once the card is formated by the camera try to take a picture to see if the problem is solved. If not, look through your camera menu, certainly under "memory setting" or something similar, then you will have an option to choose on wich memeory the pictures are recorded: the internal one or the card.
Make sure your 4gb card is selected. This shoul solve the issue.
Hope this helps.
May 27, 2011 | Panasonic Lumix DMC-TZ50 Digital Camera
My Nikon d40x is roughly three years old and the lens has had to have been repaired twice due to it being dropped. Lens is working fine though now. Yesterday i was getting out my car and the camera fell...
Time for some "tough love"...suggest you buy one of the new Pentax point-and-shoots that are especially made for people who continually drop their cameras. This one can be dropped from 3 feet and still work. Leave the good DSLRs to the rest of us.
Jul 11, 2010 | Nikon D40x Digital Camera
File error
I think you memory card slot in the trouble, if you have try to use another memory card and the result is the same. You can try to clean up your memory card slot.
Jul 24, 2009 | Samsung Digimax S630 Digital Camera
Memory Card is Full error message
The camera uses either SD or MMC cards, it is likely you bent or broke one or more of the connector pins in the camera..Bent pins usually break if you try to straighten them.
Repair costs will probably cost as much as a replacement new camera. On eBay you can buy a C330 for $10-
$40.
Sep 04, 2017 | Kodak EasyShare C330 Digital Camera
Memory card is write protected
SD cards have a slide switch along one edge. Slide it away from the contacts.
Nov 21, 2008 | Nikon Coolpix S51c Digital Camera
Sanyo camera will not turn on battery is fully charged
First you check ur battery power still constant if not check ur memory card .Empty. ur memmory card through another card reader then on ur camera without putting MC.
in this way ur probleum will solved.
thanks.
May 11, 2008 | Cameras
Does not turn on
Get another battery - it is possible the replace is stale/old/dud. Check the cleanliness of the contacts on battery and the camera, a light polish with tissue- sometimes if the camera has not been used for a with a slight patina of dirt/corrosion will build up to prevent contact.
May 08, 2007 | Nikon Coolpix 2100 Digital Camera
Samsung Digimax A400 Digital Camera Logo
61 people viewed this question
Top Samsung Cameras Experts
Jerry Z
Andy Bale
Andy Bale
Are you a Samsung Camera Expert? Answer questions, earn points and help others
