Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Tv not responding to Remote
Changed batteries in the remote... used other programed remote for tv as well... tv not responding to either of them... could it me the infrared sensor on the TV and if so how do i fix that?
  • michelle neuber Dec 23, 2006
    i powered down the set and the remote.... for some ODD reason now it is working fine.........would still like to understand if there is a fuse or circuit issue
  • 67 Answers
Check the 5 vlts of the tv sensor
Posted on Sep 19, 2007
SOURCE:
Why is my remote not working?
If new batteries installed correctly do not get it working again, it probably has failed. Before giving up, check for damaged, corroded battery contacts.
Jan 04, 2018 | Apple MC377Z/A Device Remote Control - For...
Philips 19PS50S122 TV does not respond to remote control
Please check your batteries in the tv remote as they appear to be weak or dead. You will need to find the cable remote's paper guide in order to properly program the cable remote so it can change channels, volume, and power functions on the tv set.
Good Luck!
Rich Lilja
Jan 05, 2014 | Televison & Video
Remote will not work tv.
A working TV remote is a security blanket that allows us the peace of mind of knowing that we don't have to get up unless nature calls or the house catches on fire. People are more likely to spend more time and energy to fix their TV remote than to get up and change the channel. There are a number of simple fixes that can ease your mind when your TV remote is not working.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • New Batteries
  1. Check the batteries. Make sure the batteries are in correctly and, if they are, replace the batteries. If the batteries are dead or are not in correctly, your remote will not respond and the LED light will not illuminate when a button is pressed. Make sure the TV is plugged in. An unplugged TV will not respond to any remote.
  2. Check the selected input to make sure the remote is set on the TV and not some other device programmed into the remote, such as your DVD player, VCR, or video game console.
  3. Reprogram the sync code. If you are using a universal remote, it may have deprogrammed, leaving the remote and TV out of sync.
  4. Unplug the TV for a few minutes. During a power surge, a TV can become "confused." Unplugging it for a few minutes will give the TV the break it needs to sort everything out and work properly with your remote.
  5. Use another remote on the TV. Program a universal remote to work with the TV. If the TV does not respond, the problem is likely with the TV and not the remote control.
Jan 09, 2011 | Toshiba 62HM95 62" DLP HDTV
TV will not respond to/recognize remote. I have
Check On the Menu Setup for On/Off Remote utility Maybe your Remote signal is off on the TV Set...
Sep 22, 2010 | Mitsubishi WS-65611 65" Rear Projection...
NEED SONY CODES FOR PHILLIPS REMOTE
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Jan 02, 2010 | Philips Magnavox Learning Universal Remote
TV will not respond to remote any longer.
have you replaced the battery ?. If so the remote may be faulty. there are buttons on the tv that will do all the remote can.
Nov 30, 2017 | GE RM24909 Remote Control
My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV.  Thanks for the tip!
May 14, 2008 | Televison & Video
Sounds like the sensor on the television has gone bad, since it works for the VCR. Try a universal remote that you can program the TV and VCR codes into and try it out. If it works for the VCR and TV then you know it's the remote, if the TV still isn't responding then your TV sensor is toast.
Jan 03, 2008 | Zenith B27A11Z 27" TV
Remote problems
Take the remote to your local Radio Shack and have it tested.. They used to carry IR cards and now have a pen-like tester that can tell if the remote is operating properly. Then, if you're sure the code is correct, you probably will have to have the IR detector in the Tv replaced...
Bill
Nov 20, 2007 | RCA RCU300WBL Remote Control
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
151 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
